有不對的地方請見諒
以下是一個 由外界連結提供帳號與密碼,並連接到PhpBB資料庫進行比對,且回傳驗證結果 的一個程式。
假設輸入:
domain.com/login_get.php?user_name=test001&password=test
他會連到PhpBB資料庫,並且進行比對,並回傳一個數值(0-7)。
這程式碼結構本身是沒問題的,如果帳號是「英文」的話,都可以很正常回傳\r
但是如果是「中文」的帳號,就怎麼找都找不到?
因為小弟有另外一套系統,想與現有的PHPBB整合
所以想請教各位大大,有啥米辦法可以讓這個程式碼可以分析中文的帳號呢?
謝謝!
PhpBB版本:2.0.15
MySql: 4.0.7
/* 檔名: login_get.php */
<?php
* please modify the database configuration
$dbhost = "localhost";
$dbuser = "test_user";
$dbpasswd = "test001";
$dbname = "test_db";
$usertable = "phpbb_users";
$username_field = "username";
$password_field = "user_password";
// dbms - database type
// support dbms: mysql , mysql4 , db2, msaccess, mssql-odbc, oracle, postgres7
$dbms = "mysql4";
$phpEx = "php";
$lib_path = "./lib";
* Don't modify the code below unless you know what are you doing.
// Define the output result
$LOGIN_SUCCESS = 0;
$LOGIN_PASSWD_ERROR = 1;
$LOGIN_NICK_EXIST = 2;
$LOGIN_ERROR = 3;
$LOGIN_ERROR_NOUSERID = 4;
$LOGIN_SUCCESS_ADMIN = 5;
$LOGIN_NOT_ALLOW_GUEST = 6;
$LOGIN_USER_BANED = 7;
switch($dbms)
case 'mysql':
include($lib_path . '/mysql.'.$phpEx);
break;
case 'mysql4':
include($lib_path . '/mysql4.'.$phpEx);
break;
case 'postgres':
include($lib_path . '/postgres7.'.$phpEx);
break;
case 'mssql':
include($lib_path . '/mssql.'.$phpEx);
break;
case 'oracle':
include($lib_path . '/oracle.'.$phpEx);
break;
case 'msaccess':
include($lib_path . '/msaccess.'.$phpEx);
break;
case 'mssql-odbc':
include($lib_path . '/mssql-odbc.'.$phpEx);
break;
default:
echo $LOGIN_ERROR;
exit;
// Make the database connection.
$db = new sql_db($dbhost, $dbuser, $dbpasswd, $dbname, false);
if(!$db->db_connect_id)
echo $LOGIN_ERROR;
exit;
$username = isset($HTTP_GET_VARS['username']) ? trim(htmlspecialchars($HTTP_GET_VARS['username'])) : '';
$username = substr(str_replace("\\\'", "'", $username), 0, 25);
$username = str_replace("'", "\\\'", $username);
$password = isset($HTTP_GET_VARS['password']) ? $HTTP_GET_VARS['password'] : '';
//$md5 = isset($HTTP_GET_VARS['md5']) ? $HTTP_GET_VARS['md5'] : '';
$sql = "SELECT " . $username_field ." , ". $password_field . "
FROM " . $usertable . "
WHERE ". $username_field . " = '" . str_replace("\\\'", "''", $username) . "'";
echo $LOGIN_ERROR;
exit;
if( $row = $db->sql_fetchrow($result) )
$db_user_password = $row[$password_field];
if (($password == $db_user_password) || (md5($password) == $db_user_password))
echo $LOGIN_SUCCESS;
exit;
echo $LOGIN_PASSWD_ERROR;
exit;
echo $LOGIN_ERROR_NOUSERID;
exit;
