[轉貼]圖形化水怪RPG的HP/MP/EXP
StickyKid
文章: 1019
註冊時間: 2003-01-31 10:32
來自: Taichung, Taiwan
文章 由 StickyKid »
Martinet先生原創喔~
圖檔取自Mac的HP/MP/EXP外掛....
http://phpbb-tw.net/phpbb/viewtopic.php ... hlight=EXP
需要不同圖檔的可以到FI去下載
http://www.forumimages.com
開始囉.....
開啟viewtopic.php
搜尋
$template->assign_block_vars('postrow', array(
前面加入\r
$exptemp = 100*($postrow[$i]['rpg_cur_exp']/ $postrow[$i]['rpg_max_exp']);
$hptemp = 100 * ($postrow[$i]['rpg_cur_hp'] / $postrow[$i]['rpg_max_hp']);
$mptemp = 100 *($postrow[$i]['rpg_cur_mp']/ $postrow[$i]['rpg_max_mp']);
搜尋
'POSTER_AVATAR' => $poster_avatar,
後面加入\r
'RPG_LEVEL' => $postrow[$i]['rpg_level'],
'RPG_EXP_RATIO' => $exptemp,
'RPG_HP_RATIO' => $hptemp,
'RPG_MP_RATIO' => $mptemp,
'RPG_CUR_HP' => $postrow[$i]['rpg_cur_hp'],
'RPG_CUR_MP' => $postrow[$i]['rpg_cur_mp'],
'RPG_CUR_EXP' => $postrow[$i]['rpg_cur_exp'],
'RPG_MAX_HP' => $postrow[$i]['rpg_max_hp'],
'RPG_MAX_MP' => $postrow[$i]['rpg_max_mp'],
'RPG_MAX_EXP' => $postrow[$i]['rpg_max_exp'],
開啟templates/subSilver/viewtopic_body.tpl
搜尋
{postrow.POSTER_FROM}</span><br />
後面加入\r
<!-- RPG Mod -->
<!--<br />-->
<span class="postdetails">等級: <strong><font color=red>{postrow.RPG_LEVEL}</font>
<table width="143" border="0" cellpadding="0" cellspacing="0" style="background-image:url(templates/subSilver/images/level_mod/lm_bkg.gif)">
<td><img src="images/spacer.gif" alt="" width="31" height="49" /></td>
<td width="100%">
<table width="100%" border="0" cellspacing="0" cellpadding="0">
<td><img src="images/spacer.gif" alt="" width="20" height="6" /></td>
<td><img src="templates/subSilver/images/level_mod/lm_hp_bar.gif" alt="{postrow.RPG_CUR_HP}/{postrow.RPG_MAX_HP}"  title="{postrow.RPG_CUR_HP} / {postrow.RPG_MAX_HP}" width="{postrow.RPG_HP_RATIO}" height="9" /><img src="templates/subSilver/images/level_mod/lm_hp_bar_end.gif" alt="" width="4" height="9" /></td>
<td><img src="images/spacer.gif" alt="" width="20" height="4" /></td>
<td><img src="templates/subSilver/images/level_mod/lm_mp_bar.gif" alt="{postrow.RPG_CUR_MP}/{postrow.RPG_MAX_MP}" title="{postrow.RPG_CUR_MP} / {postrow.RPG_MAX_MP}" width="{postrow.RPG_MP_RATIO}" height="9" /><img src="templates/subSilver/images/level_mod/lm_mp_bar_end.gif" alt="" width="4" height="9" /></td>
\n<tr>
<td><img src="templates/subSilver/images/level_mod/lm_exp_bar.gif" alt="{postrow.RPG_CUR_EXP}/{postrow.RPG_MAX_EXP}" title="{postrow.RPG_CUR_EXP} / {postrow.RPG_MAX_EXP}" width="{postrow.RPG_EXP_RATIO}" height="9" /><img src="templates/subSilver/images/level_mod/lm_exp_bar_end.gif" alt="" width="4" height="9" /></td>
<td><img src="images/spacer.gif" alt="" width="20" height="8" /></td>
</table>
</td>
</table>
</span>
<!-- [END RPG MOD] -->
Mowd
文章: 326
註冊時間: 2002-06-26 01:17
來自: 台北
文章 由 Mowd »
似乎都沒有人發現,有個地方打錯了,這個錯誤會造成
Parse error: parse error, unexpected ';', expecting ')' in /home/phpbb/viewtopic.php on line 1389
修正的地方我已經用紅色粗體標明了。
還有由於phpbb版本的更新,$profiledata要改成$postrow[$i]才可正常運作,同樣也在上面修正了。
今天有人向我反映我才發現。
回到「非官方認證外掛」
