外掛系統:
global_announcement_1.2.8, i-Commend_Mod_1.0.5
修改完之後上傳上去\r
開啟討論區就出現以下的訊息\r
Failed obtaining forum access control lists
SQL Error : 1054 Unknown column 'a.auth_globalannounce' in 'field list'
SELECT a.forum_id, a.auth_view, a.auth_read, a.auth_post, a.auth_reply, a.auth_edit, a.auth_delete, a.auth_sticky, a.auth_announce, a.auth_vote, a.auth_pollcreate, a.auth_globalannounce, a.auth_attachments, a.auth_download, a.auth_mod FROM phpbb_auth_access a, phpbb_user_group ug WHERE ug.user_id = 2 AND ug.user_pending = 0 AND a.group_id = ug.group_id AND a.forum_id = 1
Line : 165
File : /vhost/ccf.ohbi.net/htdocs/phpBB2/includes/auth.php
現在我又備分回去了
但我真的不知道問題出在哪\r
是否可以請前輩門告知我的問題呢???
下面是我依照只是修改完的檔案內容
[問題] 安裝完全區公告之後的問題
[問題] 安裝完全區公告之後的問題
最後由 carghost 於 2005-06-03 01:42 編輯,總共編輯了 1 次。
架設主機作業系統:Linux(虛擬主機)
上網方式:ADSL
安裝的程式:php + MySql4.X
phpBB2 版本:phpBB2.0.22
phpBB2 連結網址:http://www.topcamry.idv.tw/phpBB
上網方式:ADSL
<?php
* auth.php
* email : support@phpbb.com
* $Id: auth.php,v 1.37.2.5 2004/03/01 16:49:03 psotfx Exp $
$type's accepted (pre-pend with AUTH_):
VIEW, READ, POST, REPLY, EDIT, DELETE, STICKY, ANNOUNCE, VOTE, POLLCREATE
Possible options ($type/forum_id combinations):
* If you include a type and forum_id then a specific lookup will be done and
the single result returned
* If you set type to AUTH_ALL and specify a forum_id an array of all auth types
will be returned
* If you provide a forum_id a specific lookup on that forum will be done
* If you set forum_id to AUTH_LIST_ALL and specify a type an array listing the
results for all forums will be returned
* If you set forum_id to AUTH_LIST_ALL and type to AUTH_ALL a multidimensional
array containing the auth permissions for all types and all forums for that
user is returned
All results are returned as associative arrays, even when a single auth type is
specified.
If available you can send an array (either one or two dimensional) containing the
forum auth levels, this will prevent the auth function having to do its own
lookup
function auth($type, $forum_id, $userdata, $f_access = '')
global $db, $lang;
switch( $type )
case AUTH_ALL:
$a_sql = 'a.auth_view, a.auth_read, a.auth_post, a.auth_reply, a.auth_edit, a.auth_delete, a.auth_sticky, a.auth_announce, a.auth_vote, a.auth_pollcreate, a.auth_globalannounce';
$auth_fields = array('auth_view', 'auth_read', 'auth_post', 'auth_reply', 'auth_edit', 'auth_delete', 'auth_sticky', 'auth_announce', 'auth_vote', 'auth_pollcreate,', 'auth_globalannounce');
break;
case AUTH_VIEW:
$a_sql = 'a.auth_view';
$auth_fields = array('auth_view');
break;
case AUTH_READ:
$a_sql = 'a.auth_read';
$auth_fields = array('auth_read');
break;
case AUTH_POST:
$a_sql = 'a.auth_post';
$auth_fields = array('auth_post');
break;
case AUTH_REPLY:
$a_sql = 'a.auth_reply';
$auth_fields = array('auth_reply');
break;
case AUTH_EDIT:
$a_sql = 'a.auth_edit';
$auth_fields = array('auth_edit');
break;
case AUTH_DELETE:
$a_sql = 'a.auth_delete';
$auth_fields = array('auth_delete');
break;
case AUTH_ANNOUNCE:
$a_sql = 'a.auth_announce';
$auth_fields = array('auth_announce');
break;
case AUTH_STICKY:
$a_sql = 'a.auth_sticky';
$auth_fields = array('auth_sticky');
break;
case AUTH_POLLCREATE:
$a_sql = 'a.auth_pollcreate';
$auth_fields = array('auth_pollcreate');
break;
case AUTH_VOTE:
$a_sql = 'a.auth_vote';
$auth_fields = array('auth_vote');
break;
case AUTH_ATTACH:
break;
// Start add - Global announcement MOD
case AUTH_GLOBALANNOUNCE:
$a_sql = 'a.auth_globalannounce';
$auth_fields = array('auth_globalannounce');
break;
// End add - Global announcement MOD
default:
break;
attach_setup_basic_auth($type, $auth_fields,
$a_sql);
// If f_access has been passed, or auth is needed to return an array of forums
// then we need to pull the auth information on the given forum (or all forums)
if ( empty($f_access) )
$forum_match_sql = ( $forum_id != AUTH_LIST_ALL ) ? "WHERE a.forum_id = $forum_id" : '';
$sql = "SELECT a.forum_id, $a_sql
FROM " . FORUMS_TABLE . " a
$forum_match_sql";
message_die(GENERAL_ERROR, 'Failed obtaining forum access control lists', '', __LINE__, __FILE__, $sql);
$sql_fetchrow = ( $forum_id != AUTH_LIST_ALL ) ? 'sql_fetchrow' : 'sql_fetchrowset';
if ( !($f_access = $db->$sql_fetchrow($result)) )
$db->sql_freeresult($result);
return array();
// If the user isn't logged on then all we need do is check if the forum
// has the type set to ALL, if yes they are good to go, if not then they
// are denied access
$u_access = array();
$forum_match_sql = ( $forum_id != AUTH_LIST_ALL ) ? "AND a.forum_id = $forum_id" : '';
$sql = "SELECT a.forum_id, $a_sql, a.auth_mod
FROM " . AUTH_ACCESS_TABLE . " a, " . USER_GROUP_TABLE . " ug
WHERE ug.user_id = ".$userdata['user_id']. "
$forum_match_sql";
do
if ( $forum_id != AUTH_LIST_ALL)
$u_access[] = $row;
$u_access[$row['forum_id']][] = $row;
while( $row = $db->sql_fetchrow($result) );
$is_admin = ( $userdata['user_level'] == ADMIN && $userdata['session_logged_in'] ) ? TRUE : 0;
$auth_user = array();
for($i = 0; $i < count($auth_fields); $i++)
$key = $auth_fields[$i];
// If the user is logged on and the forum type is either ALL or REG then the user has access
// If the type if ACL, MOD or ADMIN then we need to see if the user has specific permissions
// to do whatever it is they want to do ... to do this we pull relevant information for the
// user (and any groups they belong to)
// Now we compare the users access level against the forums. We assume here that a moderator
// and admin automatically have access to an ACL forum, similarly we assume admins meet an
// auth requirement of MOD
if ( $forum_id != AUTH_LIST_ALL )
$value = $f_access[$key];
switch( $value )
case AUTH_ALL:
$auth_user[$key] = TRUE;
$auth_user[$key . '_type'] = $lang['Auth_Anonymous_Users'];
break;
case AUTH_REG:
$auth_user[$key] = ( $userdata['session_logged_in'] ) ? TRUE : 0;
$auth_user[$key . '_type'] = $lang['Auth_Registered_Users'];
break;
case AUTH_ACL:
$auth_user[$key] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_ACL, $key, $u_access, $is_admin) : 0;
$auth_user[$key . '_type'] = $lang['Auth_Users_granted_access'];
break;
case AUTH_MOD:
$auth_user[$key] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_MOD, 'auth_mod', $u_access, $is_admin) : 0;
$auth_user[$key . '_type'] = $lang['Auth_Moderators'];
break;
case AUTH_ADMIN:
$auth_user[$key] = $is_admin;
$auth_user[$key . '_type'] = $lang['Auth_Administrators'];
break;
default:
$auth_user[$key] = 0;
break;
for($k = 0; $k < count($f_access); $k++)
$value = $f_access[$k][$key];
$f_forum_id = $f_access[$k]['forum_id'];
switch( $value )
case AUTH_ALL:
\n $auth_user[$f_forum_id][$key] = TRUE;
$auth_user[$f_forum_id][$key . '_type'] = $lang['Auth_Anonymous_Users'];
break;
case AUTH_REG:
$auth_user[$f_forum_id][$key] = ( $userdata['session_logged_in'] ) ? TRUE : 0;
$auth_user[$f_forum_id][$key . '_type'] = $lang['Auth_Registered_Users'];
break;
case AUTH_ACL:
$auth_user[$f_forum_id][$key] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_ACL, $key, $u_access[$f_forum_id], $is_admin) : 0;
$auth_user[$f_forum_id][$key . '_type'] = $lang['Auth_Users_granted_access'];
break;
case AUTH_MOD:
$auth_user[$f_forum_id][$key] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_MOD, 'auth_mod', $u_access[$f_forum_id], $is_admin) : 0;
$auth_user[$f_forum_id][$key . '_type'] = $lang['Auth_Moderators'];
break;
case AUTH_ADMIN:
$auth_user[$f_forum_id][$key] = $is_admin;
$auth_user[$f_forum_id][$key . '_type'] = $lang['Auth_Administrators'];
break;
default:
$auth_user[$f_forum_id][$key] = 0;
break;
// Is user a moderator?
$auth_user['auth_mod'] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_MOD, 'auth_mod', $u_access, $is_admin) : 0;
$auth_user[$f_forum_id]['auth_mod'] = ( $userdata['session_logged_in'] ) ? auth_check_user(AUTH_MOD, 'auth_mod', $u_access[$f_forum_id], $is_admin) : 0;
return $auth_user;
function auth_check_user($type, $key, $u_access, $is_admin)
$auth_user = 0;
if ( count($u_access) )
for($j = 0; $j < count($u_access); $j++)
$result = 0;
switch($type)
case AUTH_ACL:
$result = $u_access[$j][$key];
case AUTH_MOD:
$result = $result || $u_access[$j]['auth_mod'];
case AUTH_ADMIN:
$result = $result || $is_admin;
break;
$auth_user = $auth_user || $result;
$auth_user = $is_admin;
return $auth_user;
* auth.php
will be returned
user is returned
specified.
lookup
global $db, $lang;
switch( $type )
case AUTH_ALL:
break;
case AUTH_VIEW:
break;
case AUTH_READ:
break;
case AUTH_POST:
break;
case AUTH_REPLY:
break;
case AUTH_EDIT:
break;
case AUTH_DELETE:
break;
case AUTH_ANNOUNCE:
break;
case AUTH_STICKY:
break;
break;
case AUTH_VOTE:
break;
case AUTH_ATTACH:
break;
break;
default:
break;
$a_sql);
$forum_match_sql";
return array();
$forum_match_sql";
do
$u_access[] = $row;
switch( $value )
case AUTH_ALL:
break;
case AUTH_REG:
break;
case AUTH_ACL:
break;
case AUTH_MOD:
break;
case AUTH_ADMIN:
break;
default:
break;
switch( $value )
case AUTH_ALL:
break;
case AUTH_REG:
break;
case AUTH_ACL:
break;
case AUTH_MOD:
break;
case AUTH_ADMIN:
break;
default:
break;
return $auth_user;
$auth_user = 0;
$result = 0;
switch($type)
case AUTH_ACL:
case AUTH_MOD:
case AUTH_ADMIN:
break;
return $auth_user;
上網方式:ADSL
上網方式:ADSL
Re: [問題] 安裝完全區公告之後的問題
我猜想:carghost 寫:外掛系統:
修改完之後上傳上去\r
開啟討論區就出現以下的訊息\r
您可能沒有做資料庫的更新吧!
以下是外掛的安裝說明部份:
#-----[ COPY ]------------------------------------------------
copy global_announcement_db_update.php to global_announcement_db_update.php
copy root/templates/subSilver/images/folder_global_announce.gif to templates/subSilver/images/folder_global_announce.gif
copy root/templates/subSilver/images/folder_global_announce_new.gif to templates/subSilver/images/folder_global_announce_new.gif
# This MOD need a database update.
# Then, as you must have now copied the global_announcement_db_update.php file
# in your phpBB root directory, run it with your navigator...
# http://www.yourWebSite.xxx/phpbbRootDir ... update.php
# ...and then delete it from the phpBB root directory!!!
# Please, do it NOW! Before editing phpBB files by EM or manually!!!
# Otherwise, you may have an error message during your next
# connection.
感謝心靈大大的解說心靈捕手 寫:我猜想:
您可能沒有做資料庫的更新吧!
以下是外掛的安裝說明部份:#
# connection.
我試了一下之後
卻出現這個問題
錯誤訊息\r
This list is a result of the SQL queries needed for the additional mods in the pre-moded pack
Global Announcement Mod
[Already added] line: 1 , ALTER TABLE phpbb_forums ADD auth_globalannounce TINYINT (2) DEFAULT "3" NOT NULL AFTER auth_announce
[Already added] line: 2 , ALTER TABLE phpbb_auth_access ADD auth_globalannounce TINYINT (1) not null AFTER auth_announce
1.請問我應該還要修改什麼呢???
2.我圖示已經上傳過去,卻依然看不到耶...
上網方式:ADSL
上網方式:ADSL
一般而言, 安裝外掛若需要資料庫的更新, 則必須優先於相關程式的修改;carghost 寫: ------------------------------------
錯誤訊息\r
1.請問我應該還要修改什麼呢???
也就是說, 在修改相關檔案之前, 必須先執行資料庫更新.
如今您算是" 補辦" 資料庫更新的手續,
所以才會出現這個錯誤訊息.
依照我個人的經驗, 您不用太恐慌, 只要下次別再犯, 即可;
而且這個訊息, 也告訴您, 相關的資料表已經更新了.
至於您說" 我圖示已經上傳過去,卻依然看不到耶"
建議您: 檢視該圖片的路徑後, 再做相關的調整即可.
