[外掛] pubdl BBcode (EasyMod)
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 由 Mac »
## EasyMod 0.0.7 Compliant
## MOD Title:   pubdl BBcode
## MOD Version:   1.0.0
## MOD Author:   Mac < ycl_6@sinamail.com >
## DEV Date:    March 31, 2003
## MOD Description:   Creates pubdl hyperlink
##         Usage is [pdl=pdl://url]text[/pdl] or pdl://
## Installation Level:  (easy)
## Installation Time:  5-10 Minutes
## Files To Edit:         5
##                   - includes/bbcode.php
##                   - posting.php
##                   - templates/subSilver/bbcode.tpl
##                   - language/lang_english/lang_main.php
##                   - includes/posting_body.tpl
## Included Files:      None
# IMPORTANT: if you are installing manually (without EasyMod) you MUST first
#       install the Multi Quick BBCode Mod (included).
#-----[ OPEN ]--------------------------------
includes/bbcode.php
#-----[ FIND ]---------------------------------
   $bbcode_tpl['url4'] = str_replace('{DESCRIPTION}', '\\\5', $bbcode_tpl['url4']);
#-----[ AFTER, ADD ]-------------------------------
	// The URL replacements codes for the pubdl Links - pubdl MOD
	$bbcode_tpl['pdl'] = str_replace('{URL}', '\\\1', $bbcode_tpl['pdl']);
	$bbcode_tpl['pdl'] = str_replace('{DESCRIPTION}', '\\\2', $bbcode_tpl['pdl']);
   $replacements[] = $bbcode_tpl['url4'];
	// [pdl=pdl://...]text[/pdl] code.
	$patterns[13] = "#\[pdl=(pdl://.*?)\](.*?)\[/pdl\]#si";
	$replacements[13] = $bbcode_tpl['pdl'];
   $ret = preg_replace("#([
 ])([a-z0-9\-_.]+?)@([\w\-]+\.([\w\-\.]+\.)*[\w]+)#i", "\\\1<a href=\"mailto:\\\2@\\\3\">\\\2@\\\3</a>", $ret);
	// make the pubdl links clickable - pubdl MOD
 ])(pdl://(.*\+).*\/?)#i", "\\\1pubdl: <a href=\"\\\2\">PUBDL Download Link (Click Here)</a>", $ret);
#-----[ OPEN ]---------------------------------
posting.php
$EMBB_keys = array(''
$EMBB_widths = array(''
$EMBB_values = array(''
#-----[ IN-LINE FIND ]---------------------------------
#-----[ IN-LINE AFTER, ADD ]---------------------------------
,'dl'
,'40'
,'pubdl'
   'L_BBCODE_F_HELP' =>
#-----[ AFTER, ADD ]--------------------------------
	'L_BBCODE_DL_HELP' => $lang['bbcode_dl_help'], // pubdl
## --- NOTE: You will have to make this change to ALL languages that you     ---
## ---       plan to support on your board.  I use "English" as an example   ---
$lang['bbcode_f_help']
#-----[ AFTER, ADD ]---------------------------------
$lang['bbcode_dl_help'] = "pubdl text: [pdl=pdl://url]text[/pdl] (alt+dl)"; // pubdl
<!-- BEGIN right --><img src="{URL}" border="0" align="right" /><!-- END right -->
<!-- BEGIN pdl --><a href="{URL}" target="_blank" class="postlink">{DESCRIPTION}</a><!-- END pdl -->
templates/subSilver/posting_body.tpl
f_help = "{L_BBCODE_F_HELP}";
dl_help = "{L_BBCODE_DL_HELP}";
# NOTE: the actual line to find is MUCH longer, containing all the bbcode tags
bbtags = new Array(
'[url]','[/url]'
,'[pdl]','[/pdl]'
#-----[ SAVE/CLOSE FILES ]---------------------------------
# EoM
只在 2.0.4 上面測試過
使用方法
pdl://FedJMiUsyxIQjISveHNZuv0KrEt+KjUJjknOJjbjKLJPojmaiAkJVtDVhekpGM0hixWU1YHubaQZYkalJ8DYpEJKS0KMNKkU0HIU/
pdl://FKsirIwvg01q/aJNLuyguhbj/Im/6g1uzr/OJk8jhbJUGYFTYF6ijHNJKG7QZZyuBdTq+2UBNloQsPlbPdECSDQYOUn/1rYgOr0/qN3gO7R3RFq87C7==/
[pdl=pdl://FedJMiUsyxIQjISveHNZuv0KrEt+KjUJjknOJjbjKLJPojmaiAkJVtDVhekpGM0hixWU1YHubaQZYkalJ8DYpEJKS0KMNKkU0HIU/]PUBDL Test[/pdl]
pdl://O9IJlESXDFCopOIJHgtyYGuo9jkl987yGUIP+Gvh/LMP6bHIClMkWLDMevvW4nz1N2CSx728MHGdI67RW0pDf0tFUxHVMgcxh0Si4zC42Zcz7NlgilydisHHRW/nYHUinJINKJbilugvbhjkol=/
~Mac
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
來自: MacphpBBMOD
文章 由 Mac »
## DEV Date:    July  01, 2003
## Files To Edit:         5
##                   - posting.php
includes/bbcode.php
posting.php
bbtags = new Array(
'[url]','[/url]'
,'[pdl]','[/pdl]'
#-----[ ACTION: find ]---------------------------------
			<td><span class="genmed">
			  <input type="button" class="button" accesskey="w" name="addbbcode16" value="URL" style="text-decoration: underline; width: 40px" onClick="bbstyle(16)" onMouseOver="helpline('w')" />
			  </span></td>
#-----[ ACTION: add below ]---------------------------------
			  <input type="button" class="button" accesskey="dl" name="addbbcode18" value="pubdl" style="width: 50px" onClick="bbstyle(18)" onMouseOver="helpline('dl')" />
			  </span></td>
					<select name="addbbcode18" onChange="bbfontstyle('[color=' + this.form.addbbcode18.options[this.form.addbbcode18.selectedIndex].value + ']', '[/color]')" onMouseOver="helpline('s')">
#-----[ ACTION: replace with ]---------------------------------
				  	<select name="addbbcode20" onChange="bbfontstyle('[color=' + this.form.addbbcode20.options[this.form.addbbcode20.selectedIndex].value + ']', '[/color]')" onMouseOver="helpline('s')">
					</select>  {L_FONT_SIZE}:<select name="addbbcode20" onChange="bbfontstyle('[size=' + this.form.addbbcode20.options[this.form.addbbcode20.selectedIndex].value + ']', '[/size]')" onMouseOver="helpline('f')">
				      </select>  {L_FONT_SIZE}:<select name="addbbcode22" onChange="bbfontstyle('[size=' + this.form.addbbcode22.options[this.form.addbbcode22.selectedIndex].value + ']', '[/size]')" onMouseOver="helpline('f')">
#-----[ ACTION: save, close, upload ]---------------------------------
# EoM
~Mac
回到「非官方認證外掛」
