[php]<?php
## Mod Title: Prune users
## Mod Version: 1.3.2
## Author: Niels Chr. Denmark < ncr@db9.dk > (Niels Chr. R鷣) HTTP://MODS.DB9.DK
## This mod is for phpBB2!! ver 2.0.3
## Description:
## Admin plug-in that makes it posible to delete users who are inactive/haven posted or like
## Makes it posible to make links for deletion of specific users
## a exampel of how to use this is included with the memberlist
## after this, a delete user button is showen in the meberlist
## If you do not want this "delete user button" in the memberlist, then don't
## do the changes to memberlist.php
## phpBB2 drop-in mod, that checks for unused accounts for X days
## Script only works while logged in as ADMIN, add the days=X as a extra parameter
## e.g. http://www.yourdomain.com/delete_users. ... in&days=10
## will delete all accounts who have never logged in and are older than 10 days
## And zero postes
## e.g. http://www.yourdomain.com/delete_users. ... er&days=10
## will delete all accounts who have never posted and are older than 10 days
## You can also delete specific users
## e.g. http://www.yourdomain.com/delete_users. ... user=Niels
## or http://www.yourdomain.com/delete_users. ... el_user=18
## Will delete a specific user either by name or by id, remember that this is NOT case sensetive
## if the user have posted, then his/her posts will be converted to posted by guest, and the users
## name wil still be showen
## There are NO undo function, and the script will not ask for confirmation, however
## the script will always show the name of the deleted users
## This mod you can customice your self, if you know a litle about SQL, make a new entry in the lang_admin.php (look how the others look)
## then inside the file admin_prune_users.php, is in the top, a "box" where you can fill with your statements
## and in the file delete_users.php, as the same, fill in both files witch the needed SQL command, and the entry is added
## you may sewlect if a notification email are to send out to the deleted user, to do this
## simply toggle the define('NOTIFY_USERS', true); true/false depending on if a notificatin is to be sendt out
## you can find this in the top of the file delete_users.php
## Installation Level: easy
## Installation Time: 1-2 Minutes
## Files To Edit: 2
## memberlist.php
## language/lang_english/lang_admin.php
## Included Files: 4
## delete_users.php
## admin/admin_prune_users.php
## language/lang_english/lang_prune_users.php
## templates/subsilver/admin/prune_users_body.tpl
## History:
## 0.9.0 - initial BETA
## 1.0.0 - initial release phpBB2 ver 2.0.0.
## 1.0.3 - history started, added admin plug-in module
## 1.0.4 - modifyed admin plug-in, to easyely be moded with more options
## 1.0.5 - now includes the RIGTH template file....sorry
## 1.0.6 - and now it also includes the RIGTH admin_prune_users.php....sorry once more
## 1.0.7 - lang['prune'] is already in use, so changed the name to ['Prune_commands']
## 1.1.0 - imporent update, the delete_users.php file have been updated, if you have used previous versions
## and at the same time have used user permissions on deleted user you should manual inspect your auth_access table
## 1.1.1 - changes to lang_admin.php
## 1.1.1 - confirmed for phpBB2 ver 2.0.2, no changes needed
## 1.1.2 - new version of delete_users.php, witch solve a usue about ' in usernames
## 1.3.0 - language file are now sepperated as a plug-in file
## 1.3.1 - now support email notification of deleted users
## 1.3.2 - corrected different details, reported by my user "jtp10181"
## This MOD is released under the GPL License.
## Intellectual Property is retained by the MOD Author(s) listed above
## For Security Purposes, Please Check: http://www.phpbb.com/mods/downloads/ for the
## in our MOD-Database, located at: http://www.phpbb.com/mods/downloads/
## Authors Notes:
## remeber to do the mod to all installed language/templates your board support
?>[/php]
包裹下載: http://mods.db9.dk/viewtopic.php?t=21
中文語系: http://phpbb-tw.net/phpbb/viewtopic.php?t=14115
1.3.2 修正了一些 BUG,希望能夠 "正常" 的刪除自訂時間的用戶了
(我還沒更新,所以不知道在 2.0.4 上這個問題解決了沒有)
~Mac
[外掛] 快速砍人1.3.2
[外掛] 快速砍人1.3.2
最後由 Mac 於 2003-05-13 01:58 編輯,總共編輯了 2 次。
時間正確了,phpbb204確定能用^^
131升級至132~
131升級至132~
memberlist.php
.(($userdata['user_level']==ADMIN)?'<a href="' . append_sid("delete_users.$phpEx?mode=user_id&del_user=$user_id") . '"><img src="' . $images['icon_delpost'] . '" alt="' . $lang['Delete'] . ' '.$username.'" title="' . $lang['Delete'] . ' '.$username.'" border="0" /></a>&':'')
#-----[ REPLACE ]------------------------------------------
a>&':'')
delete_users.php
language/your_lang/lang_prune_users.php
language/your_lang/email/delete_users.tpl
templates/your_temp/admin/prune_users_body.tpl
Do you fear death ?
Do you fear death ?
在 2.0.4 上面可跑
但是時間仍然不準.... @@"
請各位管理員們在刪除超過{規定時間}內未上站的會員 <- 這一點上要小心比對後再執行!!
例:
選擇超過半年未上線的會員 <- 準備刪除的名單 =.=+
經檢查後卻發現,有些人最近才來過,照理應不在名單之中,可是程式卻把他們也列進來了
下刀前要注意,別被會員罵囉...
但是時間仍然不準.... @@"
例:
下刀前要注意,別被會員罵囉...
七點要求:
1. 發問前先搜尋,確定沒有重複後再發表
2. 主題要明確
3. 依照發問格式
4. 禁連續推文
5. 請盡量減少使用地方性語言
七點要求:
2. 主題要明確
3. 依照發問格式
4. 禁連續推文
5. 請盡量減少使用地方性語言
[教學]快速砍人MOD 1.3.2 遇上問題時修正方法
說明 : 快速砍人MOD 1.3.2 遇上問題時修正方法
中文化 : 風笑痴(鐵心論壇)
原發表文章 : 快速砍人1.3.2 by Mac
昨天裝1.3.2, 發現如果你的論壇會員有數千以上, 這個MOD在後台使用時會有各種的問題出現. 到了作者發表頁查看得到以下解決方案 :
1. 解決一次顯示太多會員\r
打開 admin/admin_prune_users.php
尋找 :
這段碼會出現多次, 可自行決定哪個部分要改. 改成 =xxx 就可以, xxx 是數字如200就是一次只顯示200個.
甚至不顯示也可以 :
打開 admin_prune.php
尋找並移除
2. 關掉刪除會員後會發信通知會員的功能, 這會令刪除過程快許多, 也避免了當email server有問題時產生的錯誤.
打開MOD裡的 delete_users.php
尋找\r
替換成
3. 修改每次刪除多少個會員的數量
打開MOD裡的delete_users.php
尋找
替換成
打開MOD裡的 admin_prune_users.php
尋找\r
替換成
註 : 以上兩處這樣設是每次刪800個, 以我的經驗就要調成每次刪200個左右才不會出錯誤頁. 請根據你的情況自行決定.
以上修改若有進一步問題可以參考作者原文
http://mods.db9.dk/viewtopic.php?t=1763
中文化 : 風笑痴(鐵心論壇)
1. 解決一次顯示太多會員\r
尋找 :
$default [0] 甚至不顯示也可以 :
打開 admin_prune.php
尋找並移除
for($i = 0; $i < $user_count; $i++)
$style_color = ($user__list[$i]['user_level'] == ADMIN )?'style="color:#' . $theme['fontcolor3'] . '"':(( $user__list[$i]['user_level'] == MOD )?'style="color:#' . $theme['fontcolor2'] . '"':'');
$list[$n] .= ' <a href="' . append_sid($phpbb_root_path."profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $user_list[$i]['user_id']) . '"' . $style_color .'><b>' . $user_list[$i]['username'] . '</b></a>';
尋找\r
define('NOTIFY_USERS', true);代碼: 選擇全部
define('NOTIFY_USERS', false); 打開MOD裡的delete_users.php
尋找
if(!$result = $db->sql_query('SELECT user_id , username, user_email, user_lang ' . $sql . ' ORDER BY username')) 代碼: 選擇全部
if(!$result = $db->sql_query('SELECT user_id , username, user_email, user_lang ' . $sql . ' ORDER BY username LIMIT 800'))尋找\r
$sql[$n]='SELECT DISTINCT user_id , username, user_level '.$sql[$n].' AND user_regdate<"'.(time()-(86400*$days [$n])).'" ORDER BY username';代碼: 選擇全部
$sql[$n]='SELECT DISTINCT user_id , username, user_level '.$sql[$n].' AND user_regdate<"'.(time()-(86400*$days [$n])).'" ORDER BY username LIMIT 800';以上修改若有進一步問題可以參考作者原文
根據今天搜尋文章後找到解決時間不準的方法,感謝倉木麻衣會員提供:
這個問題個人前幾天也有遇到過
後來發現時間會不太正確的原因是它使用user_lastvisit 欄位去判斷\r
事實上~這個欄位必須在user下回登入時才會被更新\r
主要是用來與目前登入時間比對~用以列出有多少未讀文章
使用者真正的登出時間可由user_sesion_time這個欄位得出\r
個人將比對的時間欄位換成user_session_time後~就能正常運作
不會再出現該使用者明明在一二星期前來訪過~卻被判斷成超過60天未登入\r
改法大致如下
#-----[ REPLACE WITH ]---------------------------------------------
真慘~
之前講到要修改的那個檔案(admin/admin_prune_users.php)
只是列出符合條件的使用者而已\r
還要記得改 delete_users.php 檔才行
否則一樣會砍錯人*.* (剛才才發現..被刪掉的人數與列出的人數不符)
這個問題個人前幾天也有遇到過
改法大致如下
admin/admin_prune_users.php#-----[ FIND ]---------------------------------------------
$sql [3] = ' AND user_lastvisit<'.(time()-86400*60); #-----[ REPLACE WITH ]---------------------------------------------
$sql [3] = ' AND user_session_time<'.(time()-86400*60); #-----[ SAVE/CLOSE ALL FILES ]------------------------------------------
真慘~
只是列出符合條件的使用者而已\r
delete_users.php#-----[ FIND ]---------------------------------------------
user_lastvisit<'.(time()-86400*60)#-----[ REPLACE WITH ]---------------------------------------------
user_session_time<'.(time()-86400*60)#-----[ SAVE/CLOSE ALL FILES ]------------------------------------------
