看到的確會出現回覆後觀看的警告欄,但當回覆後,卻會變成替代了本文~
也就是把原文替代了(可以說是刪掉原文,只留下回文).....不知道為啥會發生
這種事.....是php版本不適用了還是大約哪個檔改錯了??
安裝文件 :
## MOD HIDE | Made By / Auteur: Philiweb < http://www.philiweb.fr.st/ >
## Description : MOD "HIDE" (aka lockdown) - this mod allow users to hide
## a message via some "bbcodes", ex : [hide] message [/hide]. To see the
## hidden message, you must be a member and you must post a reply to
## the message...
## VERSION DE PHPBB : PHPBB 2.0 RC3 - RC4 - 2.0.x (gold) - 2.0.4 |02/2003|
## You can find the last versions and informations here on the official
## website (in English and French) :
## http://membres.lycos.fr/philiweb/accueil.php?num=15
## Info : There is also some pre-modified files if you have difficulties !
## And you can find some modifications to "hide" mod here :
## http://membres.lycos.fr/philiweb/accueil.php?num=23
## new : version 4 => administrators and moderators can see "hidden
## messages" immediatly...)
## Demo : http://membres.lycos.fr/philiweb/forums/viewtopic.php?t=167
## This MOD Cannot Be Posted To Or Added At Any Non-Official phpBB Sites
There is 7 files to modify :
1 - posting.php
2 - viewtopic.php
3 - search.php
4 - topic_review.php // in the "/includes" directory
5 - bbcode.php // in the "/includes" directory
6 - bbcode.tpl // in the Templates/{Used template}/ directory
7 - posting_body.tpl // in the Templates/{Used template}/ directory
This mod is easy to install. (20 mn)
1 - In posting.php
Find
if( $attach_sig && $user_sig != '' && $userdata['user_sig_bbcode_uid'] )
$user_sig = bbencode_second_pass($user_sig, $userdata['user_sig_bbcode_uid']);
if( $bbcode_on )
$preview_message = bbencode_second_pass($preview_message, $bbcode_uid);
Replace by
$valid = FALSE;
if( $userdata['session_logged_in'] ) {
$sql = "SELECT p.poster_id, p.topic_id
FROM " . POSTS_TABLE . " p
WHERE p.topic_id = $topic_id
AND p.poster_id = " . $userdata['user_id'];
$resultat = $db->sql_query($sql);
$valid = $db->sql_numrows($resultat) ? TRUE : FALSE;}
$user_sig = bbencode_third_pass($user_sig, $userdata['user_sig_bbcode_uid'], $valid);
if( $bbcode_on )
$preview_message = bbencode_third_pass($preview_message, $bbcode_uid, $valid);
Find
if ( !preg_match('/^Re:/', $subject) && strlen($subject) > 0 )
$subject = 'Re: ' . $subject;
Add Below
if( !$userdata['session_logged_in'] ) {$message = hide_in_quote($message);}
else { $sql = "SELECT p.poster_id, p.topic_id
if(!$db->sql_numrows($resultat)) {$message = hide_in_quote($message);}
2 - In viewtopic.php
Find
// Generate a 'Show posts in previous x days' select box. If the postdays var is POSTed
// then get it's value, find the number of topics with dates newer than it (to properly
// handle pagination) and alter the main query
Add below
$valid = FALSE;
Find
if ( $user_sig != '' && $user_sig_bbcode_uid != '' )
$user_sig = ( $board_config['allow_bbcode'] ) ? bbencode_second_pass($user_sig, $user_sig_bbcode_uid) : preg_replace('/\:[0-9a-z\:]+\]/si', ']', $user_sig);
if ( $bbcode_uid != '' )
$message = ( $board_config['allow_bbcode'] ) ? bbencode_second_pass($message, $bbcode_uid) : preg_replace('/\:[0-9a-z\:]+\]/si', ']', $message);
Replace by
$user_sig = bbencode_third_pass($user_sig, $user_sig_bbcode_uid, $valid);
$message = bbencode_third_pass($message, $bbcode_uid, $valid);
3 - In search.php
Find
// If the board has HTML off but the post has HTML
// on then we process it, else leave it alone
//\r
if ( $return_chars != -1 )
And replace it by
if( $return_chars == -1 )
Find
Replace by
$message = bbencode_third_pass($message, $bbcode_uid, FALSE);
4 - In topic_review.php // in the "/includes" directory
Find
\n // Okay, let's do the loop, yeah come on baby let's do the loop
// and it goes like this ...
Add below
$valid = FALSE;
Find
if ( $bbcode_uid != "" )
Replace by
5 - In bbcode.php // in the "/includes" directory
Find
$bbcode_tpl['email'] = str_replace('{EMAIL}', '\\\1', $bbcode_tpl['email']);
Add Below
$bbcode_tpl['show'] = str_replace('{HTEXTE}', '\\\1', $bbcode_tpl['show']);
*Before* this text
* Does second-pass bbencoding. This should be used before displaying the message in
* a thread. Assumes the message is already first-pass encoded, and we are given the
* correct UID as used in first-pass encoding.
Add this functions
function hide_in_quote($text)
$text = preg_replace("#\[hide\](.*?)\[\/hide\]#si","--- phpBB : The Protected Message is not copied in this quote ---", $text);
return $text;
function bbencode_third_pass($text, $uid, $deprotect)
global $bbcode_tpl;
// pad it with a space so we can distinguish between FALSE and matching the 1st char (index 0).
// This is important; bbencode_quote(), bbencode_list(), and bbencode_code() all depend on it.
$text = " " . $text;
// First: If there isn't a "[" and a "]" in the message, don't bother.
if (! (strpos($text, "[") && strpos($text, "]")) )
// Remove padding, return.
$text = substr($text, 1);
return $text;
// Patterns and replacements for URL and email tags..
$patterns = array();
$replacements = array();
if ( $deprotect ) {
$patterns[0] = "#\[hide:$uid\](.*?)\[/hide:$uid\]#si";
$replacements[0] = $bbcode_tpl['show'];
$replacements[0] = $bbcode_tpl['hide'];
$text = preg_replace($patterns, $replacements, $text);
// Remove our padding from the string..
return $text;
Find in function "bbencode_first_pass"
// [img]image_url_here[/img] code..
$text = preg_replace("#\[img\](([a-z]+?)://([^ \"
]+?))\[/img\]#si", "[img:$uid]\\\1[/img:$uid]", $text);
Add Below
//[hide]message[/hide]
$text = preg_replace("#\[hide\](.*?)\[\/hide\]#si","[hide:$uid]\\\1[/hide:$uid]", $text);
6 - In bbcode.tpl // in the Templates/{Used template}/ directory
At the top, add
<!-- BEGIN show -->
</span>
<table border="0" align="center" width="90%" cellpadding="3" cellspacing="1">
<td><span class="genmed"><b>Protected Message:</b></span></td>
<td class="quote">
{HTEXTE}
</td>
</table>
<span class="postbody">
<!-- END show -->
<!-- BEGIN hide -->
</span>
<td class="quote">
<center>--- If you are a *registered user* : you need to post in this topic to see the message ---</center>
</td>
</table>
<!-- END hide -->
7 - In posting_body.tpl // in the Templates/{Used template}/ directory
This part add a button in the dialog box (newtopic,...).
In the list of "// Helpline messages", add :
h_help = "Hide: [hide]message[/hide] (alt+h)";
Find this line :
bbtags = new Array('[b]','[/b]'...
And add at the end :
\n'[hide]' and '[/hide]'
You will obtain something like this :
bbtags = new Array('[b]','[/b]','[i]','[/i]','[u]','[/u]','[quote]','[/quote]','[code]','- ','
Find
<input type="button" class="button" accesskey="w" name="addbbcode16" value="URL" style="text-decoration: underline; width: 40px" onClick="bbstyle(16)" onMouseOver="helpline('w')" />
</span></td>
Add Below : (Don't forget to adapt the "addbbcode" numbers if neccesary ! (exemple: addbbcode18 -> addbbcode20, 20 -> 22, etc)
<input type="button" class="button" accesskey="h" name="addbbcode18" value="Hide" style="width: 40px" onClick="bbstyle(18)" onMouseOver="helpline('h')" />
</span></td>
Next, you need to modify all the "addbbcodexx" in the rest of the file. (exemple : addbbcode20 -> addbbcode22)
That's all !
Philippe
IF YOU HAVE A PROBLEM ("undefined" instead of [hide]...) - Go on my website or contact me :
http://membres.lycos.fr/philiweb/downlo ... =7&lang=en
Official page => http://membres.lycos.fr/philiweb/accueil.php?num=15
[/code]
