admin_prune_user_posts.php 放置於 admin/
admin_prune_users_body.tpl 放置於 templates/subSilver/admin/
lang_prune_users.php 放置於 language/lang_chinese_traditional_taiwan/
有裝過快速砍人的可以將 lang_prune_users.php 的內容合併進去,因為兩個外掛語言檔檔名相同。
「搜尋會員名稱鈕」若沒出現問題就不用改,錯誤是被一堆碼給取代。
開啟 templates/subSilver/admin/admin_prune_users_body.tpl
尋找\r
?input type="submit" name="usersubmit" value="{L_FIND_USERNAME}" class="liteoption" onclick="window.open('{U_SEARCH_USER}', '_phpbbsearch', 'HEIGHT=250,resizable=yes,WIDTH=400');return false;" />
﹙自己翻的中文化,不是很完美﹚
開啟 language/lang_chinese_traditional_taiwan/lang_prune_users.php
尋找\r
$lang['Page_title'] = "Prune User Posts";
$lang['Page_desc'] = "You can use those tool to delete posts of a specific user from all the forums any specific one.";
$lang['User_name'] = "Username";
$lang['Forum'] = "Forum";
$lang['Prune'] = "Prune";
$lang['Prune_result_n'] = "%d Posts Deleted.";
$lang['Prune_result_s'] = "Successfully Pruned %d post.";
$lang['Prune_result_p'] = "Successfully Pruned %d posts.";
$lang['User_nfound'] = "ERROR: Username does not exist!";
$lang['Page_title'] = "刪除會員所有文章";
$lang['Page_desc'] = "你可以使用這些工具來刪除特定使用者在所有版面的文章.";
$lang['User_name'] = "會員名稱";
$lang['Forum'] = "選擇版面";
$lang['Prune'] = "送出";
$lang['Prune_result_n'] = "%d 文章已刪除";
$lang['Prune_result_s'] = "成功刪除 %d 篇文章";
$lang['Prune_result_p'] = "成功刪除 %d 篇文章";
$lang['User_nfound'] = "錯誤︰會員不存在";
實在想不出這兩句的意思有何差別,所以都改一樣。
我的問題造就了我發表這個MOD,這版雖然陽春但也蠻實用的。會員被砍掉後所有文章發表人都會變成訪客,比較龜毛追求完美的人務必在砍人前先去清空他的文章。這是我發表的第二個外掛,希望各位會喜歡。
