<?php
* profile.php
* email : support@phpbb.com
* $Id: profile.php,v 1.193.2.5 2004/11/18 17:49:37 acydburn Exp $
define('IN_PHPBB', true);
if ( (isset($HTTP_GET_VARS['mode']) && ($HTTP_GET_VARS['mode'] == 'viewprofile')) || (isset($HTTP_POST_VARS['mode']) && ($HTTP_POST_VARS['mode'] == 'viewprofile')) )
define('IN_CASHMOD', true);
define('CM_VIEWPROFILE',true);
$phpbb_root_path = './';
// Start session management
$userdata = session_pagestart($user_ip, PAGE_PROFILE);
init_userprefs($userdata);
// End session management
// session id check
if (!empty($HTTP_POST_VARS['sid']) || !empty($HTTP_GET_VARS['sid']))
$sid = (!empty($HTTP_POST_VARS['sid'])) ? $HTTP_POST_VARS['sid'] : $HTTP_GET_VARS['sid'];
$sid = '';
// Set default email variables
$script_name = preg_replace('/^\\/?(.*?)\/?$/', '\1', trim($board_config['script_path']));
$script_name = ( $script_name != '' ) ? $script_name . '/profile.'.$phpEx : 'profile.'.$phpEx;
$server_name = trim($board_config['server_name']);
$server_protocol = ( $board_config['cookie_secure'] ) ? 'https://' : 'http://';
$server_port = ( $board_config['server_port'] <> 80 ) ? ':' . trim($board_config['server_port']) . '/' : '/';
$server_url = $server_protocol . $server_name . $server_port . $script_name;
// Page specific functions
function gen_rand_string($hash)
$chars = array( 'a', 'A', 'b', 'B', 'c', 'C', 'd', 'D', 'e', 'E', 'f', 'F', 'g', 'G', 'h', 'H', 'i', 'I', 'j', 'J', 'k', 'K', 'l', 'L', 'm', 'M', 'n', 'N', 'o', 'O', 'p', 'P', 'q', 'Q', 'r', 'R', 's', 'S', 't', 'T', 'u', 'U', 'v', 'V', 'w', 'W', 'x', 'X', 'y', 'Y', 'z', 'Z', '1', '2', '3', '4', '5', '6', '7', '8', '9', '0');
$max_chars = count($chars) - 1;
srand( (double) microtime()*1000000);
$rand_str = '';
for($i = 0; $i < 8; $i++)
$rand_str = ( $i == 0 ) ? $chars[rand(0, $max_chars)] : $rand_str . $chars[rand(0, $max_chars)];
return ( $hash ) ? md5($rand_str) : $rand_str;
// End page specific functions
// Start of program proper
if ( isset($HTTP_GET_VARS['mode']) || isset($HTTP_POST_VARS['mode']) )
$mode = ( isset($HTTP_GET_VARS['mode']) ) ? $HTTP_GET_VARS['mode'] : $HTTP_POST_VARS['mode'];
$mode = htmlspecialchars($mode);
if ( $mode == 'viewprofile' )
include($phpbb_root_path . 'includes/usercp_viewprofile.'.$phpEx);
exit;
else if ( $mode == 'editprofile' || $mode == 'register' )
if ( !$userdata['session_logged_in'] && $mode == 'editprofile' )
redirect(append_sid("login.$phpEx?redirect=profile.$phpEx&mode=editprofile", true));
include($phpbb_root_path . 'includes/usercp_register.'.$phpEx);
exit;
else if ( $mode == 'confirm' )
// Visual Confirmation
exit;
include($phpbb_root_path . 'includes/usercp_confirm.'.$phpEx);
exit;
else if ( $mode == 'sendpassword' )
include($phpbb_root_path . 'includes/usercp_sendpasswd.'.$phpEx);
exit;
else if ( $mode == 'activate' )
include($phpbb_root_path . 'includes/usercp_activate.'.$phpEx);
exit;
else if ( $mode == 'email' )
include($phpbb_root_path . 'includes/usercp_email.'.$phpEx);
exit;
redirect(append_sid("index.$phpEx", true));
