[問題] TOP5的問題
野比小雄
文章: 129
註冊時間: 2005-02-17 18:08
來自: 107年後的某處
[問題] TOP5的問題
文章 野比小雄 »
我裝完TOP5後出現這句:
Parse error: parse error, unexpected T_DOUBLE_ARROW in d:\appserv\www\chun\phpbb2\index.php on line 409
我的index.php:
<?php
 *                                index.php
 *   $Id: index.php,v 1.99.2.3 2004/07/11 16:46:15 acydburn Exp $
define('IN_PHPBB', true);
$phpbb_root_path = './';
// Start session management
init_userprefs($userdata);
// End session management
$viewcat = ( !empty($HTTP_GET_VARS[POST_CAT_URL]) ) ? $HTTP_GET_VARS[POST_CAT_URL] : -1;
if( isset($HTTP_GET_VARS['mark']) || isset($HTTP_POST_VARS['mark']) )
	$mark_read = ( isset($HTTP_POST_VARS['mark']) ) ? $HTTP_POST_VARS['mark'] : $HTTP_GET_VARS['mark'];
	$mark_read = '';
\n}
// Handle marking posts
if( $mark_read == 'forums' )
		setcookie($board_config['cookie_name'] . '_f_all', time(), 0, $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
	$template->assign_vars(array(
		"META" => '<meta http-equiv="refresh" content="3;url='  .append_sid("index.$phpEx") . '">')
	$message = $lang['Forums_marked_read'] . '<br /><br />' . sprintf($lang['Click_return_index'], '<a href="' . append_sid("index.$phpEx") . '">', '</a> ');
// End handle marking posts
$tracking_topics = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . "_t"]) : array();
$tracking_forums = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . "_f"]) : array();
// If you don't use these stats on your index you may want to consider
// removing them
$total_posts = get_db_stat('postcount');
$total_users = get_db_stat('usercount');
$newest_userdata = get_db_stat('newestuser');
$newest_user = $newest_userdata['username'];
$newest_uid = $newest_userdata['user_id'];
if( $total_posts == 0 )
	$l_total_post_s = $lang['Posted_articles_zero_total'];
else if( $total_posts == 1 )
	$l_total_post_s = $lang['Posted_article_total'];
	$l_total_post_s = $lang['Posted_articles_total'];
if( $total_users == 0 )
	$l_total_user_s = $lang['Registered_users_zero_total'];
else if( $total_users == 1 )
	$l_total_user_s = $lang['Registered_user_total'];
	$l_total_user_s = $lang['Registered_users_total'];
// Start page proper
$sql = "SELECT c.cat_id, c.cat_title, c.cat_order
	FROM " . CATEGORIES_TABLE . " c
	ORDER BY c.cat_order";
	message_die(GENERAL_ERROR, 'Could not query categories list', '', __LINE__, __FILE__, $sql);
$category_rows = array();
while( $category_rows[] = $db->sql_fetchrow($result) );
$db->sql_freeresult($result);
if( ( $total_categories = count($category_rows) ) )
	// Define appropriate SQL
	switch(SQL_LAYER)
		case 'postgresql':
			$sql = "SELECT f.*, p.post_time, p.post_username, u.username, u.user_id
				FROM " . FORUMS_TABLE . " f, " . POSTS_TABLE . " p, " . USERS_TABLE . " u
				WHERE p.post_id = f.forum_last_post_id
					AND u.user_id = p.poster_id
					UNION (
						SELECT f.*, NULL, NULL, NULL, NULL
						WHERE NOT EXISTS (
							SELECT p.post_time
							FROM " . POSTS_TABLE . " p
					ORDER BY cat_id, forum_order";
			break;
		case 'oracle':
				WHERE p.post_id = f.forum_last_post_id(+)
					AND u.user_id = p.poster_id(+)
			break;
		default:
				FROM (( " . FORUMS_TABLE . " f
				LEFT JOIN " . POSTS_TABLE . " p ON p.post_id = f.forum_last_post_id )
				LEFT JOIN " . USERS_TABLE . " u ON u.user_id = p.poster_id )
			break;
		message_die(GENERAL_ERROR, 'Could not query forums information', '', __LINE__, __FILE__, $sql);
	$forum_data = array();
		$forum_data[] = $row;
	if ( !($total_forums = count($forum_data)) )
		message_die(GENERAL_MESSAGE, $lang['No_forums']);
	// Obtain a list of topic ids which contain
	// posts made since user last visited
		$sql = "SELECT t.forum_id, t.topic_id, p.post_time
			FROM " . TOPICS_TABLE . " t, " . POSTS_TABLE . " p
			WHERE p.post_id = t.topic_last_post_id
				AND p.post_time > " . $userdata['user_lastvisit'] . "
				AND t.topic_moved_id = 0";
			message_die(GENERAL_ERROR, 'Could not query new topic information', '', __LINE__, __FILE__, $sql);
		$new_topic_data = array();
		while( $topic_data = $db->sql_fetchrow($result) )
			$new_topic_data[$topic_data['forum_id']][$topic_data['topic_id']] = $topic_data['post_time'];
	// Obtain list of moderators of each forum
	// First users, then groups ... broken into two queries
	$sql = "SELECT aa.forum_id, u.user_id, u.username
		FROM " . AUTH_ACCESS_TABLE . " aa, " . USER_GROUP_TABLE . " ug, " . GROUPS_TABLE . " g, " . USERS_TABLE . " u
		WHERE aa.auth_mod = " . TRUE . "
			AND g.group_single_user = 1
			AND ug.group_id = aa.group_id
			AND g.group_id = aa.group_id
			AND u.user_id = ug.user_id
		GROUP BY u.user_id, u.username, aa.forum_id
		ORDER BY aa.forum_id, u.user_id";
		message_die(GENERAL_ERROR, 'Could not query forum moderator information', '', __LINE__, __FILE__, $sql);
	$forum_moderators = array();
		$forum_moderators[$row['forum_id']][] = '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $row['user_id']) . '">' . $row['username'] . '</a>';
	$sql = "SELECT aa.forum_id, g.group_id, g.group_name
			AND g.group_single_user = 0
			AND g.group_type <> " . GROUP_HIDDEN . "
		GROUP BY g.group_id, g.group_name, aa.forum_id
		ORDER BY aa.forum_id, g.group_id";
		$forum_moderators[$row['forum_id']][] = '<a href="' . append_sid("groupcp.$phpEx?" . POST_GROUPS_URL . "=" . $row['group_id']) . '">' . $row['group_name'] . '</a>';
	// Find which forums are visible for this user
	$is_auth_ary = array();
	$is_auth_ary = auth(AUTH_VIEW, AUTH_LIST_ALL, $userdata, $forum_data);
   // TOP5 MOD Begin Edit by bu MOD by OOHOO
   $auth_forum_ary = array();
   // Get forum info
   $sql = "SELECT forum_id FROM " . FORUMS_TABLE;
   if( !$q_forums = $db->sql_query($sql) )
      message_die(GENERAL_MESSAGE, 'ADV_TOP5 MOD ERROR!!');
   // Authorized forums info
   while( $forum_row = $db->sql_fetchrow($q_forums) )
      $forum_id = $forum_row['forum_id'];
      if( $is_auth_ary[$forum_id]['auth_read'] == 1)
         array_push($auth_forum_ary, $forum_id);
   if( sizeOf($auth_forum_ary) == 0 || !$AUTH_SECRUITY )
      $auth_forums = "";
      $auth_forums = 'AND f.forum_id IN(';
      if(sizeOf($auth_forum_ary) > 1)
         $auth_forums .= implode (',', $auth_forum_ary);
         $auth_forums .= $auth_forum_ary[0];
      $auth_forums .= ')';
// Mod setting
// Topics text length
$MAX_STR_LEN = 60;
// Topics to display
$MAX_TOPICS = 5;
// 0 => users can see all topics including authorized issue(but they cant read the posts)
// 1 => users can see only authorized topics
$AUTH_SECRUITY = 1;
function cutStr($str) {
   global $MAX_STR_LEN;
   $str = (strlen($str) > $MAX_STR_LEN) ? (substr($str, 0, $MAX_STR_LEN - 1) . "...") : $str;
   return $str;
// query
$sql = "SELECT topic_id, topic_title, topic_poster, topic_views, topic_replies, topic_last_post_id, f.forum_id, forum_name
   FROM " . TOPICS_TABLE . " t, " . FORUMS_TABLE . " f
   WHERE t.forum_id = f.forum_id
   AND topic_moved_id = '0'
   $auth_forums
   ORDER BY topic_last_post_id DESC LIMIT 0, $MAX_TOPICS";
   echo '<p align="center"><font color="red"><b>ADV_TOPN_MOD TOPICS QUERY ERROR!!</b></font></p>';
   exit;
// fetch rows
while( $rows = $db->sql_fetchrow($result) )
   $topic_url = append_sid("viewtopic.$phpEx?t=" . $rows['topic_id']);
   $forum_url = append_sid("viewforum.$phpEx?f=" . $rows['forum_id']);
   $topic_poster = $rows['topic_poster'];
   $topic_last_post_id = $rows['topic_last_post_id'];
   // Grab topic poster and last replier data
   $sql = "SELECT post_username, user_id, username
      FROM " . POSTS_TABLE . ", " . USERS_TABLE . "
      WHERE topic_id = '" . $rows['topic_id'] . "'
      AND poster_id = user_id
      ORDER BY post_id LIMIT 0, 1";
   if( !$p_result = $db->sql_query($sql) )
      message_die(GENERAL_MESSAGE, 'ADV_TOP5 MOD TOPIC_POSTER QUERY ERROR!!');
   $p_row = $db->sql_fetchrow($p_result);
   $poster_name = ( $topic_poster != ANONYMOUS ) ? $p_row['username'] : ( !$p_row['post_username'] ? $lang['Guest'] : $p_row['post_username']);
   $poster_url = ( $topic_poster != ANONYMOUS && !$p_row['post_username'] ) ? ('<a href="' . append_sid("profile.$phpEx?mode=viewprofile&u=$topic_poster") . '" target="_top">' . "$poster_name</a>") : $poster_name;
   $sql = "SELECT post_username, user_id, username, post_time
      WHERE post_id = '$topic_last_post_id'
      AND poster_id = user_id";
   if( !$r_result = $db->sql_query($sql) )
      message_die(GENERAL_MESSAGE, 'ADV_TOP5 MOD LAST_REPLIER QUERY ERROR!!');
   $r_row = $db->sql_fetchrow($r_result);
   $replier_id = $r_row['user_id'];
   $replier_name = ( $replier_id != ANONYMOUS ) ? $r_row['username'] : ( !$r_row['post_username'] ? $lang['Guest'] : $r_row['post_username']);
   $replier_url = ( $replier_id != ANONYMOUS && !$r_row['post_username'] ) ? ('<a href="' . append_sid("profile.$phpEx?mode=viewprofile&u=$replier_id") . '" target="_top">' . "$replier_name</a>") : $replier_name;
   $last_post_url = append_sid("viewtopic.$phpEx?p=$topic_last_post_id#$topic_last_post_id");
   $template->assign_block_vars("top5row", array(
      "forum_name" => $rows['forum_name'],
      "forum_url" => $forum_url,
      "topic" => cutStr($rows['topic_title']),
      "topic_url" => $topic_url,
      "topic_views" => $rows['topic_views'],
      "topic_replies" => $rows['topic_replies'],
      "post_time" => create_date($board_config['default_dateformat'], $r_row['post_time'], $board_config['board_timezone']),
      "poster_url" => $poster_url,
      "replier_url" => $replier_url,
      "last_post_url" => $last_post_url
   // TOP5 MOD END Edit by bu
	// Start output of page
	define('SHOW_ONLINE', true);
\n	$page_title = $lang['Index'];
		'body' => 'index_body.tpl')
		'TOTAL_POSTS' => sprintf($l_total_post_s, $total_posts),
		'TOTAL_USERS' => sprintf($l_total_user_s, $total_users),
		'NEWEST_USER' => sprintf($lang['Newest_user'], '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$newest_uid") . '">',
      'icon_url' => $images['icon_latest_reply'], // TOP5
      'icon_alt' => $lang['View_latest_post'], // TOP5
          'L_AUTHOR' => $lang['Author'], // TOP5 $newest_user, '</a>'),
		'FORUM_IMG' => $images['forum'],
		'FORUM_NEW_IMG' => $images['forum_new'],
\r
		'L_FORUM' => $lang['Forum'],
		'L_TOPICS' => $lang['Topics'],
		'L_REPLIES' => $lang['Replies'],
		'L_VIEWS' => $lang['Views'],
		'L_POSTS' => $lang['Posts'],
		'L_LASTPOST' => $lang['Last_Post'],
		'L_NO_NEW_POSTS' => $lang['No_new_posts'],
		'L_NEW_POSTS' => $lang['New_posts'],
		'L_NO_NEW_POSTS_LOCKED' => $lang['No_new_posts_locked'],
		'L_NEW_POSTS_LOCKED' => $lang['New_posts_locked'],
		'L_ONLINE_EXPLAIN' => $lang['Online_explain'],
		'L_MODERATOR' => $lang['Moderators'],
		'L_FORUM_LOCKED' => $lang['Forum_is_locked'],
		'L_MARK_FORUMS_READ' => $lang['Mark_all_forums'],
		'U_MARK_READ' => append_sid("index.$phpEx?mark=forums"))
	// Okay, let's build the index
	for($i = 0; $i < $total_categories; $i++)
		$cat_id = $category_rows[$i]['cat_id'];
		// Should we display this category/forum set?
		$display_forums = false;
		for($j = 0; $j < $total_forums; $j++)
			if ( $is_auth_ary[$forum_data[$j]['forum_id']]['auth_view'] && $forum_data[$j]['cat_id'] == $cat_id )
				$display_forums = true;
		// Yes, we should, so first dump out the category
		// title, then, if appropriate the forum list
		if ( $display_forums )
			$template->assign_block_vars('catrow', array(
				'CAT_ID' => $cat_id,
				'CAT_DESC' => $category_rows[$i]['cat_title'],
				'U_VIEWCAT' => append_sid("index.$phpEx?" . POST_CAT_URL . "=$cat_id"))
			if ( $viewcat == $cat_id || $viewcat == -1 )
					if ( $forum_data[$j]['cat_id'] == $cat_id )
						$forum_id = $forum_data[$j]['forum_id'];
						if ( $is_auth_ary[$forum_id]['auth_view'] )
							if ( $forum_data[$j]['forum_status'] == FORUM_LOCKED )
								$folder_image = $images['forum_locked'];
								$folder_alt = $lang['Forum_locked'];
								$unread_topics = false;
									if ( !empty($new_topic_data[$forum_id]) )
										$forum_last_post_time = 0;
										while( list($check_topic_id, $check_post_time) = @each($new_topic_data[$forum_id]) )
											if ( empty($tracking_topics[$check_topic_id]) )
												$unread_topics = true;
												$forum_last_post_time = max($check_post_time, $forum_last_post_time);
												if ( $tracking_topics[$check_topic_id] < $check_post_time )
										if ( !empty($tracking_forums[$forum_id]) )
											if ( $tracking_forums[$forum_id] > $forum_last_post_time )
										if ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all']) )
											if ( $HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all'] > $forum_last_post_time )
								$folder_image = ( $unread_topics ) ? $images['forum_new'] : $images['forum'];
								$folder_alt = ( $unread_topics ) ? $lang['New_posts'] : $lang['No_new_posts'];
							$posts = $forum_data[$j]['forum_posts'];
							$topics = $forum_data[$j]['forum_topics'];
							if ( $forum_data[$j]['forum_last_post_id'] )
								$last_post_time = create_date($board_config['default_dateformat'], $forum_data[$j]['post_time'], $board_config['board_timezone']);
								$last_post = $last_post_time . '<br />';
								$last_post .= ( $forum_data[$j]['user_id'] == ANONYMOUS ) ? ( ($forum_data[$j]['post_username'] != '' ) ? $forum_data[$j]['post_username'] . ' ' : $lang['Guest'] . ' ' ) : '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . '='  . $forum_data[$j]['user_id']) . '">' . $forum_data[$j]['username'] . '</a> ';
								$last_post .= '<a href="' . append_sid("viewtopic.$phpEx?"  . POST_POST_URL . '=' . $forum_data[$j]['forum_last_post_id']) . '#' . $forum_data[$j]['forum_last_post_id'] . '"><img src="' . $images['icon_latest_reply'] . '" border="0" alt="' . $lang['View_latest_post'] . '" title="' . $lang['View_latest_post'] . '" /></a>';
								$last_post = $lang['No_Posts'];
							if ( count($forum_moderators[$forum_id]) > 0 )
								$l_moderators = ( count($forum_moderators[$forum_id]) == 1 ) ? $lang['Moderator'] : $lang['Moderators'];
								$moderator_list = implode(', ', $forum_moderators[$forum_id]);
								$l_moderators = ' ';
								$moderator_list = ' ';
							$template->assign_block_vars('catrow.forumrow',	array(
								'ROW_CLASS' => $row_class,
								'FORUM_FOLDER_IMG' => $folder_image,
								'FORUM_NAME' => $forum_data[$j]['forum_name'],
								'FORUM_DESC' => $forum_data[$j]['forum_desc'],
								'POSTS' => $forum_data[$j]['forum_posts'],
								'TOPICS' => $forum_data[$j]['forum_topics'],
								'LAST_POST' => $last_post,
								'MODERATORS' => $moderator_list,
								'L_MODERATOR' => $l_moderators,
								'L_FORUM_FOLDER_ALT' => $folder_alt,
								'U_VIEWFORUM' => append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id"))
	} // for ... categories
}// if ... total_categories
// Generate the page
$template->pparse('body');
bu
文章: 443
註冊時間: 2003-02-23 12:46
來自: 25° 4′N 121° 29′E
文章 bu »
請用 Integreated Toplist 1.0.3
官方外掛區有 ;)
(即是新版的整合式 TOP5)
*譯文資料在phpBB 技術文件
bu.femto-size
*和我聯絡,請寄 or Google Talk 圖檔
野比小雄
文章: 129
來自: 107年後的某處
文章 野比小雄 »
沒事了^^
謝~~
