從會員資料中發生資料查詢錯誤
SQL Error : 1146 Table 'jerry691017.color_groups_table' doesn't exist
SELECT group_id, group_name FROM COLOR_GROUPS_TABLE
Line : 145
File : admin_color_groups.php版主: 版主管理群
從會員資料中發生資料查詢錯誤
Line : 145
File : admin_color_groups.php我確定有執行"nivisec_install.php"這個檔案tseesther 寫:有mysql那邊的語法未執行?
可以的話請附上安裝檔
Line : 145
File : admin_color_groups.phpjerry6983 寫:安裝完出現下列錯誤:
請問各位大大是那裡出錯??代碼: 選擇全部
從會員資料中發生資料查詢錯誤 DEBUG MODE SQL Error : 1146 Table 'jerry691017.color_groups_table' doesn't exist SELECT group_id, group_name FROM[color=red], [/color]COLOR_GROUPS_TABLE Line : 145 File : admin_color_groups.php
忘了問.....jerry6983 寫:The working status of your phpBB version with this mod is unknown. It may or may not work correctly. If it is higher than 2.0.5 it will probably work, but no guarantees.
Found phpbb root path at ./.
Using sql queue list file nivisec_schema/install.sql.
Found php version 4.3.8.
Found phpbb version 2.0.14.
[FAILED] :: CREATE TABLE `phpbb_color_groups` ( `group_id` mediumint(8) unsigned NOT NULL auto_increment, `group_name` varchar(255) NOT NULL default '', `group_color` varchar(50) NOT NULL default '', PRIMARY KEY (`group_id`), UNIQUE KEY `group_name` (`group_name`) ) TYPE=MyISAM
Reason:Table 'phpbb_color_groups' already exists
Analysis:This is considered a duplicate entry and can be ignored as a failure because the needed information is already inserted.
[FAILED] :: ALTER TABLE `phpbb_users` ADD `user_color_group` MEDIUMINT UNSIGNED NOT NULL
Reason:Duplicate column name 'user_color_group'
[OK] :: ALTER TABLE `phpbb_color_groups` ADD `hidden` TINYINT( 1 ) DEFAULT '0' NOT NULL
[OK] :: ALTER TABLE `phpbb_color_groups` ADD `order_num` MEDIUMINT NOT NULL
[FAILED] :: ALTER TABLE `phpbb_groups` ADD `group_color_group` MEDIUMINT UNSIGNED NOT NULL
Reason:Duplicate column name 'group_color_group'
Please delete this file (nivisec_install.php) and nivisec_schema/*.* for security reasons!
第一次裝就有了,我想自己手動安裝sql也沒無法成功tseesther 寫:忘了問.....jerry6983 寫:The working status of your phpBB version with this mod is unknown. It may or may not work correctly. If it is higher than 2.0.5 it will probably work, but no guarantees.
以上這段出現是你第一次裝已有?還是你重覆執行nivisec_install才出現?
tseesther 寫:如果第一次裝已有就奇怪了......
它說其中有幾項之前已有所以建立失敗.... 但你說這是第一次裝呢.....
或許你之前曾經裝過類似的外掛??或嘗試裝過沒有成功但又沒有移除已修改的東西.........
sql那邊它說有幾項是失敗,你看看是否可以把它們移除(想想有沒有其他外掛是需要它們)然後再裝過:
- phpbb_color_groups
- phpbb_users 裡的 user_color_group
- phpbb_groups 裡的 group_color_group
