裝完後,你可以任意點任何一位會員的名字進去看到他們的個人資料
就在個人資料裡面,在名字旁邊就會有個連結,可以讓論壇管理人員看到會員更詳細的設定!
## Mod Title: User Administration Link on Profile
## Mod Version: 1.0.0
## Author: Matthijs <matthijs@beryllium.net>
## Description: This will add a link to the User Administration
## of the Administration Panel on the 'view
## profile' page. Will only display the link when
## user is ADMIN.
## Installation Level: Easy
## Installation Time: 3 Minutes
## Files To Edit: includes/usercp_viewprofile.php,
## language/lang_english/lang_main.php,
## templates/subSilver/profile_view_body.tpl
## Included Files: N/A
## Security Disclaimer: This MOD Cannot Be Posted To Or Added At Any Non-Official phpBB Sites
## Author Note:
## You should change all your languages and themes if you use others
## then English and subSilver.
$page_title = $lang['Viewing_profile'];
if( $userdata['user_level'] == ADMIN )
$template->assign_vars(array(
'L_USER_ADMIN' => sprintf($lang['User_admin_for'], $profiledata['username']),
'U_ADMIN_PROFILE' => append_sid("admin/admin_users.$phpEx?mode=edit&" . POST_USERS_URL . '=' . $profiledata['user_id']))
$template->assign_block_vars("switch_user_admin", array());
templates/fiapple/profile_view_body.tpl
<td class="catLeft" width="60%" align="center"><b><span class="gen">{L_ABOUT_USER}</span></b>
#-----[ AFTER,ADD]------------------------------------------
<!-- BEGIN switch_user_admin -->
<span class="gen"> (<a target="_admin" href="{U_ADMIN_PROFILE}" class="gen">{L_USER_ADMIN}</a>)</span>
<!-- END switch_user_admin -->
<td class="catRight" width="60%"><b><span class="gen">{L_ABOUT_USER}</span></b></td>
<td class="catLeft" width="60%"><b><span class="gen">{L_ABOUT_USER}</span></b>
</td>
languages/lang_chinese_traditional_taiwan/lang_main.php
$lang['About_user'] = '關於 %s'; // %s is username
$lang['User_admin_for'] = " %s的詳細設定管理資料"; // %s is username
# EoM我只是把fiapple米掊的修改方式給弄了出來!
