[外掛]Flashing GIF for new PM
scott511747
文章: 176
註冊時間: 2003-04-14 22:25
文章 由 scott511747 »
## MOD Title:          Flashing GIF for new PM
## MOD Author:         Niels < ncr@db9.dk > (Niels Chr. R鷣) http://mods.db9.dk
## MOD Description:    This MOD replace the PM GIF by a flashing
##                     one when you have new PM not viewed.
## MOD Version:        1.0.0
## Compatibility:      2.0.4->2.0.6 (2.0.0->2.0.3 not tested)
## Installation Level: Easy
## Installation Time:  2 minutes
## Files To Edit:      2
##         templates/subSilver/overall_header.tpl
##         templates/subSilver/subSilver.cfg
## Included Files:     4
##         templates/subSilver/images/icon_mini_message.gif
##         templates/subSilver/images/icon_mini_no_message.gif
##         templates/subTrail/images/icon_mini_message.gif
##         templates/subTrail/images/icon_mini_no_message.gif
## Author Notes:
## This MOD is NOT compatible with EasyMOD 0.0.10 of Nuttzy.
## It can NOT be fully installed because EM can't find the
## string "templates/subSilver/images/icon_mini_message.gif"
## in other styles than subSilver. The only solution would
## have been to replace all the line, but it's too risky.
## For updates, check this official link...
## http://mods.db9.dk/viewforum.php?f=12
## MOD History:
##   2003-08-03 - Version 1.0.0
##      - Initial final release
#-----[ 複製 ]------------------------------------------------
copy icon_mini_message.gif to templates/subSilver/images/
copy icon_mini_no_message.gif to templates/subSilver/images/
#-----[ 開啟 ]------------------------------------------------
#-----[ 尋找 ]------------------------------------------------
#-----[ 替換成 ]-----------------------------------------
{PRIVMSG_IMG}
$images['pm_new_msg'] = "";
$images['pm_no_new_msg'] = "";
// Start replacement - Flashing GIF for new PM MOD
$images['pm_new_msg'] = "$current_template_images/icon_mini_message.gif";
$images['pm_no_new_msg'] = "$current_template_images/icon_mini_no_message.gif";
// End replacement - Flashing GIF for new PM MOD
#-----[ 存檔並上傳 ]--------------------------------
# EoM
icon_mini_no_message.gif 圖檔
icon_mini_message.gif 圖檔
當你有新訊息時圖示會閃爍提示!
有時將訊息框關掉後就會忘記去看他,不過一閃一閃的 Icon 我想不去注意也難!
不清楚開發處的註冊用意,如果有違反的話請管理群刪掉吧!
回到「非官方認證外掛」
