修改的地方不多,主要是在INDEX上面\r
並且加入了統計論壇風格的設定,可以方面的讓人看到目前論壇比較受歡迎的風格。
最重要的是~~登入後也可以改風格了~
接下來下一版的目標就是要讓2.0.X的使用者在登入後也能夠改風格~~
(挑位置中)
要看DEMO嗎??
來這邊吧\r
http://bbs.gffclan.net
[php]<?php
## Mod Title: Change Style & language on Index & Smartor's ezPortal
## Mod Version: 1.2
## Author: GFF_Grant(godbless) < godbless@gffclan.net > - http://gffclan.net
## Lots of credits to: Cees-Jan Kiewiet < webmaster@iceblow.zzn.com > - change guest template mod
## Tom Cioffe Jr < gwyd@cioffe.com > - change style on index / counts users mod
## Smartor < smartor_xp@hotmail.com > - http://smartor.is-root.com - ezPortal & Change Style for Smartor's ezPortal
## yuan - http://www.timer.idv.tw/ - select default language mod for Smartor's ezPortal
## Niels Chr. R鷣 Denmark < ncr@db9.dk > - select default language mod
## This mod is based on Cess-Jan Kiewiet's change guest template mod . If a user is logged in,
## their choice of template is stored in a cookie for 6 hours. Otherwise,
## the logged in user's choice in inputted directly into the database.
## This mod is for phpBB2 Plus 1.x
## Installation rated: easy-medium
## Installation time: aprox 5-10 min (for editing templates)
## Files to edit: 3 or 5
## common.php
## index.php
## templates/Your Templates/index_body.tpl
## portal.php
## templates/Your Templates/portal_body.tpl
\n## History:
## 1.0 Confirmed for phpBB2 Plus 1.x
## 1.1 Confirmed for phpBB2 Plus 1.x & phpBB 2.0.x
## 1.2 Change Styles for phpBB2 Plus 1.x within logged in on Index
## Security Disclaimer: This MOD Cannot Be Posted To Or Added At Any Non-Official phpBB Sites
## Installation Notes:
## The most important thing to keep in mind is, take your time, make
## sure you are finding the correct lines to modify, then take care to paste the new code.
## Please also keep in mind, if you are using more than one language file or theme at your
## site, you will need to edit the corrosponding files for each occurrence. Good Luck!
common.php
#-----[FIND]------------------------------------------
$board_config[$row['config_name']] = $row['config_value'];
#-----[AFTER, ADD]------------------------------------------
if ($language)
$board_config['default_lang'] = $language;
setcookie('default_lang',$language , (time()+21600), $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
} else if (isset($HTTP_COOKIE_VARS['default_lang']) )
$board_config['default_lang']=$HTTP_COOKIE_VARS['default_lang'];
if ($template)
$board_config['default_style'] = $template;
setcookie('default_style',$template , (time()+21600), $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
} else if (isset($HTTP_COOKIE_VARS['default_style']) )
$board_config['default_style']=$HTTP_COOKIE_VARS['default_style'];
index.php
#-----[ADD AFTER]------------------------------------------
include($phpbb_root_path . 'includes/functions_selects.'.$phpEx); // Change Style & Language
// Handle marking posts
#-----[ADD BEFORE]------------------------------------------
// Change Style
$fpage_style = $userdata['user_style'];
if(isset($HTTP_POST_VARS['fpage_theme']))
$fpage_theme = intval($HTTP_POST_VARS['fpage_theme']);
$fpuser_id = $userdata['user_id'];
$fp_sql = "UPDATE " . USERS_TABLE . " SET user_style = '$fpage_theme' WHERE user_id = $fpuser_id";
if ( !($fp_result = $db->sql_query($fp_sql)) )
message_die(GENERAL_ERROR, 'Could not update users table ' . "$user_id $fpage_theme", '', __LINE__, __FILE__, $sql);
$fp_message = $lang['Profile_updated'] . '<br /><br />' . sprintf($lang['Click_return_index'], '<a href="' . append_sid("index.$phpEx") . '">', '</a>');
message_die(GENERAL_MESSAGE, $fp_message);
'LANGUAGE_SELECT' => language_select($board_config['default_lang'], 'language'),
'L_SELECT_LANG' => $lang['Board_lang'],
'TEMPLATE_SELECT' => style_select($board_config['default_style'], 'template'),
'L_SELECT_STYLE' => $lang['Board_style'],
'FPAGE_STYLE' => style_select($fpage_style, 'fpage_theme'),
'L_CHANGE_NOW' => $lang['Go'],
# (only for phpBB 2.0.x )
# (remember to change this in every template dir)
<input type="submit" class="mainoption" name="login" value="{L_LOGIN}" />
</span> </td>
</table>
</form>
#-----[REPLACE WITH]------------------------------------------
</span> </td>
</form>
<td class="catHead" height="28"><a name="login"></a><span class="cattitle">{L_SELECT_LANG}</span></td>
<td class="row1" align="center" valign="middle" height="28"><span class="gensmall">
<form method="post" action=""{U_INDEX}">
{LANGUAGE_SELECT} <input type="submit" class="mainoption" name="cangenow" value="{L_CHANGE_NOW}" />
</span></td>
</tr> </form>
</form>
<td class="catHead" height="28"><a name="login"></a><span class="cattitle">{L_SELECT_STYLE}</span></td>
{TEMPLATE_SELECT} <input type="submit" class="mainoption" name="cangenow" value="{L_CHANGE_NOW}" />
</span></td>
</tr> </form>
</table>
# (only for phpBB Plus 1.x )
<td class="row1"><span class="gensmall">
#-----[BEFORE ADD]------------------------------------------
</form>
<th colspan="2" class="thCornerL" height="25" nowrap="nowrap">
{L_SELECT_LANG}
</span></td>
<form method="post" action=""{U_INDEX}">{LANGUAGE_SELECT}
</span></td> \r
</tr><td class="row1">
<hr>
</td>
</td>
<!-- BEGIN switch_user_logged_out -->
<br /><br /><form method="post" action="{U_INDEX}">
<span style="filter: glow(color=blue,strength=3); height:10px; color:white; padding:1px; font-size : 11px">{L_SELECT_STYLE}:<br /></span><br />
<!-- BEGIN switch_user_logged_in -->
{FPAGE_STYLE} <input type="submit" class="mainoption" name="fpcangenow" value="{L_CHANGE_NOW}" />
<!-- END switch_user_logged_in -->
</form><br /><br />
portal.php
define('IN_PHPBB', true);
$phpbb_root_path = './';
include($phpbb_root_path . 'fetchposts.'.$phpEx);
$template->assign_vars(array(
'WELCOME_TEXT' => $CFG['welcome_text'],
'TOTAL_POSTS' => sprintf($l_total_post_s, $total_posts),
'TOTAL_USERS' => sprintf($l_total_user_s, $total_users),
#-----[ BEFORE ADD ]-----------------------------------
// Change Style
'L_VOTE_BUTTON' => $lang['Vote'],
#-----[ AFTER ADD ]-----------------------------------
<center><br />{AVATAR_IMG}</center>
<br />{LAST_VISIT_DATE}<br />
<br />{CURRENT_TIME}<br /><br />{S_TIMEZONE}
<br /><br /><form method="post" action="{U_PORTAL}"><span style="filter: glow(color=blue,strength=3); height:10px; color:white; padding:1px; font-size : 11px">{L_SELECT_STYLE}:<br /></span><br />
</form>
</table>
</form>
</form><th colspan="2" class="thCornerL" height="25" nowrap="nowrap">
{L_SELECT_LANG}
</span></td>
<form method="post" action=""{U_INDEX}">{LANGUAGE_SELECT}<input type="submit" class="mainoption" name="cangenow" value="{L_CHANGE_NOW}" />
</span></td>
</tr></form>
# (THIS ADDS THE NUMBER OF USERS WITH THIS STYLE TO THE DROP DOWN.
# SKIP TO THE NEXT FILE IF YOU DO NOT WISH TO ADD THIS FEATURE)
#-----[ OPEN FILE: includes/functions_selects.php ]------------------------------------------
$selected = ( $row['themes_id'] == $default_style ) ? ' selected="selected"' : '';
$style_select .= '<option value="' . $row['themes_id'] . '"' . $selected . '>' . $row['style_name'] . '</option>';
//begin theme count
$tcount=0;
$t_id = $row['themes_id'];
$tsql = "SELECT user_style FROM " . USERS_TABLE . " WHERE user_style = $t_id";
if ( !($tresult = $db->sql_query($tsql)) ){
message_die(GENERAL_ERROR, "Couldn't query user table", "", __LINE__, __FILE__, $sql);}
while ( $trow = $db->sql_fetchrow($tresult) ) {
$tcount++; }
$style_select .= '<option value="' . $row['themes_id'] . '"' . $selected . '>' . $row['style_name'] . ' [users: ' . $tcount . ']</option>';
#EoM
?>[/php]
[2.0.4][PLUS]快速改變論壇風格及語言設定1.2
外掛問題區發問格式就在這裡,請務必一定照著格式來~!
你不照著規則來,就算是神也搞不清楚你的問題在哪裡!
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
