安裝Attachment Mod (Version 2.3.14), 發生問題....
snoopytony
文章: 6
註冊時間: 2005-11-20 17:51
文章 由 snoopytony »
安裝了 Attachment Mod (Version 2.3.14) , 進入到"系統管理控制台"(phpBB Administration).... 不能進入:
附加檔案:-> 管理選項  -> 配額限制   -> 幽靈檔案   -> 同步附加檔案
副檔名: -> 特殊類別
版面管理 -> 管理選項   -> 快速刪文
而顯示出:
Parse error: parse error in d:\appserv\www\sharing\includes\functions_admin.php on line 158
_________________
●架設主機作業系統:Windows XP Professional
●上網方式:網上行寬頻
●安裝的程式:Apache + phpBB + MySql+phpMyAdmin
http://religious.no-ip.org:8080/sharing/
檢視 includes\functions_admin.php 的修改是否有誤?
或者將它另存成文字檔後, 再貼出下載路徑.
snoopytony
文章: 6
文章 由 snoopytony »
<?php
* functions_admin.php
* email : support@phpbb.com
* $Id: functions_admin.php,v 1.5.2.5 2005/09/14 19:16:21 acydburn Exp $
// Simple version of jumpbox, just lists authed forums
function make_forum_select($box_name, $ignore_forum = false, $select_forum = '')
global $db, $userdata;
$is_auth_ary = auth(AUTH_READ, AUTH_LIST_ALL, $userdata);
$sql = 'SELECT f.forum_id, f.forum_name
FROM ' . CATEGORIES_TABLE . ' c, ' . FORUMS_TABLE . ' f
WHERE f.cat_id = c.cat_id
ORDER BY c.cat_order, f.forum_order';
message_die(GENERAL_ERROR, 'Couldn not obtain forums information', '', __LINE__, __FILE__, $sql);
$forum_list = '';
if ( $is_auth_ary[$row['forum_id']]['auth_read'] && $ignore_forum != $row['forum_id'] )
$selected = ( $select_forum == $row['forum_id'] ) ? ' selected="selected"' : '';
$forum_list .= '<option value="' . $row['forum_id'] . '"' . $selected .'>' . $row['forum_name'] . '</option>';
$forum_list = ( $forum_list == '' ) ? '<option value="-1">-- ! No Forums ! --</option>' : '<select name="' . $box_name . '">' . $forum_list . '</select>';
return $forum_list;
// Synchronise functions for forums/topics
function sync($type, $id = false)
global $db;
switch($type)
case 'all forums':
$sql = "SELECT forum_id
FROM " . FORUMS_TABLE;
message_die(GENERAL_ERROR, 'Could not get forum IDs', '', __LINE__, __FILE__, $sql);
sync('forum', $row['forum_id']);
break;
case 'all topics':
$sql = "SELECT topic_id
FROM " . TOPICS_TABLE;
message_die(GENERAL_ERROR, 'Could not get topic ID', '', __LINE__, __FILE__, $sql);
sync('topic', $row['topic_id']);
break;
case 'forum':
$sql = "SELECT MAX(post_id) AS last_post, COUNT(post_id) AS total
FROM " . POSTS_TABLE . "
WHERE forum_id = $id";
message_die(GENERAL_ERROR, 'Could not get post ID', '', __LINE__, __FILE__, $sql);
$last_post = ( $row['last_post'] ) ? $row['last_post'] : 0;
$total_posts = ($row['total']) ? $row['total'] : 0;
$last_post = 0;
$total_posts = 0;
$sql = "SELECT COUNT(topic_id) AS total
FROM " . TOPICS_TABLE . "
message_die(GENERAL_ERROR, 'Could not get topic count', '', __LINE__, __FILE__, $sql);
$total_topics = ( $row = $db->sql_fetchrow($result) ) ? ( ( $row['total'] ) ? $row['total'] : 0 ) : 0;
$sql = "UPDATE " . FORUMS_TABLE . "
SET forum_last_post_id = $last_post, forum_posts = $total_posts, forum_topics = $total_topics
if ( !$db->sql_query($sql) )
message_die(GENERAL_ERROR, 'Could not update forum', '', __LINE__, __FILE__, $sql);
break;
case 'topic':
$sql = "SELECT MAX(post_id) AS last_post, MIN(post_id) AS first_post, COUNT(post_id) AS total_posts
WHERE topic_id = $id";
if ($row['total_posts'])
// Correct the details of this topic
$sql = 'UPDATE ' . TOPICS_TABLE . '
SET topic_replies = ' . ($row['total_posts'] - 1) . ', topic_first_post_id = ' . $row['first_post'] . ', topic_last_post_id = ' . $row['last_post'] . "
if (!$db->sql_query($sql))
message_die(GENERAL_ERROR, 'Could not update topic', '', __LINE__, __FILE__, $sql);
attachment_sync_topic($id);
// There are no replies to this topic
// Check if it is a move stub
$sql = 'SELECT topic_moved_id
FROM ' . TOPICS_TABLE . "
if (!$row['topic_moved_id'])
$sql = 'DELETE FROM ' . TOPICS_TABLE . " WHERE topic_id = $id";
message_die(GENERAL_ERROR, 'Could not remove topic', '', __LINE__, __FILE__, $sql);
$db->sql_freeresult($result);
break;
return true;
_________________
●上網方式:網上行寬頻
以下是此外掛關於 includes\functions_admin.php 的修改:
includes/functions_admin.php
# around line 184
			break;
	return true;
#-----[ BEFORE, ADD ]---------------------------------------
就這麼一個步驟, 我實在很納悶您為甚麼會加錯地方? :-?
snoopytony
文章: 6
文章 由 snoopytony »
多謝 "心靈捕手" 的指導..... 因我是一個初哥.... 我安裝attach_mod是靠easymod 去安的.... 所以d來龍去脈都不太懂... 還要跟大家慢慢學習....
原來它將這句放在約157行... 我跟你的指引更正後, 便無問題了.
真的是很多謝你的指點.
_________________
●上網方式:網上行寬頻
