[外掛] 還是簡易子分區的問題!!
bradpittbb
文章: 52
註冊時間: 2005-05-27 08:48
[外掛] 還是簡易子分區的問題!!
文章 bradpittbb »
問題一:當我在新增版面時出現如下的錯誤!!
一般錯誤
Couldn't get order number from forums table
SQL Error : 1064 You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 3
SELECT MAX(forum_order) AS max_order FROM phpbb_forums WHERE cat_id =
Line : 429
File : admin_forums.php
問題二:當我在後台新增分區後台有出現!!但前台完全無動靜...
問題三:之前我還有版面時~(我全刪掉想重弄~)閱讀版面時版面配置縮成一半~
僅剩左半部而已~很怪~
因為我之前有裝cash mod222所以我有照前輩的修正~
問題四:又多了一個連控制臺都進不去的錯誤了~~愈補愈大洞...
出現如下的錯誤
Parse error: parse error, unexpected T_STRING in c:\appserv\www\phpbb2\admin\admin_forums.php on line 1148
底下是我的admin_forums原始檔的出現問題的429行開始~勞費各位幫我看一下嘛..好嗎??
			$sql = "SELECT MAX(forum_order) AS max_order
				FROM " . FORUMS_TABLE . "
				WHERE cat_id = " . $c;
				message_die(GENERAL_ERROR, "Couldn't get order number from forums table", "", __LINE__, __FILE__, $sql);
			$max_order = $row['max_order'];
			$next_order = $max_order + 10;
			$sql = "SELECT MAX(forum_id) AS max_id
				FROM " . FORUMS_TABLE;
			$max_id = $row['max_id'];
			$next_id = $max_id + 1;
			// Default permissions of public ::
			$field_sql = "";
			$value_sql = "";
			while( list($field, $value) = each($forum_auth_ary) )
				$field_sql .= ", $field";
				$value_sql .= ", $value";
//forum_sub start
         $forum_set=$HTTP_POST_VARS[POST_CAT_URL];
         if(empty($forum_set))
            message_die(GENERAL_ERROR, "?#93;定錯誤");
            $temp=split(",",$forum_set);
            $c=intval($temp[0]);
            $forum_sub=intval($temp[1]);
            if($forum_sub >0 && intval($HTTP_POST_VARS[POST_FORUM_URL])!= $forum_sub)
               $sort_sub=intval($temp[2])+1;
            }else
               $sort_sub=intval($temp[2]);
//forum_sub end
	// There is no problem having duplicate forum names so we won't check for it.
		$sql = "INSERT INTO " . FORUMS_TABLE . " (forum_id, forum_name, cat_id, forum_desc, forum_order, forum_status,forum_sub,sort_sub, prune_enable, forum_topictypes" . $field_sql . ")
            VALUES ('" . $next_id . "', '" . str_replace("\'", "''", $HTTP_POST_VARS['forumname']) . "', " . $c . ", '" . str_replace("\'", "''", $HTTP_POST_VARS['forumdesc']) . "', $next_order, " . intval($HTTP_POST_VARS['forumstatus']) . ", " .$forum_sub.",".$sort_sub.",". intval($HTTP_POST_VARS['prune_enable']) . ",'".str_replace("\'", "''", $HTTP_POST_VARS['topictypes'])."'".$value_sql . ")";			if( !$result = $db->sql_query($sql) )
				message_die(GENERAL_ERROR, "Couldn't insert row in forums table", "", __LINE__, __FILE__, $sql);
			if( $HTTP_POST_VARS['prune_enable'] )
				if( $HTTP_POST_VARS['prune_days'] == "" || $HTTP_POST_VARS['prune_freq'] == "")
					message_die(GENERAL_MESSAGE, $lang['Set_prune_data']);
				$sql = "INSERT INTO " . PRUNE_TABLE . " (forum_id, prune_days, prune_freq)
					VALUES('" . $next_id . "', " . intval($HTTP_POST_VARS['prune_days']) . ", " . intval($HTTP_POST_VARS['prune_freq']) . ")";
					message_die(GENERAL_ERROR, "Couldn't insert row in prune table", "", __LINE__, __FILE__, $sql);
			$message = $lang['Forums_updated'] . "<br /><br />" . sprintf($lang['Click_return_forumadmin'], "<a href=\"" . append_sid("admin_forums.$phpEx") . "\">", "</a>") . "<br /><br />" . sprintf($lang['Click_return_admin_index'], "<a href=\"" . append_sid("index.$phpEx?pane=right") . "\">", "</a>");
			break;
		case 'modforum':
			// Modify a forum in the DB
			if( isset($HTTP_POST_VARS['prune_enable']))
				if( $HTTP_POST_VARS['prune_enable'] != 1 )
					$HTTP_POST_VARS['prune_enable'] = 0;
			//forum_sub start
            $sql = "select count(forum_sub) as id from " . FORUMS_TABLE . " WHERE forum_sub = " . intval($HTTP_POST_VARS[POST_FORUM_URL]);
            $get_sub_Id = $db->sql_fetchrow($result);
            if($get_sub_Id[id]>0)
               message_die(GENERAL_ERROR, "此版面有其他子版面相連,無法?#93;定成子版面");
            if(intval($HTTP_POST_VARS[POST_FORUM_URL])== $forum_sub)
               $sql = "UPDATE " . FORUMS_TABLE . "
                     SET forum_name = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumname']) . "', forum_desc = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumdesc']) . "', forum_status = " . intval($HTTP_POST_VARS['forumstatus']) . ", prune_enable = " . intval($HTTP_POST_VARS['prune_enable']) . "
                     WHERE forum_id = " . intval($HTTP_POST_VARS[POST_FORUM_URL]);
            }else
               if(intval($temp[1])>0)
               }else
               { \r
                     SET forum_name = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumname']) . "', cat_id = " . $c . ", forum_desc = '" . str_replace("\'", "''", $HTTP_POST_VARS['forumdesc']) . "', forum_status = " . intval($HTTP_POST_VARS['forumstatus']) . ", prune_enable = " . intval($HTTP_POST_VARS['prune_enable']) . "
                     ,forum_sub=".$forum_sub.",sort_sub=".$sort_sub." ,forum_topictypes = '".str_replace("\'", "''", $HTTP_POST_VARS['topictypes'])."'
            message_die(GENERAL_ERROR, "Couldn't update forum information", "", __LINE__, __FILE__, $sql);
//forum_sub end
			if( $HTTP_POST_VARS['prune_enable'] == 1 )
				if( $HTTP_POST_VARS['prune_days'] == "" || $HTTP_POST_VARS['prune_freq'] == "" )
				$sql = "SELECT *
					FROM " . PRUNE_TABLE . "
					message_die(GENERAL_ERROR, "Couldn't get forum Prune Information","",__LINE__, __FILE__, $sql);
				if( $db->sql_numrows($result) > 0 )
					$sql = "UPDATE " . PRUNE_TABLE . "
						SET	prune_days = " . intval($HTTP_POST_VARS['prune_days']) . ",	prune_freq = " . intval($HTTP_POST_VARS['prune_freq']) . "
						VALUES(" . intval($HTTP_POST_VARS[POST_FORUM_URL]) . ", " . intval($HTTP_POST_VARS['prune_days']) . ", " . intval($HTTP_POST_VARS['prune_freq']) . ")";
					message_die(GENERAL_ERROR, "Couldn't Update Forum Prune Information","",__LINE__, __FILE__, $sql);
			break;
		case 'addcat':
			// Create a category in the DB
			if( trim($HTTP_POST_VARS['categoryname']) == '')
				message_die(GENERAL_ERROR, "Can't create a category without a name");
			$sql = "SELECT MAX(cat_order) AS max_order
				FROM " . CATEGORIES_TABLE;
				message_die(GENERAL_ERROR, "Couldn't get order number from categories table", "", __LINE__, __FILE__, $sql);
			$sql = "INSERT INTO " . CATEGORIES_TABLE . " (cat_title, cat_order)
				VALUES ('" . str_replace("\'", "''", $HTTP_POST_VARS['categoryname']) . "', $next_order)";
				message_die(GENERAL_ERROR, "Couldn't insert row in categories table", "", __LINE__, __FILE__, $sql);
			break;
		case 'editcat':
			// Show form to edit a category
			$newmode = 'modcat';
			$buttonvalue = $lang['Update'];
			$cat_id = intval($HTTP_GET_VARS[POST_CAT_URL]);
			$row = get_info('category', $cat_id);
			$cat_title = $row['cat_title'];
				"body" => "admin/category_edit_body.tpl")
			$s_hidden_fields = '<input type="hidden" name="mode" value="' . $newmode . '" /><input type="hidden" name="' . POST_CAT_URL . '" value="' . $cat_id . '" />';
			$template->assign_vars(array(
				'CAT_TITLE' => $cat_title,
				'L_EDIT_CATEGORY' => $lang['Edit_Category'],
				'L_EDIT_CATEGORY_EXPLAIN' => $lang['Edit_Category_explain'],
				'L_CATEGORY' => $lang['Category'],
				'S_HIDDEN_FIELDS' => $s_hidden_fields,
				'S_SUBMIT_VALUE' => $buttonvalue,
				'S_FORUM_ACTION' => append_sid("admin_forums.$phpEx"))
			$template->pparse("body");
			break;
		case 'modcat':
			// Modify a category in the DB
			$sql = "UPDATE " . CATEGORIES_TABLE . "
				SET cat_title = '" . str_replace("\'", "''", $HTTP_POST_VARS['cat_title']) . "'
			break;
		case 'deleteforum':
			// Show form to delete a forum
			$forum_id = intval($HTTP_GET_VARS[POST_FORUM_URL]);
			$select_to = '<select name="to_id">';
			$select_to .= "<option value=\"-1\"$s>" . $lang['Delete_all_posts'] . "</option>
			$select_to .= get_list('forum', $forum_id, 0);
			$select_to .= '</select>';
			$buttonvalue = $lang['Move_and_Delete'];
			$newmode = 'movedelforum';
			$foruminfo = get_info('forum', $forum_id);
			$name = $foruminfo['forum_name'];
				"body" => "admin/forum_delete_body.tpl")
			$s_hidden_fields = '<input type="hidden" name="mode" value="' . $newmode . '" /><input type="hidden" name="from_id" value="' . $forum_id . '" />';
				'NAME' => $name,
				'L_FORUM_DELETE' => $lang['Forum_delete'],
				'L_FORUM_DELETE_EXPLAIN' => $lang['Forum_delete_explain'],
				'L_MOVE_CONTENTS' => $lang['Move_contents'],
				'L_FORUM_NAME' => $lang['Forum_name'],
				"S_HIDDEN_FIELDS" => $s_hidden_fields,
				'S_FORUM_ACTION' => append_sid("admin_forums.$phpEx"),
				'S_SELECT_TO' => $select_to,
				'S_SUBMIT_VALUE' => $buttonvalue)
			break;
		case 'movedelforum':
			// Move or delete a forum in the DB
			$from_id = intval($HTTP_POST_VARS['from_id']);
			$to_id = intval($HTTP_POST_VARS['to_id']);
			$delete_old = intval($HTTP_POST_VARS['delete_old']);
			// Either delete or move all posts in a forum
			if($to_id == -1)
				// Delete polls in this forum
				$sql = "SELECT v.vote_id
					FROM " . VOTE_DESC_TABLE . " v, " . TOPICS_TABLE . " t
					WHERE t.forum_id = $from_id
						AND v.topic_id = t.topic_id";
					message_die(GENERAL_ERROR, "Couldn't obtain list of vote ids", "", __LINE__, __FILE__, $sql);
					$vote_ids = '';
					do
						$vote_ids = (($vote_ids != '') ? ', ' : '') . $row['vote_id'];
					while ($row = $db->sql_fetchrow($result));
					$sql = "DELETE FROM " . VOTE_DESC_TABLE . "
						WHERE vote_id IN ($vote_ids)";
					$db->sql_query($sql);
					$sql = "DELETE FROM " . VOTE_RESULTS_TABLE . "
					$sql = "DELETE FROM " . VOTE_USERS_TABLE . "
				$db->sql_freeresult($result);
				include($phpbb_root_path . "includes/prune.$phpEx");
				prune($from_id, 0, true); // Delete everything from forum
				$sql = "SELECT *
					WHERE forum_id IN ($from_id, $to_id)";
					message_die(GENERAL_ERROR, "Couldn't verify existence of forums", "", __LINE__, __FILE__, $sql);
				if($db->sql_numrows($result) != 2)
					message_die(GENERAL_ERROR, "Ambiguous forum ID's", "", __LINE__, __FILE__);
				$sql = "UPDATE " . TOPICS_TABLE . "
					SET forum_id = $to_id
					WHERE forum_id = $from_id";
					message_die(GENERAL_ERROR, "Couldn't move topics to other forum", "", __LINE__, __FILE__, $sql);
				$sql = "UPDATE " . POSTS_TABLE . "
					message_die(GENERAL_ERROR, "Couldn't move posts to other forum", "", __LINE__, __FILE__, $sql);
				sync('forum', $to_id);
			// Alter Mod level if appropriate - 2.0.4
			$sql = "SELECT ug.user_id
				FROM " . AUTH_ACCESS_TABLE . " a, " . USER_GROUP_TABLE . " ug
				WHERE a.forum_id <> $from_id
					AND a.auth_mod = 1
					AND ug.group_id = a.group_id";
				message_die(GENERAL_ERROR, "Couldn't obtain moderator list", "", __LINE__, __FILE__, $sql);
				$user_ids = '';
				do
					$user_ids .= (($user_ids != '') ? ', ' : '' ) . $row['user_id'];
					WHERE a.forum_id = $from_id
						AND a.auth_mod = 1
						AND ug.user_id NOT IN ($user_ids)";
				if( !$result2 = $db->sql_query($sql) )
				if ($row = $db->sql_fetchrow($result2))
					$user_ids = '';
					do
					while ($row = $db->sql_fetchrow($result2));
						SET user_level = " . USER . "
						WHERE user_id IN ($user_ids)
							AND user_level <> " . ADMIN;
			$db->sql_freeresult($result2);
			$sql = "DELETE FROM " . FORUMS_TABLE . "
				message_die(GENERAL_ERROR, "Couldn't delete forum", "", __LINE__, __FILE__, $sql);
			$sql = "DELETE FROM " . AUTH_ACCESS_TABLE . "
			$sql = "DELETE FROM " . PRUNE_TABLE . "
				message_die(GENERAL_ERROR, "Couldn't delete forum prune information!", "", __LINE__, __FILE__, $sql);
			break;
		case 'deletecat':
			// Show form to delete a category
			$newmode = 'movedelcat';
			$catinfo = get_info('category', $cat_id);
			$name = $catinfo['cat_title'];
			if ($catinfo['number'] == 1)
				$sql = "SELECT count(*) as total
					FROM ". FORUMS_TABLE;
					message_die(GENERAL_ERROR, "Couldn't get Forum count", "", __LINE__, __FILE__, $sql);
				$count = $db->sql_fetchrow($result);
				$count = $count['total'];
				if ($count > 0)
					message_die(GENERAL_ERROR, $lang['Must_delete_forums']);
					$select_to = $lang['Nowhere_to_move'];
				$select_to .= get_list('category', $cat_id, 0);
			$s_hidden_fields = '<input type="hidden" name="mode" value="' . $newmode . '" /><input type="hidden" name="from_id" value="' . $cat_id . '" />';
				'NAME' => $name,
			break;
		case 'movedelcat':
			// Move or delete a category in the DB
			if (!empty($to_id))
				$sql = "SELECT *
					FROM " . CATEGORIES_TABLE . "
					WHERE cat_id IN ($from_id, $to_id)";
					message_die(GENERAL_ERROR, "Couldn't verify existence of categories", "", __LINE__, __FILE__, $sql);
					message_die(GENERAL_ERROR, "Ambiguous category ID's", "", __LINE__, __FILE__);
					SET cat_id = $to_id
					WHERE cat_id = $from_id";
					message_die(GENERAL_ERROR, "Couldn't move forums to other category", "", __LINE__, __FILE__, $sql);
			$sql = "DELETE FROM " . CATEGORIES_TABLE ."
				message_die(GENERAL_ERROR, "Couldn't delete category", "", __LINE__, __FILE__, $sql);
			break;
		case 'forum_order':
			// Change order of forums in the DB
			$move = intval($HTTP_GET_VARS['move']);
			$forum_info = get_info('forum', $forum_id);
			$cat_id = $forum_info['cat_id'];
				SET forum_order = forum_order + $move
				WHERE forum_id = $forum_id";
				message_die(GENERAL_ERROR, "Couldn't change category order", "", __LINE__, __FILE__, $sql);
			renumber_order('forum', $forum_info['cat_id']);
			$show_index = TRUE;
			break;
		case 'cat_order':
			// Change order of categories in the DB
				SET cat_order = cat_order + $move
				WHERE cat_id = $cat_id";
			renumber_order('category');
			$show_index = TRUE;
			break;
		case 'forum_sync':
			sync('forum', intval($HTTP_GET_VARS[POST_FORUM_URL]));
			$show_index = TRUE;
			break;
		default:
			message_die(GENERAL_MESSAGE, $lang['No_mode']);
			break;
	if ($show_index != TRUE)
		include('./page_footer_admin.'.$phpEx);
		exit;
\n// Start page proper
	"body" => "admin/forum_admin_body.tpl")
	'L_FORUM_TITLE' => $lang['Forum_admin'],
	'L_FORUM_EXPLAIN' => $lang['Forum_admin_explain'],
	'L_CREATE_FORUM' => $lang['Create_forum'],
	'L_CREATE_CATEGORY' => $lang['Create_category'],
	'L_EDIT' => $lang['Edit'],
	'L_DELETE' => $lang['Delete'],
	'L_MOVE_UP' => $lang['Move_up'],
	'L_MOVE_DOWN' => $lang['Move_down'],
	'L_RESYNC' => $lang['Resync'])
$sql = "SELECT cat_id, cat_title, cat_order
	ORDER BY cat_order";
if( !$q_categories = $db->sql_query($sql) )
	message_die(GENERAL_ERROR, "Could not query categories list", "", __LINE__, __FILE__, $sql);
if( $total_categories = $db->sql_numrows($q_categories) )
	$category_rows = $db->sql_fetchrowset($q_categories);
	$sql = "SELECT *
		ORDER BY cat_id, forum_order";
	if(!$q_forums = $db->sql_query($sql))
		message_die(GENERAL_ERROR, "Could not query forums information", "", __LINE__, __FILE__, $sql);
	if( $total_forums = $db->sql_numrows($q_forums) )
		$forum_rows = $db->sql_fetchrowset($q_forums);
	// Okay, let's build the index
	$gen_cat = array();
	for($i = 0; $i < $total_categories; $i++)
		$cat_id = $category_rows[$i]['cat_id'];
		$template->assign_block_vars("catrow", array(
			'S_ADD_FORUM_SUBMIT' => "addforum[$cat_id]",
			'S_ADD_FORUM_NAME' => "forumname[$cat_id]",
			'CAT_ID' => $cat_id,
			'CAT_DESC' => $category_rows[$i]['cat_title'],
			'U_CAT_EDIT' => append_sid("admin_forums.$phpEx?mode=editcat&" . POST_CAT_URL . "=$cat_id"),
			'U_CAT_DELETE' => append_sid("admin_forums.$phpEx?mode=deletecat&" . POST_CAT_URL . "=$cat_id"),
			'U_CAT_MOVE_UP' => append_sid("admin_forums.$phpEx?mode=cat_order&move=-15&" . POST_CAT_URL . "=$cat_id"),
			'U_CAT_MOVE_DOWN' => append_sid("admin_forums.$phpEx?mode=cat_order&move=15&" . POST_CAT_URL . "=$cat_id"),
			'U_VIEWCAT' => append_sid($phpbb_root_path."index.$phpEx?" . POST_CAT_URL . "=$cat_id"))
		for($j = 0; $j < $total_forums; $j++)
			$forum_id = $forum_rows[$j]['forum_id'];
			if ($forum_rows[$j]['cat_id'] == $cat_id)
		if($forum_rows[$j]['forum_sub']>0)
               $forum_sub="<br>子版面";
		$template->assign_block_vars("catrow.forumrow",	array(
					'FORUM_NAME' => $forum_rows[$j]['forum_name'],
					'FORUM_DESC' => $forum_rows[$j]['forum_desc'],
					'ROW_COLOR' => $row_color,
					'NUM_TOPICS' => $forum_rows[$j]['forum_topics'],
					'NUM_POSTS' => $forum_rows[$j]['forum_posts'],
					'U_VIEWFORUM' => append_sid($phpbb_root_path."viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id"),
					'U_FORUM_EDIT' => append_sid("admin_forums.$phpEx?mode=editforum&" . POST_FORUM_URL . "=$forum_id"),
					'U_FORUM_DELETE' => append_sid("admin_forums.$phpEx?mode=deleteforum&" . POST_FORUM_URL . "=$forum_id"),
					'U_FORUM_MOVE_UP' => append_sid("admin_forums.$phpEx?mode=forum_order&move=-15&" . POST_FORUM_URL . "=$forum_id"),
					'U_FORUM_MOVE_DOWN' => append_sid("admin_forums.$phpEx?mode=forum_order&move=15&" . POST_FORUM_URL . "=$forum_id"),
'FORUM_SUB' =>$forum_sub,					'U_FORUM_RESYNC' => append_sid("admin_forums.$phpEx?mode=forum_sync&" . POST_FORUM_URL . "=$forum_id"))
			}// if ... forumid == catid
		} // for ... forums
	} // for ... categories
}// if ... total_categories
我的參考連結~
http://phpbb-tw.net/phpbb/viewtopic.php?p=201052#201052
http://phpbb-tw.net/phpbb/viewtopic.php?p=201074#201074
http://phpbb-tw.net/phpbb/viewtopic.php?p=187615#187615
●架設主機作業系統:windows xp home 512 MB RAM
●您的上網方式:hinet ADSL 512/256k 固定ip
●您安裝的程式: php2.0.15 。
●您的 domain(網域名稱) localhost
●您的 phpBB2 連結網址:http://211.20.74.243/phpBB2/index.php
