[問題] 無法建立新版面(以解決)
cain
註冊時間: 2005-03-11 18:30
[問題] 無法建立新版面(以解決)
文章 cain »
問題外掛:Mass-lock
參考連結:http://phpbb-tw.net/phpbb/viewtopic.php?t=19423
使用版本:phpBB 2.0.13
網站位置:http://cainharries.no-ip.org/phpbb/index.php
於版面管理建立新版面後出現\r
一般錯誤
Couldn't insert row in forums table
SQL Error : 1054 Unknown column 'lock_enable' in 'field list'
INSERT INTO phpbb_forums (forum_id, forum_name, cat_id, forum_desc, forum_order, forum_status, prune_enable, lock_enable, auth_view, auth_read, auth_post, auth_reply, auth_edit, auth_delete, auth_sticky, auth_announce, auth_vote, auth_pollcreate) VALUES ('7', '.', 3, '', 10, 0, 0, 0, 0, 0, 0, 0, 1, 1, 3, 3, 1, 1)
Line : 486
File : admin_forums.php
補充:
安裝外掛
Integrated Toplist 1.0.3
session force
Mass-lock
