Arthur Liao
- 星球普通子民
- 文章: 10
- 註冊時間: 2005-09-14 11:18
文章
由 Arthur Liao »
[推薦外掛] MultiVote_Mod (複選) (Update 1.4.2)
裝完之後,幾個選項一直出不來,感覺很詭異,最後改了這兩個地方,終於顯現出來。
$lang['Max_vote'] = '最大投票數';
$lang['Max_vote_explain'] = '<br>[ 輸入 1 或是空白, 表示只允許一個選擇. ]';
$lang['Max_voting_1_explain'] = '您最多只可以選擇 ';
$lang['Max_voting_2_explain'] = ' 個答案';
$lang['Max_voting_3_explain'] = '(超過限制的選擇, 將被忽略.)';
$lang['Vhide'] = '隱藏';
$lang['Hide_vote'] = '投票結果';
$lang['Tothide_vote'] = '總投票數';
$lang['Hide_vote_explain'] = '<br>[ 隱藏, 直到投票截止. ]';
#-----[ REPLACE WITH ]---------------------------------------------
$lang['Max_vote_explain'] = '<br />[ 輸入 1 或是空白, 表示只允許一個選擇. ]';
$lang['Hide_vote_explain'] = '<br />[ 隱藏, 直到投票截止. ]';
- 默默耕耘的老師
- 文章: 8540
- 註冊時間: 2004-04-30 01:54
- 來自: Taiwan
文章
由 心靈捕手 »
Arthur Liao 寫:[推薦外掛] MultiVote_Mod (複選) (Update 1.4.2)
外掛中文化, 僅提供您參考;
您可以依個人喜惡, 自行增減, 修改.
參考使用時, 比對一下原文 (程式碼).
language/lang_english/lang_main.php
$lang['Total_votes'] = 'Total Votes';
$lang['Total_votes'] = 'Total Votes : ';
$lang['Voted_show'] = 'Voted : '; // it means : users that voted (the number of voters will follow)
$lang['Results_after'] = 'Results will be visible after the poll expires';
$lang['Poll_expires'] = 'Poll expires in ';
$lang['Poll_expiredyes'] = '- Poll expired -';
$lang['Poll_noexpire'] = 'This poll does not expire';
$lang['Minutes'] = 'Minutes';
$lang['Delete_poll'] = 'Delete Poll';
#-----[ AFTER, ADD ]---------------------------------------------
$lang['Max_vote'] = 'Maximum selections';
$lang['Max_vote_explain'] = '[ Enter 1 or leave blank to allow only one selection ]';
$lang['Max_voting_1_explain'] = 'Please select only ';
$lang['Max_voting_2_explain'] = ' answers';
$lang['Max_voting_3_explain'] = ' (selections above limit will be ignored)';
$lang['Vhide'] = 'Hide';
$lang['Hide_vote'] = 'Results';
$lang['Tothide_vote'] = 'Sum of votes';
$lang['Hide_vote_explain'] = '[ Hide until poll expires ]';
Source: MultiVote_Mod_v.1.4.2.txt
Arthur Liao
- 星球普通子民
- 文章: 10
文章
由 Arthur Liao »
抱歉.....我只是因為依照您的MOD去修正,發現其中<br>在其中無法work,
需改為<br/>才能顯現出正常畫面。
所以才會發出這篇,讓同樣遇到問題的人,可以做參考。
若有得罪之處,敬請見諒。
