[分享]Copy Post to Clipboard +原創
Rickycheng
文章: 49
註冊時間: 2002-09-27 16:41
文章 由 Rickycheng »
found in phpbbhacks.com
## MOD Title: Copy Post to Clipboard (never let the site eat a post)
## MOD Author: cdkrg  < cdkrg@fluencynow.com > www.able2know.com
## MOD Description: Ever have users complain that your forum "ate" their long post?
## This MOD adds a button on the posting page that highlights all
## the text of the post and copies it to the clipboard. If the browser is not compatible
## it displays a different button that simply selects all the text allowing the user
## to copy it more simply. You can see a working example of this at www.able2know.com/forums/
## on those forums there are two forums that allow you to post as a guest (since you are too lazy to register!)
## those forums are the test forum and the forum help. Please don't post junk posts, you can
## see this in action without submitting your post
## MOD Version: 1.0.0
## Installation Level: (easy)
## Installation Time: 1 Minute
## Files To Edit: posting_body.tpl
## Included Files: n/a
## Author Notes:
## This is a simple MOD that has a powerful feature. I don't expect there to be any
## updates or newer versions as it runs perfectly in the first version with no bugs and certainly
## no security holes. If you have installed other MODs like spellcheck you might not want to
## add the extra row from this MOD and simply add the javascript to the row you have already
## created. This is optional and a layout issue. If you like this MOD or have questions about
## it please join my forum at www.able2know.com I can be contacted there.
## You might want to edit the alert message. It contains the URL of the site that I made this for.
## MOD GLOSSARY The following are definitions for actions
## that might be included in this MOD, this MOD might not contain some of the terms defined below.
## COPY- Copy files to a location on the server
## OPEN - Open a specific file.
## FIND - Find a piece of code within the opened file
## REPLACE WITH - Replace a piece of code (whatever we "FIND") with this code
## OR - Replace With the above "REPLACE WITH"... OR... this code
## AFTER, ADD - After a piece of code, add this piece of code
## BEFORE, ADD - Before a piece of code, add this piece of code
## IN-LINE FIND - Find a piece of code within a code line
## IN-LINE AFTER, ADD - After a piece of code in a code line, add this piece of code
## IN-LINE BEFORE, ADD - Before a piece of code in a code line, add this piece of code
templates/subSilver/posting_body.tpl
<!-- END privmsg_extensions -->
<SCRIPT language="JavaScript">
function highlightmetasearch() {
document.post.message.select(); document.post.message.focus();
function copymetasearch() {
highlightmetasearch();
textRange = document.post.message.createTextRange();
textRange.execCommand("RemoveFormat");
textRange.execCommand("Copy");
alert("This post has been copied to your clipboard.
If this post is lost when you submit it you can easily repost it.
Always use this feature before posting! -
www.able2know.com");
</SCRIPT>
      <td colspan="9">
          <span class="smalltext">
    <textarea name="message" rows="15" cols="35" wrap="virtual" style="width:450px" tabindex="3" class="post" onselect="storeCaret(this);" onclick="storeCaret(this);" onkeyup="storeCaret(this);">{MESSAGE}</textarea>
       </span>
           </td>
<tr><td colspan="9" align="right">
     <script language="JavaScript" type="text/javascript">
if ((navigator.appName=="Microsoft Internet Explorer")&&(parseInt(navigator.appVersion)>=4)) {
document.write('<INPUT type="button" class="button" value="COPY TO CLIPBOARD" onClick="copymetasearch();">');
} else {
document.write('<INPUT type="button" class="button" value="HIGHLIGHT TEXT" onClick="highlightmetasearch();">');
</script>
  </td></tr>
# EoM
# if you use Advanced_Quick_Reply_Hack
# must edit 1 file more to make this hack more nice
# this part Hacked by rickycheng
templates/subSilver/quick_reply.tpl
<!-- END user_logged_in -->
</SCRIPT>
<input type='submit' name='post' class='mainoption' value='{L_SUBMIT}'>
} else {
</script>
  </td></tr>
# EoM
中文說明:
在你的論壇,瀏覽文章中增加一個按鈕,點選後會複製文章內容到剪貼簿上。
                                   ~河風
回到「非官方認證外掛」
