1.0版僅適用於Plus 1.x上面\r
裡面僅有可以裝在phpbb Plus 1.x 上的設定
並且修改了一些原模組的BUG
參考使用的MODS的連結如下:
1.Cees-Jan Kiewiet < webmaster@iceblow.zzn.com > - change guest template mod (找不到連結) ★⊙。~~~。⊙★
2.Tom Cioffe Jr < gwyd@cioffe.com > - change style on index / counts users mod
3.Smartor < smartor_xp@hotmail.com > - http://smartor.is-root.com - ezPortal & Change Style for Smartor's ezPortal
4.yuan - http://www.timer.idv.tw/ - select default language mod for Smartor's ezPortal
5.Niels Chr. R鷣 Denmark < ncr@db9.dk > - select default language mod
這個版本主要就只是讓使用者在未登入前可以有機會的改變它所看到的版面風格和語言設定,讓未註冊及未登入的會員能夠更快的了解論壇~
[php]<?php
## Mod Title: Change Style & language on Index & Smartor's ezPortal
## Mod Version: 1.0
## Author: GFF_Grant(godbless) < godbless@gff.mac.to > - http://gff.mac.to
## Lots of credits to: Cees-Jan Kiewiet < webmaster@iceblow.zzn.com > - change guest template mod
## Tom Cioffe Jr < gwyd@cioffe.com > - change style on index / counts users mod
## Smartor <smartor_xp@hotmail.com> - http://smartor.is-root.com - ezPortal & Change Style for Smartor's ezPortal
## yuan - http://www.timer.idv.tw/ - select default language mod for Smartor's ezPortal
## Niels Chr. R鷣 Denmark < ncr@db9.dk > - select default language mod
## This mod is based on Cess-Jan Kiewiet's change guest template mod . If a user is logged in,
## their choice of template is stored in a cookie for 6 hours. Otherwise,
## the logged in user's choice in inputted directly into the database.
## This mod is for phpBB2 Plus 1.x
## Installation rated: easy-medium
## Installation time: aprox 5-10 min (for editing templates)
## Files to edit: 3 or 5
## common.php
## index.php
## templates/Your Templates/index_body.tpl
## portal.php
## templates/Your Templates/portal_body.tpl
## Security Disclaimer: This MOD Cannot Be Posted To Or Added At Any Non-Official phpBB Sites
## Installation Notes:
## The most important thing to keep in mind is, take your time, make
## sure you are finding the correct lines to modify, then take care to paste the new code.
## Please also keep in mind, if you are using more than one language file or theme at your
## site, you will need to edit the corrosponding files for each occurrence. Good Luck!
common.php
#-----[FIND]------------------------------------------
$board_config[$row['config_name']] = $row['config_value'];
#-----[AFTER, ADD]------------------------------------------
if ($language)
$board_config['default_lang'] = $language;
setcookie('default_lang',$language , (time()+21600), $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
} else if (isset($HTTP_COOKIE_VARS['default_lang']) )
$board_config['default_lang']=$HTTP_COOKIE_VARS['default_lang'];
if ($template)
$board_config['default_style'] = $template;
setcookie('default_style',$template , (time()+21600), $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
} else if (isset($HTTP_COOKIE_VARS['default_style']) )
$board_config['default_style']=$HTTP_COOKIE_VARS['default_style'];
index.php
#-----[ADD AFTER]------------------------------------------
include($phpbb_root_path . 'includes/functions_selects.'.$phpEx); // Change Style & Language
// Handle marking posts
#-----[ADD BEFORE]------------------------------------------
// Change Style
$fpage_style = $userdata['user_style'];
if(isset($HTTP_POST_VARS['fpage_theme']))
$fpage_theme = intval($HTTP_POST_VARS['fpage_theme']);
$fpuser_id = $userdata['user_id'];
$fp_sql = "UPDATE " . USERS_TABLE . " SET user_style = '$fpage_theme' WHERE user_id = $fpuser_id";
if ( !($fp_result = $db->sql_query($fp_sql)) )
message_die(GENERAL_ERROR, 'Could not update users table ' . "$user_id $fpage_theme", '', __LINE__, __FILE__, $sql);
$fp_message = $lang['Profile_updated'] . '<br /><br />' . sprintf($lang['Click_return_index'], '<a href="' . append_sid("index.$phpEx") . '">', '</a>');
message_die(GENERAL_MESSAGE, $fp_message);
'LANGUAGE_SELECT' => language_select($board_config['default_lang'], 'language'),
'L_SELECT_LANG' => $lang['Board_lang'],
'TEMPLATE_SELECT' => style_select($board_config['default_style'], 'template'),
'L_SELECT_STYLE' => $lang['Board_style'],
'FPAGE_STYLE' => style_select($fpage_style, 'fpage_theme'),
'L_CHANGE_NOW' => $lang['Go'],
<td class="row1"><span class="gensmall">
#-----[BEFORE ADD]------------------------------------------
</form>
<th colspan="2" class="thCornerL" height="25" nowrap="nowrap">
{L_SELECT_LANG}
</span></td>
<td class="row1" align="center" valign="middle" height="28"><span class="gensmall">
<form method="post" action=""{U_INDEX}">{LANGUAGE_SELECT}
<input type="submit" class="mainoption" name="cangenow" value="{L_CHANGE_NOW}" />
</span></td>
</tr><td class="row1">
<hr>
</td>
</form>
{L_SELECT_STYLE}
</span></td>
<form method="post" action=""{U_INDEX}">\r
{TEMPLATE_SELECT} <input type="submit" class="mainoption" name="fpcangenow" value="{L_CHANGE_NOW}" />
</span></td>
<hr>
</td>
portal.php
define('IN_PHPBB', true);
$phpbb_root_path = './';
include($phpbb_root_path . 'fetchposts.'.$phpEx);
$template->assign_vars(array(
'WELCOME_TEXT' => $CFG['welcome_text'],
'TOTAL_POSTS' => sprintf($l_total_post_s, $total_posts),
'TOTAL_USERS' => sprintf($l_total_user_s, $total_users),
#-----[ BEFORE ADD ]-----------------------------------
// Change Style
'L_VOTE_BUTTON' => $lang['Vote'],
#-----[ AFTER ADD ]-----------------------------------
<!-- BEGIN switch_user_logged_in -->
<center><br />{AVATAR_IMG}</center>
<br />{LAST_VISIT_DATE}<br />
<!-- END switch_user_logged_in -->
<br />{CURRENT_TIME}<br /><br />{S_TIMEZONE}
<br /><br /><form method="post" action="{U_PORTAL}"><span style="filter: glow(color=blue,strength=3); height:10px; color:white; padding:1px; font-size : 11px">{L_SELECT_STYLE}:<br /></span><br />
<!-- BEGIN switch_user_logged_out -->
{TEMPLATE_SELECT} <input type="submit" class="mainoption" name="cangenow" value="{L_CHANGE_NOW}" />
{FPAGE_STYLE} <input type="submit" class="mainoption" name="fpcangenow" value="{L_CHANGE_NOW}" />
</form>
</table>
</form>
</form><th colspan="2" class="thCornerL" height="25" nowrap="nowrap">
{L_SELECT_LANG}
</span></td>
<form method="post" action=""{U_INDEX}">{LANGUAGE_SELECT}<input type="submit" class="mainoption" name="cangenow" value="{L_CHANGE_NOW}" />
</span></td>
</tr></form>
#EoM
?>[/php]
[外掛]改變版面語言及風格 1.0
[外掛]改變版面語言及風格 1.0
外掛問題區發問格式就在這裡,請務必一定照著格式來~!
你不照著規則來,就算是神也搞不清楚你的問題在哪裡!
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
