參考連結: http://www.mx-system.com/
使用版本: phpBB 2.0.18
網站位置: http://www.mylovelypet.net/
在首頁 http://www.mylovelypet.net/ 中的 "LOG IN" 跟 "WHO IS ONLINE" 還有最上方的 "Portal Home Forum Profile FAQ Search Memberlist Private Messages Log in Register" 都是英文, 沒辦法像 http://www.mylovelypet.net/phpBB2/index.php 中都是中文, 我猜應該是 MX_portal index.php 的問題, 可是不知道從何改起, 還請大家幫忙看一下, 或者有其他的解決辦法呢?
以下是 MX_Portal/index.php 的內容
define('IN_PORTAL', 1);
$mx_root_path = './';
include_once($mx_root_path . 'extension.inc');
include_once($mx_root_path . 'common.'.$phpEx);
// Start session management
mx_init_userprefs($userdata);
$cache_dir = $mx_root_path . 'cache/';
if ( $HTTP_SESSION_VARS['cache_read'] != TRUE && file_exists($cache_dir . 'block_config.xml') )
include_once($mx_root_path . "cache/mx_cache.php"); // file of easy_parser class
read_cache_config();
// End session management
$view_page = FALSE;
// Load default header
$page_id = $mx_request_vars->request('page', MX_TYPE_INT, 1);
$page_row = get_info(PAGE_TABLE, "page_id", $page_id);
$page_title .= $page_row['page_name'];
include($mx_root_path . 'includes/page_header.'.$phpEx);
$is_auth_ary = array();
$is_auth_ary = page_auth(AUTH_VIEW, $userdata, $page_row['auth_view'], $page_row['auth_view_group'] );
if ( ! $is_auth_ary['auth_view'] )
$message = empty($lang['Page_Not_Authorised']) ? "Sorry, but you don't have privilege to access this page." : $lang['Page_Not_Authorised'];
mx_message_die(GENERAL_MESSAGE, $message, "", __LINE__, __FILE__, "");
if ( !empty($HTTP_SESSION_VARS['page_column_' . $page_id]) )
$column_rows = $HTTP_SESSION_VARS['page_column_' . $page_id];
$total_column = count($HTTP_SESSION_VARS['page_column_' . $page_id]);
$sql = "SELECT col.column_id, col.column_title, col.column_order, col.column_size
FROM " . COLUMN_TABLE . " col
WHERE page_id = $page_id
ORDER BY column_order";
if( !$q_column = $db->sql_query($sql) )
mx_message_die(GENERAL_ERROR, "Could not query column list", "", __LINE__, __FILE__, $sql);
if( $total_column = $db->sql_numrows($q_column) )
$column_rows = $db->sql_fetchrowset($q_column);
$HTTP_SESSION_VARS['page_column_' . $page_id] = $column_rows;
if ( !empty($HTTP_SESSION_VARS['page_block_' . $page_id]) )
$block_rows = $HTTP_SESSION_VARS['page_block_' . $page_id];
$total_block = count( $HTTP_SESSION_VARS['page_block_' . $page_id] );
$sql = "SELECT blk.block_id, blk.auth_view_group, blk.auth_edit_group, bct.column_id, module_path, function_file, auth_view
FROM " . COLUMN_BLOCK_TABLE . " bct,
" . BLOCK_TABLE . " blk,
" . FUNCTION_TABLE . " fnc,
" . MODULE_TABLE . " modu
WHERE blk.function_id = fnc.function_id
AND blk.block_id = bct.block_id
AND fnc.module_id = modu.module_id
ORDER BY column_id, block_order";
// AND bct.column_id = " . $column_rows[$column]['column_id'] . "
if( !$q_modules = $db->sql_query($sql) )
mx_message_die(GENERAL_ERROR, "Could not query modules information", "", __LINE__, __FILE__, $sql);
if( $total_block = $db->sql_numrows($q_modules) )
$block_rows = $db->sql_fetchrowset($q_modules);
$HTTP_SESSION_VARS['page_block_' . $page_id] = $block_rows;
ECHO '<table border="0" cellspacing="4" cellpadding="0" width="100%"><tr valign="top">';
for($column = 0; $column < $total_column; $column++)
$block_size = $column_rows[$column]['column_size'];
ECHO '<td width="' . $block_size . '" >';
for($block = 0; $block < $total_block; $block++)
if ( $column_rows[$column]['column_id'] == $block_rows[$block]['column_id'] )
// Find which blocks are visible for this user
$block_id = $block_rows[$block]['block_id'];
$block_row = get_info(BLOCK_TABLE, "block_id", $block_id);
$is_auth_ary = block_auth(AUTH_VIEW, $block_id, $userdata, $block_rows[$block], $block_row['auth_view_group']);
if ( $is_auth_ary['auth_view'] )
$template = new Template($template->root, $board_config, $db);
$module_root_path = $block_rows[$block]['module_path'];
$block_file = $block_rows[$block]['function_file'];
include( $module_root_path . $block_file );
} // for ... modules
ECHO '</td>';
} // for ... column
ECHO '</tr></table>';
include($mx_root_path . 'includes/page_tail.'.$phpEx);
exit;
