[外掛] Admin Userlist 2.0.4 ( support Color Groups )
-=Galipa=-
文章: 15
註冊時間: 2005-05-26 16:10
文章 由 -=Galipa=- »
## MOD Title: Admin Userlist
## MOD Author: wGEric < eric@best-dev.com > (Eric Faerber) http://mods.best-dev.com/
## MOD Description: This MOD lets you view all of you members and various information about
##			them in the Admin Control Panel.  From the list, you can perform
##			various actions on multiple users.
## MOD Version: 2.0.4
## Installation Level: Easy
## Installation Time: 10 Minutes
## Files To Edit: language/lang_english/lang_admin.php
## Included Files: admin/admin_userlist.php
##		   templates/subSilver/admin/userlist_body.tpl
##		   templates/subSilver/admin/userlist_group.tpl
## Author Notes:
##	Deleting users cannot be undone!
##	A special thanks to all those who helped test this MOD
##		GPHemsley
##		R45
##	If you wish to use Nivisec's Color Groups mod with this mod, you can install the
##	patch provided:  colorgroups_userlist.mod
## MOD History:
##   2005-10-10 - version 2.0.4
##	- Added support for Nivisec's Color Groups mod (see colorgroups_userlist.mod)
##	- Fixed admin/mod color scheme from 2.0.3 release
##   2005-10-06 - version 2.0.3
##	- Fixed sort function
## 	- Selected sorting option remains highlighted on results page
##	- Prevent setting 0 users from causing error
##	- Deleting group mods fixed
##	- Sorts by newest registration first (by ASC instead of DESC by default)
##	- Names link back to "manage user" instead of "profile" now
##	- Userlist length is set to topics_per_page instead of posts_per_page
##	- Added Select / De-select all buttons
##	- Corrected placement of </Form> code
##	- Added "time" to last activity column
##	- Deleting a member keeps their ID on posts instead of using Anonymous
##	- Spelling correction of "Delete" in userlist delete confirmation
##   2004-07-13 - Versoin 2.0.2
##	- Fixed bugs with adding users to groups
##	- fixed other bugs as well
##   2004-05-24 - Version 2.0.1
##	- Fixed security issues
##	- Made compatible with php 3
##	- Fixed minor bugs
##   2004-05-18 - Version 2.0.0
##      - complete rewrite of code
##	- added ability to add multiple users to a group
##	- changed look, Open/Close Feature
##	- Fixed all known bugs
Download:
http://deathmonkeighs.com/files/admin_userlist_204.zip
個人以為:
這個升級版, 並非原作者 wGEric 所釋出, 應該是其他網友所為.
理由如下:
1. phpbb 官方外掛資料庫裡頭, 只有 2.0.2 版
http://www.phpbb.com/phpBB/viewtopic.php?t=117359
2. 原作者 wGEric 網站所釋出的版本, 也是只有 2.0.2 版
http://mods.best-dev.com/viewforum.php?f=3
http://mods.best-dev.com/viewtopic.php?t=1904
ps.
移動到" 官方外掛討論" 版面.
