[外掛][管理模組]會員權限控制及資料管理連結
godbless
文章: 647
註冊時間: 2002-05-17 06:02
來自: 台北市南京東路4段
文章 由 godbless »
這個模組是將前述的會員管理連結及會員權限控制的統合整理版本\r
includes/usercp_viewprofile.php
$page_title = $lang['Viewing_profile'];
// User Administration Link on Profile
if( $userdata['user_level'] == ADMIN )
   $template->assign_vars(array(
      'L_USER_ADMIN' => sprintf($lang['User_admin_for'], $profiledata['username']),
      'U_ADMIN_PROFILE' => append_sid("admin/admin_users.$phpEx?mode=edit&" . POST_USERS_URL . '=' . $profiledata['user_id']))
   $template->assign_block_vars("switch_user_admin", array());
// The member jurisdiction management links
$template->assign_block_vars("switch_user_auth", array());
'L_USER_AUTH' => $lang['User_auth'],
'U_AUTH' => append_sid("admin/admin_ug_auth.$phpEx?mode=user&u=" . $profiledata['user_id']))
templates/fiapple/profile_view_body.tpl
   <td class="catLeft" width="60%" align="center"><b><span class="gen">{L_ABOUT_USER}</span></b>
<span class="gen"><a target="_admin" href="{U_ADMIN_PROFILE}" class="gen">{L_USER_ADMIN}</a><span class="gen"><a target="_admin" href="{U_AUTH}" class="gen">{L_USER_AUTH}</a></span></td>
templates/subSilver/profile_view_body.tpl
   <td class="catRight" width="60%"><b><span class="gen">{L_ABOUT_USER}</span></b>
<span class="gen"> <a target="_admin" href="{U_ADMIN_PROFILE}" class="gen">{L_USER_ADMIN}</a><span class="gen"><a href="{U_AUTH}" target="_autn">{L_USER_AUTH}</a></span></td>
languages/lang_chinese_traditional_taiwan/lang_main.php
$lang['About_user'] = '關於 %s'; // %s is username
$lang['User_admin_for'] = " %s的設定資料"; // %s is username
$lang['User_auth'] = " %s的權限控制"; // The member jurisdiction management links //%s is username
# EoM
以上資訊來源來自於:
竹貓星球
http://www.animestationun.com/phpbb2/
http://www.animestationun.com/phpbb2/viewtopic.php?t=69
http://www.phpbb.com/mods/downloads/ind ... ages&cat=3
外掛問題區發問格式就在這裡,請務必一定照著格式來~!
你不照著規則來,就算是神也搞不清楚你的問題在哪裡!
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
回到「非官方認證外掛」
