INSERT INTO phpbb_forums (forum_id, forum_name, cat_id, forum_desc, forum_order, forum_status,forum_sub,sort_sub, prune_enable, forum_topictypes, auth_view, auth_read, auth_post, auth_reply, auth_edit, auth_delete, auth_sticky, auth_announce, auth_vote, auth_pollcreate) VALUES ('1', '8655', 4, '368', 10, 0, 0,0,0,'', 0, 0, 0, 0, 1, 1, 3, 3, 1, 1)
這我的admin_forums後半部較可能有問題那邊!!!(降可以嗎??小竹子大人~不要再砍我文了嘛~~我很心痛...
$sql = "INSERT INTO " . FORUMS_TABLE . " (forum_id, forum_name, cat_id, forum_desc, forum_order, forum_status,forum_sub,sort_sub, prune_enable, forum_topictypes" . $field_sql . ")
VALUES ('" . $next_id . "', '" . str_replace("\'", "''", $HTTP_POST_VARS['forumname']) . "', " . $c . ", '" . str_replace("\'", "''", $HTTP_POST_VARS['forumdesc']) . "', $next_order, " . intval($HTTP_POST_VARS['forumstatus']) . ", " .$forum_sub.",".$sort_sub.",". intval($HTTP_POST_VARS['prune_enable']) . ",'".str_replace("\'", "''", $HTTP_POST_VARS['topictypes'])."'".$value_sql . ")"; if( !$result = $db->sql_query($sql) )
message_die(GENERAL_ERROR, "Couldn't insert row in forums table", "", __LINE__, __FILE__, $sql);
if( $HTTP_POST_VARS['prune_enable'] )
if( $HTTP_POST_VARS['prune_days'] == "" || $HTTP_POST_VARS['prune_freq'] == "")
message_die(GENERAL_MESSAGE, $lang['Set_prune_data']);
$sql = "INSERT INTO " . PRUNE_TABLE . " (forum_id, prune_days, prune_freq)
VALUES('" . $next_id . "', " . intval($HTTP_POST_VARS['prune_days']) . ", " . intval($HTTP_POST_VARS['prune_freq']) . ")";
message_die(GENERAL_ERROR, "Couldn't insert row in prune table", "", __LINE__, __FILE__, $sql);
$message = $lang['Forums_updated'] . "<br /><br />" . sprintf($lang['Click_return_forumadmin'], "<a href=\"" . append_sid("admin_forums.$phpEx") . "\">", "</a>") . "<br /><br />" . sprintf($lang['Click_return_admin_index'], "<a href=\"" . append_sid("index.$phpEx?pane=right") . "\">", "</a>");
break;
case 'modforum':
// Modify a forum in the DB
if( isset($HTTP_POST_VARS['prune_enable']))
if( $HTTP_POST_VARS['prune_enable'] != 1 )
$HTTP_POST_VARS['prune_enable'] = 0;
//forum_sub start
$forum_set=$HTTP_POST_VARS[POST_CAT_URL];
if(empty($forum_set))
message_die(GENERAL_ERROR, "?#93;定錯誤");
$sql = "select count(forum_sub) as id from " . FORUMS_TABLE . " WHERE forum_sub = " . intval($HTTP_POST_VARS[POST_FORUM_URL]);
\n {
$get_sub_Id = $db->sql_fetchrow($result);
if($get_sub_Id[id]>0)
message_die(GENERAL_ERROR, "此版面有其他子版面相連,無法?#93;定成子版面");
$temp=split(",",$forum_set);
$c=intval($temp[0]);
$forum_sub=intval($temp[1]);
if(intval($HTTP_POST_VARS[POST_FORUM_URL])== $forum_sub)
$sort_sub=intval($temp[2]);
$sql = "UPDATE " . FORUMS_TABLE . "
SET forum_name = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumname']) . "', forum_desc = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumdesc']) . "', forum_status = " . intval($HTTP_POST_VARS['forumstatus']) . ", prune_enable = " . intval($HTTP_POST_VARS['prune_enable']) . "
WHERE forum_id = " . intval($HTTP_POST_VARS[POST_FORUM_URL]);
}else
if(intval($temp[1])>0)
$sort_sub=intval($temp[2])+1;
}else
SET forum_name = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumname']) . "', cat_id = " . $c . ", forum_desc = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumdesc']) . "', forum_status = " . intval($HTTP_POST_VARS['forumstatus']) . ", prune_enable = " . intval($HTTP_POST_VARS['prune_enable']) . "
,forum_sub=".$forum_sub.",sort_sub=".$sort_sub." ,forum_topictypes = '".str_replace("\'", "''", $HTTP_POST_VARS['topictypes'])."'
message_die(GENERAL_ERROR, "Couldn't update forum information", "", __LINE__, __FILE__, $sql);
//forum_sub end
if( $HTTP_POST_VARS['prune_enable'] == 1 )
if( $HTTP_POST_VARS['prune_days'] == "" || $HTTP_POST_VARS['prune_freq'] == "" )
$sql = "SELECT *
FROM " . PRUNE_TABLE . "
message_die(GENERAL_ERROR, "Couldn't get forum Prune Information","",__LINE__, __FILE__, $sql);
if( $db->sql_numrows($result) > 0 )
$sql = "UPDATE " . PRUNE_TABLE . "
SET prune_days = " . intval($HTTP_POST_VARS['prune_days']) . ", prune_freq = " . intval($HTTP_POST_VARS['prune_freq']) . "
VALUES(" . intval($HTTP_POST_VARS[POST_FORUM_URL]) . ", " . intval($HTTP_POST_VARS['prune_days']) . ", " . intval($HTTP_POST_VARS['prune_freq']) . ")";
message_die(GENERAL_ERROR, "Couldn't Update Forum Prune Information","",__LINE__, __FILE__, $sql);
break;
case 'addcat':
// Create a category in the DB
if( trim($HTTP_POST_VARS['categoryname']) == '')
message_die(GENERAL_ERROR, "Can't create a category without a name");
$sql = "SELECT MAX(cat_order) AS max_order
FROM " . CATEGORIES_TABLE;
message_die(GENERAL_ERROR, "Couldn't get order number from categories table", "", __LINE__, __FILE__, $sql);
$max_order = $row['max_order'];
$next_order = $max_order + 10;
// There is no problem having duplicate forum names so we won't check for it.
$sql = "INSERT INTO " . CATEGORIES_TABLE . " (cat_title, cat_order)
VALUES ('" . str_replace("\'", "''", $HTTP_POST_VARS['categoryname']) . "', $next_order)";
message_die(GENERAL_ERROR, "Couldn't insert row in categories table", "", __LINE__, __FILE__, $sql);
break;
case 'editcat':
// Show form to edit a category
$newmode = 'modcat';
$buttonvalue = $lang['Update'];
$cat_id = intval($HTTP_GET_VARS[POST_CAT_URL]);
$row = get_info('category', $cat_id);
$cat_title = $row['cat_title'];
"body" => "admin/category_edit_body.tpl")
$s_hidden_fields = '<input type="hidden" name="mode" value="' . $newmode . '" /><input type="hidden" name="' . POST_CAT_URL . '" value="' . $cat_id . '" />';
$template->assign_vars(array(
'CAT_TITLE' => $cat_title,
'L_EDIT_CATEGORY' => $lang['Edit_Category'],
'L_EDIT_CATEGORY_EXPLAIN' => $lang['Edit_Category_explain'],
'L_CATEGORY' => $lang['Category'],
'S_HIDDEN_FIELDS' => $s_hidden_fields,
'S_SUBMIT_VALUE' => $buttonvalue,
'S_FORUM_ACTION' => append_sid("admin_forums.$phpEx"))
$template->pparse("body");
break;
case 'modcat':
// Modify a category in the DB
$sql = "UPDATE " . CATEGORIES_TABLE . "
SET cat_title = '" . str_replace("\'", "''", $HTTP_POST_VARS['cat_title']) . "'
WHERE cat_id = " . intval($HTTP_POST_VARS[POST_CAT_URL]);
break;
case 'deleteforum':
// Show form to delete a forum
$forum_id = intval($HTTP_GET_VARS[POST_FORUM_URL]);
$select_to = '<select name="to_id">';
$select_to .= "<option value=\"-1\"$s>" . $lang['Delete_all_posts'] . "</option>
$select_to .= get_list('forum', $forum_id, 0);
$select_to .= '</select>';
$buttonvalue = $lang['Move_and_Delete'];
$newmode = 'movedelforum';
$foruminfo = get_info('forum', $forum_id);
$name = $foruminfo['forum_name'];
"body" => "admin/forum_delete_body.tpl")
$s_hidden_fields = '<input type="hidden" name="mode" value="' . $newmode . '" /><input type="hidden" name="from_id" value="' . $forum_id . '" />';
'NAME' => $name,
'L_FORUM_DELETE' => $lang['Forum_delete'],
'L_FORUM_DELETE_EXPLAIN' => $lang['Forum_delete_explain'],
'L_MOVE_CONTENTS' => $lang['Move_contents'],
'L_FORUM_NAME' => $lang['Forum_name'],
"S_HIDDEN_FIELDS" => $s_hidden_fields,
'S_FORUM_ACTION' => append_sid("admin_forums.$phpEx"),
'S_SELECT_TO' => $select_to,
'S_SUBMIT_VALUE' => $buttonvalue)
break;
case 'movedelforum':
// Move or delete a forum in the DB
$from_id = intval($HTTP_POST_VARS['from_id']);
$to_id = intval($HTTP_POST_VARS['to_id']);
$delete_old = intval($HTTP_POST_VARS['delete_old']);
// Either delete or move all posts in a forum
if($to_id == -1)
// Delete polls in this forum
$sql = "SELECT v.vote_id
FROM " . VOTE_DESC_TABLE . " v, " . TOPICS_TABLE . " t
WHERE t.forum_id = $from_id
AND v.topic_id = t.topic_id";
message_die(GENERAL_ERROR, "Couldn't obtain list of vote ids", "", __LINE__, __FILE__, $sql);
$vote_ids = '';
do
$vote_ids = (($vote_ids != '') ? ', ' : '') . $row['vote_id'];
while ($row = $db->sql_fetchrow($result));
$sql = "DELETE FROM " . VOTE_DESC_TABLE . "
WHERE vote_id IN ($vote_ids)";
$db->sql_query($sql);
$sql = "DELETE FROM " . VOTE_RESULTS_TABLE . "
$sql = "DELETE FROM " . VOTE_USERS_TABLE . "
$db->sql_freeresult($result);
include($phpbb_root_path . "includes/prune.$phpEx");
prune($from_id, 0, true); // Delete everything from forum
$sql = "SELECT *
FROM " . FORUMS_TABLE . "
WHERE forum_id IN ($from_id, $to_id)";
message_die(GENERAL_ERROR, "Couldn't verify existence of forums", "", __LINE__, __FILE__, $sql);
if($db->sql_numrows($result) != 2)
message_die(GENERAL_ERROR, "Ambiguous forum ID's", "", __LINE__, __FILE__);
$sql = "UPDATE " . TOPICS_TABLE . "
SET forum_id = $to_id
WHERE forum_id = $from_id";
message_die(GENERAL_ERROR, "Couldn't move topics to other forum", "", __LINE__, __FILE__, $sql);
$sql = "UPDATE " . POSTS_TABLE . "
message_die(GENERAL_ERROR, "Couldn't move posts to other forum", "", __LINE__, __FILE__, $sql);
sync('forum', $to_id);
// Alter Mod level if appropriate - 2.0.4
$sql = "SELECT ug.user_id
FROM " . AUTH_ACCESS_TABLE . " a, " . USER_GROUP_TABLE . " ug
WHERE a.forum_id <> $from_id
AND a.auth_mod = 1
AND ug.group_id = a.group_id";
message_die(GENERAL_ERROR, "Couldn't obtain moderator list", "", __LINE__, __FILE__, $sql);
$user_ids = '';
do
$user_ids .= (($user_ids != '') ? ', ' : '' ) . $row['user_id'];
WHERE a.forum_id = $from_id
AND a.auth_mod = 1
AND ug.user_id NOT IN ($user_ids)";
if( !$result2 = $db->sql_query($sql) )
if ($row = $db->sql_fetchrow($result2))
$user_ids = '';
do
while ($row = $db->sql_fetchrow($result2));
SET user_level = " . USER . "
WHERE user_id IN ($user_ids)
AND user_level <> " . ADMIN;
$db->sql_freeresult($result2);
$sql = "DELETE FROM " . FORUMS_TABLE . "
message_die(GENERAL_ERROR, "Couldn't delete forum", "", __LINE__, __FILE__, $sql);
$sql = "DELETE FROM " . AUTH_ACCESS_TABLE . "
$sql = "DELETE FROM " . PRUNE_TABLE . "
message_die(GENERAL_ERROR, "Couldn't delete forum prune information!", "", __LINE__, __FILE__, $sql);
break;
case 'deletecat':
// Show form to delete a category
$newmode = 'movedelcat';
$catinfo = get_info('category', $cat_id);
$name = $catinfo['cat_title'];
if ($catinfo['number'] == 1)
$sql = "SELECT count(*) as total
FROM ". FORUMS_TABLE;
message_die(GENERAL_ERROR, "Couldn't get Forum count", "", __LINE__, __FILE__, $sql);
$count = $db->sql_fetchrow($result);
$count = $count['total'];
if ($count > 0)
message_die(GENERAL_ERROR, $lang['Must_delete_forums']);
$select_to = $lang['Nowhere_to_move'];
$select_to .= get_list('category', $cat_id, 0);
$s_hidden_fields = '<input type="hidden" name="mode" value="' . $newmode . '" /><input type="hidden" name="from_id" value="' . $cat_id . '" />';
'NAME' => $name,
break;
case 'movedelcat':
// Move or delete a category in the DB
if (!empty($to_id))
$sql = "SELECT *
FROM " . CATEGORIES_TABLE . "
WHERE cat_id IN ($from_id, $to_id)";
message_die(GENERAL_ERROR, "Couldn't verify existence of categories", "", __LINE__, __FILE__, $sql);
message_die(GENERAL_ERROR, "Ambiguous category ID's", "", __LINE__, __FILE__);
SET cat_id = $to_id
WHERE cat_id = $from_id";
message_die(GENERAL_ERROR, "Couldn't move forums to other category", "", __LINE__, __FILE__, $sql);
$sql = "DELETE FROM " . CATEGORIES_TABLE ."
message_die(GENERAL_ERROR, "Couldn't delete category", "", __LINE__, __FILE__, $sql);
break;
case 'forum_order':
// Change order of forums in the DB
$move = intval($HTTP_GET_VARS['move']);
$forum_info = get_info('forum', $forum_id);
$cat_id = $forum_info['cat_id'];
SET forum_order = forum_order + $move
WHERE forum_id = $forum_id";
message_die(GENERAL_ERROR, "Couldn't change category order", "", __LINE__, __FILE__, $sql);
renumber_order('forum', $forum_info['cat_id']);
$show_index = TRUE;
break;
case 'cat_order':
// Change order of categories in the DB
SET cat_order = cat_order + $move
WHERE cat_id = $cat_id";
renumber_order('category');
$show_index = TRUE;
break;
case 'forum_sync':
sync('forum', intval($HTTP_GET_VARS[POST_FORUM_URL]));
$show_index = TRUE;
break;
default:
message_die(GENERAL_MESSAGE, $lang['No_mode']);
break;
if ($show_index != TRUE)
include('./page_footer_admin.'.$phpEx);
exit;
// Start page proper
"body" => "admin/forum_admin_body.tpl")
\n 'L_FORUM_TITLE' => $lang['Forum_admin'],
'L_FORUM_EXPLAIN' => $lang['Forum_admin_explain'],
'L_CREATE_FORUM' => $lang['Create_forum'],
'L_CREATE_CATEGORY' => $lang['Create_category'],
'L_EDIT' => $lang['Edit'],
'L_DELETE' => $lang['Delete'],
'L_MOVE_UP' => $lang['Move_up'],
'L_MOVE_DOWN' => $lang['Move_down'],
'L_RESYNC' => $lang['Resync'])
$sql = "SELECT cat_id, cat_title, cat_order
ORDER BY cat_order";
if( !$q_categories = $db->sql_query($sql) )
message_die(GENERAL_ERROR, "Could not query categories list", "", __LINE__, __FILE__, $sql);
if( $total_categories = $db->sql_numrows($q_categories) )
$category_rows = $db->sql_fetchrowset($q_categories);
$sql = "SELECT *
ORDER BY cat_id, forum_order";
if(!$q_forums = $db->sql_query($sql))
message_die(GENERAL_ERROR, "Could not query forums information", "", __LINE__, __FILE__, $sql);
if( $total_forums = $db->sql_numrows($q_forums) )
$forum_rows = $db->sql_fetchrowset($q_forums);
// Okay, let's build the index
$gen_cat = array();
for($i = 0; $i < $total_categories; $i++)
$cat_id = $category_rows[$i]['cat_id'];
$template->assign_block_vars("catrow", array(
'S_ADD_FORUM_SUBMIT' => "addforum[$cat_id]",
'S_ADD_FORUM_NAME' => "forumname[$cat_id]",
'CAT_ID' => $cat_id,
'CAT_DESC' => $category_rows[$i]['cat_title'],
'U_CAT_EDIT' => append_sid("admin_forums.$phpEx?mode=editcat&" . POST_CAT_URL . "=$cat_id"),
'U_CAT_DELETE' => append_sid("admin_forums.$phpEx?mode=deletecat&" . POST_CAT_URL . "=$cat_id"),
'U_CAT_MOVE_UP' => append_sid("admin_forums.$phpEx?mode=cat_order&move=-15&" . POST_CAT_URL . "=$cat_id"),
'U_CAT_MOVE_DOWN' => append_sid("admin_forums.$phpEx?mode=cat_order&move=15&" . POST_CAT_URL . "=$cat_id"),
'U_VIEWCAT' => append_sid($phpbb_root_path."index.$phpEx?" . POST_CAT_URL . "=$cat_id"))
for($j = 0; $j < $total_forums; $j++)
$forum_id = $forum_rows[$j]['forum_id'];
if ($forum_rows[$j]['cat_id'] == $cat_id)
if($forum_rows[$j]['forum_sub']>0)
$forum_sub="<br>子版面";
$template->assign_block_vars("catrow.forumrow", array(
'FORUM_NAME' => $forum_rows[$j]['forum_name'],
'FORUM_DESC' => $forum_rows[$j]['forum_desc'],
'ROW_COLOR' => $row_color,
'NUM_TOPICS' => $forum_rows[$j]['forum_topics'],
'NUM_POSTS' => $forum_rows[$j]['forum_posts'],
'U_VIEWFORUM' => append_sid($phpbb_root_path."viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id"),
'U_FORUM_EDIT' => append_sid("admin_forums.$phpEx?mode=editforum&" . POST_FORUM_URL . "=$forum_id"),
'U_FORUM_DELETE' => append_sid("admin_forums.$phpEx?mode=deleteforum&" . POST_FORUM_URL . "=$forum_id"),
'U_FORUM_MOVE_UP' => append_sid("admin_forums.$phpEx?mode=forum_order&move=-15&" . POST_FORUM_URL . "=$forum_id"),
'U_FORUM_MOVE_DOWN' => append_sid("admin_forums.$phpEx?mode=forum_order&move=15&" . POST_FORUM_URL . "=$forum_id"),
'FORUM_SUB' =>$forum_sub, 'U_FORUM_RESYNC' => append_sid("admin_forums.$phpEx?mode=forum_sync&" . POST_FORUM_URL . "=$forum_id"))
}// if ... forumid == catid
} // for ... forums
} // for ... categories
}// if ... total_categories
