[問題] 簡易子分區的問題,我裝不下10次了
hatakok
文章: 46
註冊時間: 2004-09-05 02:09
來自: 地獄的小角落
文章 由 hatakok »
http://phpbb-tw.net/phpbb/viewtopic.php?t=33019
我都卡在 \includes\functions.php 這檔
以下是 簡易子分區MOD 的操作說明
將整個 function make_jumpbox($action , $match_forum_id = 0) 取代為==========
//forum_sub start
function make_jumpbox($action,$match_forum_id=0)
   global $template, $userdata, $lang, $db, $nav_links, $phpEx, $SID,$is_auth;
   $sql="select cat_id,cat_title from ".CATEGORIES_TABLE." order by cat_order  ";
      message_die(GENERAL_ERROR, "Couldn't get list of Categories/Forums", "", __LINE__, __FILE__, $sql);
   $cat_data = array();
      $cat_data[] = $row;
   $db->sql_freeresult($result);
   $sql = "SELECT cat_id,forum_id,forum_name,sort_sub,forum_sub,auth_view from ".FORUMS_TABLE."  ORDER BY cat_id,forum_order";
   $forum_data = array();
   $forum_sub = array();
   $forum_sub2 = array();
      $s="";
      if($row['auth_view'] <= AUTH_REG)
         if($row[forum_sub]==0)
            $forum_data[$row['cat_id']][] = $row;
            if ($row[forum_id] == $match_forum_id)
               $s = " selected=\"selected\"";
            $forum_sub[$row['forum_sub']][] = "add_select('".$row[forum_id]."','".$row[forum_name]."','$s',".($row[sort_sub]+1).");";
            $forum_sub2[$row['forum_sub']]=$row[forum_id];
   $sub_list="add_select('-1','".$lang['Select_forum']."','$s',0);";
   for( $i=0;$i<count($cat_data);$i++)
      $s = "";
      $cat_id=$cat_data[$i][cat_id];
      $sub_list .="add_select('-1','&nbsp;','$s',0);";
      $sub_list .="add_select('-1','".$cat_data[$i][cat_title]."','$s',0);";
      for($j=0;$j<count($forum_data[$cat_id]);$j++)
         $s = "";
         if ($forum_data[$cat_id][$j][forum_id] == $match_forum_id)
         $sub_list .= "add_select('".$forum_data[$cat_id][$j][forum_id]."','".$forum_data[$cat_id][$j][forum_name]."','$s',".($forum_data[$cat_id][$j][sort_sub]+1).");";
         if ( count($forum_sub[$forum_data[$cat_id][$j][forum_id]]) > 0 )
            $sub_list.= implode(' ', $forum_sub[$forum_data[$cat_id][$j][forum_id]]);
            $sub_list.=sub_search($forum_sub2[$forum_data[$cat_id][$j][forum_id]],$forum_sub,$forum_sub2);
      'jumpbox' => 'jumpbox.tpl')
   $template->assign_vars(array(
      'L_GO' => $lang['Go'],
      'L_JUMP_TO' => $lang['Jump_to'],
      'L_SELECT_FORUM' => $lang['Select_forum'],
      'JUMP_NAME'=>POST_FORUM_URL,
      'S_JUMPBOX_SELECT' => $sub_list,
      'S_JUMPBOX_ACTION' => append_sid($action))
   $template->assign_var_from_handle('JUMPBOX', 'jumpbox');
   return;
function sub_search($id,$forum_sub,$forum_sub2)
   if ( count($forum_sub[$id]) > 0 )
      $list= implode(' ', $forum_sub[$id]);
      $list.=sub_search($forum_sub2[$id],$forum_sub,$forum_sub2);
   return $list;
//forum_sub end
我如果取代後,首頁就會錯誤就會出現\r
Fatal error: Call to a member function on a non-object in c:\appserv\www
ivers\includes\functions.php on line 246
如果沒取代就會正常,但是創子分區就會出現以下錯誤
Fatal error: Call to undefined function: sub_search() in c:\appserv\www
ivers\admin\admin_forums.php on line 226
請救救我 :cry:
最後由 hatakok 於 2005-05-13 03:08 編輯,總共編輯了 2 次。
不染天下不染塵 . 半分形蹤半分蹤
聖賢不過籠中影 . 身遊瀟灑文武風
~倉木麻衣~
文章: 1405
註冊時間: 2004-03-21 21:00
文章 由 ~倉木麻衣~ »
搜尋過「function make_jumpbox(」了嗎?
hatakok
文章: 46
來自: 地獄的小角落
文章 由 hatakok »
~倉木麻衣~ 寫:搜尋過「function make_jumpbox」了嗎?
您好
我不懂您的意思耶 ~_~
請問可以說的清楚點嗎?
很抱歉麻煩您了 ^^"
等我解決後我會給您答謝的唷 ^Q^
不染天下不染塵 . 半分形蹤半分蹤
聖賢不過籠中影 . 身遊瀟灑文武風
~倉木麻衣~
文章: 1405
文章 由 ~倉木麻衣~ »
意思就是~答案在搜尋裡~
關鍵字:function make_jumpbox(
勾選符合以上所有關鍵字的資料
顯示模式:主題
hatakok
文章: 46
來自: 地獄的小角落
文章 由 hatakok »
~倉木麻衣~ 寫:意思就是~答案在搜尋裡~
勾選符合以上所有關鍵字的資料
顯示模式:主題
我有找過了
但都沒有我要的答案
不染天下不染塵 . 半分形蹤半分蹤
聖賢不過籠中影 . 身遊瀟灑文武風
hatakok
文章: 46
來自: 地獄的小角落
文章 由 hatakok »
嗯\r
抱歉
我漏看到了重要的地方\r
我為我的疏忽對您致上十二萬分的歉意
也很謝謝您幫我找出來
我先去修改了
謝謝您了
至於謝禮,等我處理好我會再跟您商討
不染天下不染塵 . 半分形蹤半分蹤
聖賢不過籠中影 . 身遊瀟灑文武風
