[問題] 裝了junior_admin後,副管理員開後台Cash Admin出錯
minotaur
文章: 170
註冊時間: 2005-01-05 20:52
文章 minotaur »
裝了junior_admin後,副管理員開後台Cash Admin裡其中的選項出現以下錯誤訊息\r
Fatal error: Cannot redeclare class template in f:\appserv\www\gf-forum\includes\template.php on line 30
但使用系統管理員身分就不會出錯\r
junior_admin下載點
http://www.nivisec.com/downloads/phpbb/junior_admin.zip
junior_admin 外掛修改部分剪貼上都沒錯\r
另外小弟為了支援phpBB 2.0.15 修改了以下內容::
login.php
if( !$userdata['session_logged_in'] || (isset($HTTP_GET_VARS['admin']) && $userdata['session_logged_in'] && ($userdata['user_level'] == ADMIN))
include_once($phpbb_root_path . 'includes/functions_jr_admin.' . $phpEx);
$jr_admin_userdata = jr_admin_get_user_info($userdata['user_id']);
if( !$userdata['session_logged_in'] || (isset($HTTP_GET_VARS['admin']) && $userdata['session_logged_in'] && (!empty($jr_admin_userdata['user_jr_admin']) || $userdata['user_level'] == ADMIN)))
admin/pagestart.php
redirect(append_sid("login.$phpEx?redirect=admin/&admin=1", true));
redirect(append_sid("login.$phpEx?redirect=admin/index.$phpEx&admin=1", true));
# EoM
includes\template.php 之部分內容
class Template { ←第三十行
var $classname = "Template";
// variable that holds all the data we'll be substituting into
// the compiled templates.
// This will end up being a multi-dimensional array like this:
// $this->_tpldata[block.][iteration#][child.][iteration#][child2.][iteration#][variablename] == value
// if it's a root-level variable, it'll be like this:
// $this->_tpldata[.][0][varname] == value
var $_tpldata = array();
// Hash of filenames for each template handle.
var $files = array();
// Root template directory.
var $root = "";
// this will hash handle names to the compiled code for that handle.
var $compiled_code = array();
// This will hold the uncompiled code for that handle.
var $uncompiled_code = array();
* Constructor. Simply sets the root dir.
function Template($root = ".")
$this->set_rootdir($root);
最後由 minotaur 於 2005-07-15 23:39 編輯,總共編輯了 1 次。
minotaur
文章: 170
文章 minotaur »
能再請問這會是哪兒的錯誤嗎
我重裝好幾次了
都還是一樣耶
minotaur
文章: 170
文章 minotaur »
能幫我解決一下嗎
我卡這問題好久了
