attach mod 2.4.1安裝問題,請各位大大幫下忙(已解決)
duotsang
文章: 9
註冊時間: 2005-10-21 20:11
文章 由 duotsang »
問題外掛:attach mod 2.4.1
使用版本:phpBB 2.0.1.9
Checking attachment mod storage directory:
files/ Directory found, Directory not writeable - please make sure you make it writeable before using the attachment mod
Running :: CREATE TABLE phpbb_attachments_config ( config_name varchar(255) NOT NULL, config_value varchar(255) NOT NULL, PRIMARY KEY (config_name) ) -> COMPLETED
Running :: CREATE TABLE phpbb_forbidden_extensions ( ext_id mediumint(8) UNSIGNED NOT NULL auto_increment, extension varchar(100) NOT NULL, PRIMARY KEY (ext_id) ) -> COMPLETED
Running :: CREATE TABLE phpbb_extension_groups ( group_id mediumint(8) NOT NULL auto_increment, group_name char(20) NOT NULL, cat_id tinyint(2) DEFAULT '0' NOT NULL, allow_group tinyint(1) DEFAULT '0' NOT NULL, download_mode tinyint(1) UNSIGNED DEFAULT '1' NOT NULL, upload_icon varchar(100) DEFAULT '', max_filesize int(20) DEFAULT '0' NOT NULL, forum_permissions varchar(255) default '' NOT NULL, PRIMARY KEY group_id (group_id) ) -> COMPLETED
Running :: CREATE TABLE phpbb_extensions ( ext_id mediumint(8) UNSIGNED NOT NULL auto_increment, group_id mediumint(8) UNSIGNED DEFAULT '0' NOT NULL, extension varchar(100) NOT NULL, comment varchar(100), PRIMARY KEY ext_id (ext_id) ) -> COMPLETED
Running :: CREATE TABLE phpbb_attachments_desc ( attach_id mediumint(8) UNSIGNED NOT NULL auto_increment, physical_filename varchar(255) NOT NULL, real_filename varchar(255) NOT NULL, download_count mediumint(8) UNSIGNED DEFAULT '0' NOT NULL, comment varchar(255), extension varchar(100), mimetype varchar(100), filesize int(20) NOT NULL, filetime int(11) DEFAULT '0' NOT NULL, thumbnail tinyint(1) DEFAULT '0' NOT NULL, PRIMARY KEY (attach_id), KEY filetime (filetime), KEY physical_filename (physical_filename(10)), KEY filesize (filesize) ) -> COMPLETED
Running :: CREATE TABLE phpbb_attachments ( attach_id mediumint(8) UNSIGNED DEFAULT '0' NOT NULL, post_id mediumint(8) UNSIGNED DEFAULT '0' NOT NULL, privmsgs_id mediumint(8) UNSIGNED DEFAULT '0' NOT NULL, user_id_1 mediumint(8) NOT NULL, user_id_2 mediumint(8) NOT NULL, KEY attach_id_post_id (attach_id, post_id), KEY attach_id_privmsgs_id (attach_id, privmsgs_id), KEY post_id (post_id), KEY privmsgs_id (privmsgs_id) ) -> COMPLETED
Running :: CREATE TABLE phpbb_quota_limits ( quota_limit_id mediumint(8) unsigned NOT NULL auto_increment, quota_desc varchar(20) NOT NULL default '', quota_limit bigint(20) unsigned NOT NULL default '0', PRIMARY KEY (quota_limit_id) ) -> COMPLETED
Running :: CREATE TABLE phpbb_attach_quota ( user_id mediumint(8) unsigned NOT NULL default '0', group_id mediumint(8) unsigned NOT NULL default '0', quota_type smallint(2) NOT NULL default '0', quota_limit_id mediumint(8) unsigned NOT NULL default '0', KEY quota_type (quota_type) ) -> COMPLETED
Running :: ALTER TABLE phpbb_forums ADD auth_download TINYINT(2) DEFAULT '0' NOT NULL -> COMPLETED
Running :: ALTER TABLE phpbb_auth_access ADD auth_download TINYINT(1) DEFAULT '0' NOT NULL -> COMPLETED
Running :: ALTER TABLE phpbb_posts ADD post_attachment TINYINT(1) DEFAULT '0' NOT NULL -> COMPLETED
Running :: ALTER TABLE phpbb_topics ADD topic_attachment TINYINT(1) DEFAULT '0' NOT NULL -> COMPLETED
Running :: ALTER TABLE phpbb_privmsgs ADD privmsgs_attachment TINYINT(1) DEFAULT '0' NOT NULL -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('upload_dir','files') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('upload_img','images/icon_clip.gif') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('topic_icon','images/icon_clip.gif') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('display_order','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('max_filesize','262144') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('attachment_quota','52428800') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('max_filesize_pm','262144') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('max_attachments','3') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('max_attachments_pm','1') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('disable_mod','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('allow_pm_attach','1') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('attachment_topic_review','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('allow_ftp_upload','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('show_apcp','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('attach_version','2.4.1') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('default_upload_quota', '0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('default_pm_quota', '0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('ftp_server','') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('ftp_path','') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('download_path','') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('ftp_user','') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('ftp_pass','') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('ftp_pasv_mode','1') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_display_inlined','1') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_max_width','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_max_height','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_link_width','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_link_height','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_create_thumbnail','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_min_thumb_filesize','12000') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('img_imagick', '') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('use_gd2','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('wma_autoplay','0') -> COMPLETED
Running :: INSERT INTO phpbb_attachments_config (config_name, config_value) VALUES ('flash_autoplay','0') -> COMPLETED
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (1,'php') -> COMPLETED
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (2,'php3') -> COMPLETED
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (3,'php4') -> COMPLETED
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (4,'phtml') -> COMPLETED
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (5,'pl') -> COMPLETED
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (6,'asp') -> COMPLETED
Running :: INSERT INTO phpbb_forbidden_extensions (ext_id, extension) VALUES (7,'cgi') -> COMPLETED
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (1,'Images',1,1,1,'',0,'') -> COMPLETED
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (2,'Archives',0,1,1,'',0,'') -> COMPLETED
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (3,'Plain Text',0,0,1,'',0,'') -> COMPLETED
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (4,'Documents',0,0,1,'',0,'') -> COMPLETED
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (5,'Real Media',0,0,2,'',0,'') -> COMPLETED
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (6,'Streams',2,0,1,'',0,'') -> COMPLETED
Running :: INSERT INTO phpbb_extension_groups (group_id, group_name, cat_id, allow_group, download_mode, upload_icon, max_filesize, forum_permissions) VALUES (7,'Flash Files',3,0,1,'',0,'') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (1, 1,'gif', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (2, 1,'png', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (3, 1,'jpeg', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (4, 1,'jpg', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (5, 1,'tif', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (6, 1,'tga', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (7, 2,'gtar', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (8, 2,'gz', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (9, 2,'tar', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (10, 2,'zip', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (11, 2,'rar', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (12, 2,'ace', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (13, 3,'txt', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (14, 3,'c', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (15, 3,'h', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (16, 3,'cpp', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (17, 3,'hpp', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (18, 3,'diz', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (19, 4,'xls', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (20, 4,'doc', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (21, 4,'dot', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (22, 4,'pdf', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (23, 4,'ai', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (24, 4,'ps', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (25, 4,'ppt', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (26, 5,'rm', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (27, 6,'wma', '') -> COMPLETED
Running :: INSERT INTO phpbb_extensions (ext_id, group_id, extension, comment) VALUES (28, 7,'swf', '') -> COMPLETED
Running :: INSERT INTO phpbb_quota_limits (quota_limit_id, quota_desc, quota_limit) VALUES (1, 'Low', 262144) -> COMPLETED
Running :: INSERT INTO phpbb_quota_limits (quota_limit_id, quota_desc, quota_limit) VALUES (2, 'Medium', 2097152) -> COMPLETED
Running :: INSERT INTO phpbb_quota_limits (quota_limit_id, quota_desc, quota_limit) VALUES (3, 'High', 5242880) -> COMPLETED
COMPLETE!
Attachment Mod Tables generated successfully.
NOW REMOVE THE INSTALL AND CONTRIB DIRECTORIES
之後我delete左install同contrib
返回個website,開新的topic時無顯示上傳檔案~
請各位大大幫下手,好急的,唔該
最後由 duotsang 於 2006-01-28 18:39 編輯,總共編輯了 1 次。
cecilng
文章: 5
註冊時間: 2005-03-08 01:49
文章 由 cecilng »
你有冇chmod呀?
To duotsang:
您貼的訊息, 只是表示您已經執行資料庫的更新;
我猜想, 您應該尚未進行必要的檔案修改.
如果您是用全新的論壇, 安裝此外掛的話,
那麼請參考這裡:
http://phpbb-tw.net/phpbb/viewtopic.php?p=225068#225068
否則, 必須要參考安裝說明( docs/install.txt), 手動進行必要的檔案修改.
域域仔
文章: 42
註冊時間: 2003-05-20 20:26
文章 由 域域仔 »
心靈捕手 寫:To duotsang:
我認為他是沒安Pre-mod file.....我之前都好像有這經驗........應該是缺了這步~~
duotsang
文章: 9
文章 由 duotsang »
我有裝pre-modified file,但是顯示唔到\r
我個forum:http://www.guppyworld.net/phpBB2
thx,唔該各位大大
duotsang 寫:我有裝pre-modified file,但是顯示唔到\r
thx,唔該各位大大
1. 提供測試用帳號與密碼;
2. 將底下檔案打包後, 貼出下載路徑:
posting.php
tempkates/subSilver/posting_body.tpl
duotsang
文章: 9
文章 由 duotsang »
多謝您,心靈大大同其他大大們
login:text
password:text
posting.php
http://www.sendspace.com/file/1524ip
posting_body.tpl
http://www.sendspace.com/file/d2mrxs
duotsang 寫:多謝您,心靈大大同其他大大們
login:text
password:text
posting.php
posting_body.tpl
上傳的檔案裡頭\r
posting.php 有修改\r
posting_body.tpl 並無修改
以下的修改, 提供您參考: ( 安裝說明部份擷取)
templates/subSilver/posting_body.tpl
# around line 258
<form action="{S_POST_ACTION}" method="post" name="post" onsubmit="return checkForm(this)">
#-----[ REPLACE WITH ]---------------------------------------
<form action="{S_POST_ACTION}" method="post" name="post" onsubmit="return checkForm(this)" {S_FORM_ENCTYPE}>
# around line 462
	{POLLBOX}
#-----[ BEFORE, ADD ]---------------------------------------
	{ATTACHBOX}
您既然說" 有裝pre-modified file",
那麼我猜想, 是關於風格檔的上傳或修改有問題.
不過, 您的論壇是使用預設風格 subSilver,
照理說, 是不容易出錯的啊! :-?
duotsang
文章: 9
文章 由 duotsang »
心靈大大,我照你叫我改的,我都改了,但是都無改變
我想問我的forum的情況多唔多人會係咁??
