Fatal error: Call to a member function on a non-object in /home/www/rurutan.coolinc.info/phpBB2/includes/functions_post.php on line 357
functions_post.php 如下
<?php
* functions_post.php
* email : support@phpbb.com
* $Id: functions_post.php,v 1.9.2.37 2004/11/18 17:49:44 acydburn Exp $
if (!defined('IN_PHPBB'))
die('Hacking attempt');
$html_entities_match = array('#&(?!(\#[0-9]+;))#', '#<#', '#>#');
$html_entities_replace = array('&', '<', '>');
$unhtml_specialchars_match = array('#>#', '#<#', '#"#', '#&#');
$unhtml_specialchars_replace = array('>', '<', '"', '&');
// This function will prepare a posted message for
// entry into the database.
function prepare_message($message, $html_on, $bbcode_on, $smile_on, $bbcode_uid = 0)
global $board_config, $html_entities_match, $html_entities_replace;
// Clean up the message
$message = trim($message);
if ($html_on)
$allowed_html_tags = split(',', $board_config['allow_html_tags']);
$end_html = 0;
$start_html = 1;
$tmp_message = '';
$message = ' ' . $message . ' ';
while ($start_html = strpos($message, '<', $start_html))
$tmp_message .= preg_replace($html_entities_match, $html_entities_replace, substr($message, $end_html + 1, ($start_html - $end_html - 1)));
if ($end_html = strpos($message, '>', $start_html))
$length = $end_html - $start_html + 1;
$hold_string = substr($message, $start_html, $length);
if (($unclosed_open = strrpos(' ' . $hold_string, '<')) != 1)
$tmp_message .= preg_replace($html_entities_match, $html_entities_replace, substr($hold_string, 0, $unclosed_open - 1));
$hold_string = substr($hold_string, $unclosed_open - 1);
$tagallowed = false;
for ($i = 0; $i < sizeof($allowed_html_tags); $i++)
$match_tag = trim($allowed_html_tags[$i]);
if (preg_match('#^<\/?' . $match_tag . '[> ]#i', $hold_string))
$tagallowed = (preg_match('#^<\/?' . $match_tag . ' .*?(style[\t ]*?=|on[\w]+[\t ]*?=)#i', $hold_string)) ? false : true;
$tmp_message .= ($length && !$tagallowed) ? preg_replace($html_entities_match, $html_entities_replace, $hold_string) : $hold_string;
$start_html += $length;
$tmp_message .= preg_replace($html_entities_match, $html_entities_replace, substr($message, $start_html, strlen($message)));
$start_html = strlen($message);
$end_html = $start_html;
if (!$end_html || ($end_html != strlen($message) && $tmp_message != ''))
$tmp_message .= preg_replace($html_entities_match, $html_entities_replace, substr($message, $end_html + 1));
$message = ($tmp_message != '') ? trim($tmp_message) : trim($message);
$message = preg_replace($html_entities_match, $html_entities_replace, $message);
if($bbcode_on && $bbcode_uid != '')
$message = bbencode_first_pass($message, $bbcode_uid);
return $message;
function unprepare_message($message)
global $unhtml_specialchars_match, $unhtml_specialchars_replace;
return preg_replace($unhtml_specialchars_match, $unhtml_specialchars_replace, $message);
// Prepare a message for posting
function prepare_post(&$mode, &$post_data, &$bbcode_on, &$html_on, &$smilies_on, &$error_msg, &$username, &$bbcode_uid, &$subject, &$message, &$poll_title, &$poll_options, &$poll_length)
global $board_config, $userdata, $lang, $phpEx, $phpbb_root_path;
// Check username
if (!empty($username))
$username = phpbb_clean_username($username);
if (!$userdata['session_logged_in'] || ($userdata['session_logged_in'] && $username != $userdata['username']))
include($phpbb_root_path . 'includes/functions_validate.'.$phpEx);
$result = validate_username($username);
if ($result['error'])
$error_msg .= (!empty($error_msg)) ? '<br />' . $result['error_msg'] : $result['error_msg'];
$username = '';
// Check subject
if (!empty($subject))
$subject = htmlspecialchars(trim($subject));
else if ($mode == 'newtopic' || ($mode == 'editpost' && $post_data['first_post']))
$error_msg .= (!empty($error_msg)) ? '<br />' . $lang['Empty_subject'] : $lang['Empty_subject'];
// Check message
if (!empty($message))
$bbcode_uid = ($bbcode_on) ? make_bbcode_uid() : '';
$message = prepare_message(trim($message), $html_on, $bbcode_on, $smilies_on, $bbcode_uid);
else if ($mode != 'delete' && $mode != 'poll_delete')
$error_msg .= (!empty($error_msg)) ? '<br />' . $lang['Empty_message'] : $lang['Empty_message'];
// Handle poll stuff
$poll_length = (isset($poll_length)) ? max(0, intval($poll_length)) : 0;
if (!empty($poll_title))
$poll_title = htmlspecialchars(trim($poll_title));
if(!empty($poll_options))
$temp_option_text = array();
while(list($option_id, $option_text) = @each($poll_options))
$option_text = trim($option_text);
if (!empty($option_text))
$temp_option_text[$option_id] = htmlspecialchars($option_text);
$option_text = $temp_option_text;
if (count($poll_options) < 2)
$error_msg .= (!empty($error_msg)) ? '<br />' . $lang['To_few_poll_options'] : $lang['To_few_poll_options'];
else if (count($poll_options) > $board_config['max_poll_options'])
$error_msg .= (!empty($error_msg)) ? '<br />' . $lang['To_many_poll_options'] : $lang['To_many_poll_options'];
else if ($poll_title == '')
$error_msg .= (!empty($error_msg)) ? '<br />' . $lang['Empty_poll_title'] : $lang['Empty_poll_title'];
return;
// Post a new topic/reply/poll or edit existing post/poll
function submit_post($mode, &$post_data, &$message, &$meta, &$forum_id, &$topic_id, &$post_id, &$poll_id, &$topic_type, &$bbcode_on, &$html_on, &$smilies_on, &$attach_sig, &$bbcode_uid, &$post_username, &$post_subject, &$post_message, &$poll_title, &$poll_options, &$poll_length)
global $board_config, $lang, $db, $phpbb_root_path, $phpEx;
global $userdata, $user_ip;
include($phpbb_root_path . 'includes/functions_search.'.$phpEx);
$current_time = time();
if ($mode == 'newtopic' || $mode == 'reply' || $mode == 'editpost')
// Flood control
$where_sql = ($userdata['user_id'] == ANONYMOUS) ? "poster_ip = '$user_ip'" : 'poster_id = ' . $userdata['user_id'];
$sql = "SELECT MAX(post_time) AS last_post_time
FROM " . POSTS_TABLE . "
WHERE $where_sql";
if ($result = $db->sql_query($sql))
if (intval($row['last_post_time']) > 0 && ($current_time - intval($row['last_post_time'])) < intval($board_config['flood_interval']))
message_die(GENERAL_MESSAGE, $lang['Flood_Error']);
if ($mode == 'editpost')
remove_search_post($post_id);
$topic_vote = (!empty($poll_title) && count($poll_options) >= 2) ? 1 : 0;
$sql = ($mode != "editpost") ? "INSERT INTO " . TOPICS_TABLE . " (topic_title, topic_poster, topic_time, forum_id, topic_status, topic_type, topic_vote) VALUES ('$post_subject', " . $userdata['user_id'] . ", $current_time, $forum_id, " . TOPIC_UNLOCKED . ", $topic_type, $topic_vote)" : "UPDATE " . TOPICS_TABLE . " SET topic_title = '$post_subject', topic_type = $topic_type " . (($post_data['edit_vote'] || !empty($poll_title)) ? ", topic_vote = " . $topic_vote : "") . " WHERE topic_id = $topic_id";
if (!$db->sql_query($sql))
message_die(GENERAL_ERROR, 'Error in posting', '', __LINE__, __FILE__, $sql);
if ($mode == 'newtopic')
$topic_id = $db->sql_nextid();
$edited_sql = ($mode == 'editpost' && !$post_data['last_post'] && $post_data['poster_post']) ? ", post_edit_time = $current_time, post_edit_count = post_edit_count + 1 " : "";
$sql = ($mode != "editpost") ? "INSERT INTO " . POSTS_TABLE . " (topic_id, forum_id, poster_id, post_username, post_time, poster_ip, enable_bbcode, enable_html, enable_smilies, enable_sig) VALUES ($topic_id, $forum_id, " . $userdata['user_id'] . ", '$post_username', $current_time, '$user_ip', $bbcode_on, $html_on, $smilies_on, $attach_sig)" : "UPDATE " . POSTS_TABLE . " SET post_username = '$post_username', enable_bbcode = $bbcode_on, enable_html = $html_on, enable_smilies = $smilies_on, enable_sig = $attach_sig" . $edited_sql . " WHERE post_id = $post_id";
if (!$db->sql_query($sql, BEGIN_TRANSACTION))
if ($mode != 'editpost')
$post_id = $db->sql_nextid();
$sql = ($mode != 'editpost') ? "INSERT INTO " . POSTS_TEXT_TABLE . " (post_id, post_subject, bbcode_uid, post_text) VALUES ($post_id, '$post_subject', '$bbcode_uid', '$post_message')" : "UPDATE " . POSTS_TEXT_TABLE . " SET post_text = '$post_message', bbcode_uid = '$bbcode_uid', post_subject = '$post_subject' WHERE post_id = $post_id";
add_search_words('single', $post_id, stripslashes($post_message), stripslashes($post_subject));
// Add poll
if (($mode == 'newtopic' || ($mode == 'editpost' && $post_data['edit_poll'])) && !empty($poll_title) && count($poll_options) >= 2)
$sql = (!$post_data['has_poll']) ? "INSERT INTO " . VOTE_DESC_TABLE . " (topic_id, vote_text, vote_start, vote_length) VALUES ($topic_id, '$poll_title', $current_time, " . ($poll_length * 86400) . ")" : "UPDATE " . VOTE_DESC_TABLE . " SET vote_text = '$poll_title', vote_length = " . ($poll_length * 86400) . " WHERE topic_id = $topic_id";
$delete_option_sql = '';
$old_poll_result = array();
if ($mode == 'editpost' && $post_data['has_poll'])
$sql = "SELECT vote_option_id, vote_result
FROM " . VOTE_RESULTS_TABLE . "
WHERE vote_id = $poll_id
ORDER BY vote_option_id ASC";
message_die(GENERAL_ERROR, 'Could not obtain vote data results for this topic', '', __LINE__, __FILE__, $sql);
$old_poll_result[$row['vote_option_id']] = $row['vote_result'];
if (!isset($poll_options[$row['vote_option_id']]))
$delete_option_sql .= ($delete_option_sql != '') ? ', ' . $row['vote_option_id'] : $row['vote_option_id'];
$poll_id = $db->sql_nextid();
@reset($poll_options);
$poll_option_id = 1;
while (list($option_id, $option_text) = each($poll_options))
$option_text = str_replace("\'", "''", htmlspecialchars($option_text));
$poll_result = ($mode == "editpost" && isset($old_poll_result[$option_id])) ? $old_poll_result[$option_id] : 0;
$sql = ($mode != "editpost" || !isset($old_poll_result[$option_id])) ? "INSERT INTO " . VOTE_RESULTS_TABLE . " (vote_id, vote_option_id, vote_option_text, vote_result) VALUES ($poll_id, $poll_option_id, '$option_text', $poll_result)" : "UPDATE " . VOTE_RESULTS_TABLE . " SET vote_option_text = '$option_text', vote_result = $poll_result WHERE vote_option_id = $option_id AND vote_id = $poll_id";
$poll_option_id++;
if ($delete_option_sql != '')
$sql = "DELETE FROM " . VOTE_RESULTS_TABLE . "
WHERE vote_option_id IN ($delete_option_sql)
message_die(GENERAL_ERROR, 'Error deleting pruned poll options', '', __LINE__, __FILE__, $sql);
$cash_message = $GLOBALS['cm_posting']->update_post($mode, $post_data, $forum_id, $topic_id, $post_id, $topic_type, $bbcode_uid, $post_username, $post_message);
$meta = '<meta http-equiv="refresh" content="3;url=' . append_sid("viewtopic.$phpEx?" . POST_POST_URL . "=" . $post_id) . '#' . $post_id . '">';
$message = $lang['Stored'] . '<br />' . $cash_message. '<br /><br />' . sprintf($lang['Click_view_message'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_POST_URL . "=" . $post_id) . '#' . $post_id . '">', '</a>') . '<br /><br />' . sprintf($lang['Click_return_forum'], '<a href="' . append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id") . '">', '</a>');
return false;
// Update post stats and details
function update_post_stats(&$mode, &$post_data, &$forum_id, &$topic_id, &$post_id, &$user_id)
global $db;
$sign = ($mode == 'delete') ? '- 1' : '+ 1';
$forum_update_sql = "forum_posts = forum_posts $sign";
$topic_update_sql = '';
if ($mode == 'delete')
if ($post_data['last_post'])
if ($post_data['first_post'])
$forum_update_sql .= ', forum_topics = forum_topics - 1';
$topic_update_sql .= 'topic_replies = topic_replies - 1';
$sql = "SELECT MAX(post_id) AS last_post_id
message_die(GENERAL_ERROR, 'Error in deleting post', '', __LINE__, __FILE__, $sql);
$topic_update_sql .= ', topic_last_post_id = ' . $row['last_post_id'];
if ($post_data['last_topic'])
WHERE forum_id = $forum_id";
$forum_update_sql .= ($row['last_post_id']) ? ', forum_last_post_id = ' . $row['last_post_id'] : ', forum_last_post_id = 0';
else if ($post_data['first_post'])
$sql = "SELECT MIN(post_id) AS first_post_id
$topic_update_sql .= 'topic_replies = topic_replies - 1, topic_first_post_id = ' . $row['first_post_id'];
else if ($mode != 'poll_delete')
$forum_update_sql .= ", forum_last_post_id = $post_id" . (($mode == 'newtopic') ? ", forum_topics = forum_topics $sign" : "");
$topic_update_sql = "topic_last_post_id = $post_id" . (($mode == 'reply') ? ", topic_replies = topic_replies $sign" : ", topic_first_post_id = $post_id");
$topic_update_sql .= 'topic_vote = 0';
$sql = "UPDATE " . FORUMS_TABLE . " SET
$forum_update_sql
if ($topic_update_sql != '')
$sql = "UPDATE " . TOPICS_TABLE . " SET
$topic_update_sql
SET user_posts = user_posts $sign
WHERE user_id = $user_id";
if (!$db->sql_query($sql, END_TRANSACTION))
return;
// Delete a post/poll
function delete_post($mode, &$post_data, &$message, &$meta, &$forum_id, &$topic_id, &$post_id, &$poll_id)
$GLOBALS['cm_posting']->update_delete($mode, $post_data, $forum_id, $topic_id, $post_id);
$sql = "DELETE FROM " . POSTS_TABLE . "
$sql = "DELETE FROM " . POSTS_TEXT_TABLE . "
$sql = "DELETE FROM " . TOPICS_TABLE . "
OR topic_moved_id = $topic_id";
$sql = "DELETE FROM " . TOPICS_WATCH_TABLE . "
if ($mode == 'poll_delete' || ($mode == 'delete' && $post_data['first_post'] && $post_data['last_post']) && $post_data['has_poll'] && $post_data['edit_poll'])
$sql = "DELETE FROM " . VOTE_DESC_TABLE . "
message_die(GENERAL_ERROR, 'Error in deleting poll', '', __LINE__, __FILE__, $sql);
WHERE vote_id = $poll_id";
$sql = "DELETE FROM " . VOTE_USERS_TABLE . "
if ($mode == 'delete' && $post_data['first_post'] && $post_data['last_post'])
$meta = '<meta http-equiv="refresh" content="3;url=' . append_sid("viewforum.$phpEx?" . POST_FORUM_URL . '=' . $forum_id) . '">';
$message = $lang['Deleted'];
$meta = '<meta http-equiv="refresh" content="3;url=' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . '=' . $topic_id) . '">';
$message = (($mode == 'poll_delete') ? $lang['Poll_delete'] : $lang['Deleted']) . '<br /><br />' . sprintf($lang['Click_return_topic'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id") . '">', '</a>');
$message .= '<br /><br />' . sprintf($lang['Click_return_forum'], '<a href="' . append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id") . '">', '</a>');
return;
// Handle user notification on new post
function user_notification($mode, &$post_data, &$topic_title, &$forum_id, &$topic_id, &$post_id, &$notify_user)
$delete_sql = (!$post_data['first_post'] && !$post_data['last_post']) ? " AND user_id = " . $userdata['user_id'] : '';
$sql = "DELETE FROM " . TOPICS_WATCH_TABLE . " WHERE topic_id = $topic_id" . $delete_sql;
message_die(GENERAL_ERROR, 'Could not change topic notify data', '', __LINE__, __FILE__, $sql);
if ($mode == 'reply')
$sql = "SELECT ban_userid
FROM " . BANLIST_TABLE;
message_die(GENERAL_ERROR, 'Could not obtain banlist', '', __LINE__, __FILE__, $sql);
$user_id_sql = '';
if (isset($row['ban_userid']) && !empty($row['ban_userid']))
$user_id_sql .= ', ' . $row['ban_userid'];
$sql = "SELECT u.user_id, u.user_email, u.user_lang
FROM " . TOPICS_WATCH_TABLE . " tw, " . USERS_TABLE . " u
WHERE tw.topic_id = $topic_id
AND tw.user_id NOT IN (" . $userdata['user_id'] . ", " . ANONYMOUS . $user_id_sql . ")
AND tw.notify_status = " . TOPIC_WATCH_UN_NOTIFIED . "
AND u.user_id = tw.user_id";
message_die(GENERAL_ERROR, 'Could not obtain list of topic watchers', '', __LINE__, __FILE__, $sql);
$update_watched_sql = '';
$bcc_list_ary = array();
// Sixty second limit
@set_time_limit(60);
do
if ($row['user_email'] != '')
$bcc_list_ary[$row['user_lang']][] = $row['user_email'];
$update_watched_sql .= ($update_watched_sql != '') ? ', ' . $row['user_id'] : $row['user_id'];
while ($row = $db->sql_fetchrow($result));
\n
// Let's do some checking to make sure that mass mail functions
// are working in win32 versions of php.
if (preg_match('/[c-z]:\\\\\.*/i', getenv('PATH')) && !$board_config['smtp_delivery'])
$ini_val = (@phpversion() >= '4.0.0') ? 'ini_get' : 'get_cfg_var';
// We are running on windows, force delivery to use our smtp functions
// since php's are broken by default
$board_config['smtp_delivery'] = 1;
$board_config['smtp_host'] = @$ini_val('SMTP');
if (sizeof($bcc_list_ary))
include($phpbb_root_path . 'includes/emailer.'.$phpEx);
$emailer = new emailer($board_config['smtp_delivery']);
$script_name = preg_replace('/^\/?(.*?)\/?$/', '\1', trim($board_config['script_path']));
$script_name = ($script_name != '') ? $script_name . '/viewtopic.'.$phpEx : 'viewtopic.'.$phpEx;
$server_name = trim($board_config['server_name']);
$server_protocol = ($board_config['cookie_secure']) ? 'https://' : 'http://';
$server_port = ($board_config['server_port'] <> 80) ? ':' . trim($board_config['server_port']) . '/' : '/';
$orig_word = array();
$replacement_word = array();
obtain_word_list($orig_word, $replacement_word);
$emailer->from($board_config['board_email']);
$emailer->replyto($board_config['board_email']);
$topic_title = (count($orig_word)) ? preg_replace($orig_word, $replacement_word, unprepare_message($topic_title)) : unprepare_message($topic_title);
@reset($bcc_list_ary);
while (list($user_lang, $bcc_list) = each($bcc_list_ary))
$emailer->use_template('topic_notify', $user_lang);
for ($i = 0; $i < count($bcc_list); $i++)
$emailer->bcc($bcc_list[$i]);
// The Topic_reply_notification lang string below will be used
// if for some reason the mail template subject cannot be read
// ... note it will not necessarily be in the posters own language!
$emailer->set_subject($lang['Topic_reply_notification']);
// This is a nasty kludge to remove the username var ... till (if?)
// translators update their templates
$emailer->msg = preg_replace('#[ ]?{USERNAME}#', '', $emailer->msg);
$emailer->assign_vars(array(
'EMAIL_SIG' => (!empty($board_config['board_email_sig'])) ? str_replace('<br />', "
" . $board_config['board_email_sig']) : '',
'SITENAME' => $board_config['sitename'],
'TOPIC_TITLE' => $topic_title,
'U_TOPIC' => $server_protocol . $server_name . $server_port . $script_name . '?' . POST_POST_URL . "=$post_id#$post_id",
'U_STOP_WATCHING_TOPIC' => $server_protocol . $server_name . $server_port . $script_name . '?' . POST_TOPIC_URL . "=$topic_id&unwatch=topic")
$emailer->send();
$emailer->reset();
$db->sql_freeresult($result);
if ($update_watched_sql != '')
$sql = "UPDATE " . TOPICS_WATCH_TABLE . "
SET notify_status = " . TOPIC_WATCH_NOTIFIED . "
AND user_id IN ($update_watched_sql)";
$db->sql_query($sql);
$sql = "SELECT topic_id
AND user_id = " . $userdata['user_id'];
message_die(GENERAL_ERROR, 'Could not obtain topic watch information', '', __LINE__, __FILE__, $sql);
if (!$notify_user && !empty($row['topic_id']))
message_die(GENERAL_ERROR, 'Could not delete topic watch information', '', __LINE__, __FILE__, $sql);
else if ($notify_user && empty($row['topic_id']))
$sql = "INSERT INTO " . TOPICS_WATCH_TABLE . " (user_id, topic_id, notify_status)
VALUES (" . $userdata['user_id'] . ", $topic_id, 0)";
message_die(GENERAL_ERROR, 'Could not insert topic watch information', '', __LINE__, __FILE__, $sql);
// Fill smiley templates (or just the variables) with smileys
// Either in a window or inline
function generate_smilies($mode, $page_id)
global $db, $board_config, $template, $lang, $images, $theme, $phpEx, $phpbb_root_path;
global $user_ip, $session_length, $starttime;
global $userdata;
$inline_columns = 4;
$inline_rows = 5;
$window_columns = 8;
if ($mode == 'window')
$userdata = session_pagestart($user_ip, $page_id);
init_userprefs($userdata);
$gen_simple_header = TRUE;
$page_title = $lang['Emoticons'] . " - $topic_title";
'smiliesbody' => 'posting_smilies.tpl')
$sql = "SELECT emoticon, code, smile_url
FROM " . SMILIES_TABLE . "
ORDER BY smilies_id";
$num_smilies = 0;
$rowset = array();
if (empty($rowset[$row['smile_url']]))
$rowset[$row['smile_url']]['code'] = str_replace("'", "\\\'", str_replace('\\\', '\\\\\\\', $row['code']));
$rowset[$row['smile_url']]['emoticon'] = $row['emoticon'];
$num_smilies++;
if ($num_smilies)
$smilies_count = ($mode == 'inline') ? min(19, $num_smilies) : $num_smilies;
$smilies_split_row = ($mode == 'inline') ? $inline_columns - 1 : $window_columns - 1;
$s_colspan = 0;
$row = 0;
$col = 0;
while (list($smile_url, $data) = @each($rowset))
if (!$col)
$template->assign_block_vars('smilies_row', array());
$template->assign_block_vars('smilies_row.smilies_col', array(
'SMILEY_CODE' => $data['code'],
'SMILEY_IMG' => $board_config['smilies_path'] . '/' . $smile_url,
'SMILEY_DESC' => $data['emoticon'])
$s_colspan = max($s_colspan, $col + 1);
if ($col == $smilies_split_row)
if ($mode == 'inline' && $row == $inline_rows - 1)
break;
$col = 0;
$row++;
$col++;
if ($mode == 'inline' && $num_smilies > $inline_rows * $inline_columns)
$template->assign_block_vars('switch_smilies_extra', array());
$template->assign_vars(array(
'L_MORE_SMILIES' => $lang['More_emoticons'],
'U_MORE_SMILIES' => append_sid("posting.$phpEx?mode=smilies"))
'L_EMOTICONS' => $lang['Emoticons'],
'L_CLOSE_WINDOW' => $lang['Close_window'],
'S_SMILIES_COLSPAN' => $s_colspan)
$template->pparse('smiliesbody');
