來源:http://www.phpbbhacks.com/viewhack.php?id=2033
[php]## EasyMod 0.0.7 compliant
## MOD Title: Did you know? Box
## MOD Author: Dwing < dwing@weingarten-net.de > (Dimitri Seitz) http://www.dseitz.de
## MOD Description: This Hack will create a 'Did you know?' Box in the phpBB Header. Sentences can be set in the file schon_gewusst.txt
## MOD Version: 1.0.0
## Installation Level: easy
## Installation Time: 2 minutes
## Files To Edit: 2
## Included Files: schon_gewusst.txt
## Author Notes: Demo http://www.weingarten-net.de/static/modtest/ (german version)
##############################################################[/php]
[php]#
includes/page_header.php
// Format Timezone. We are unable to use array_pop here, because of PHP3 compatibility
$l_timezone = explode('.', $board_config['board_timezone']);
$l_timezone = (count($l_timezone) > 1 && $l_timezone[count($l_timezone)-1] != 0) ? $lang[sprintf('%.1f', $board_config['board_timezone'])] : $lang[number_format($board_config['board_timezone'])];
// Generate 'Did you know?'
$random_file = $phpbb_root_path . 'schon_gewusst.txt';
$random = file($random_file);
srand();
$randomizer = rand(0, count($random) );
$znumber = rand(1, 2);
if( !isset($random[$randomizer]) )
$random[$randomizer] = 'More Mods like this <a href="http://www.dseitz.de">here</a>';
'PRIVMSG_IMG' => $icon_pm,
'ZMESSAGE' => $random[$randomizer],
'ZNUMBER' => $znumber,
templates/subSilver/overall_header.tpl
</table></td>
</table>
<!-- Did you know? -->
<br />
<table border="0" align="center" cellpadding="4" cellspacing="0" class="forumline">
<tbody>
<th class="thHead"> Did you kow? </th>
<td class="row{ZNUMBER}"><span class="gen"> {ZMESSAGE} </span></td>
</tbody>
</table>
<br clear="all">
#-----[ COPY TO FOLDER ]------------------------------------------
schon_gewusst.txt to schon_gewusst.txt
# EoM[/php]
功能:在首頁新增一個表格顯示隨機的字串
[外掛]Did You Know?
GeniusKiKi
- 文章: 1086
- 註冊時間: 2003-10-28 14:50
[外掛]Did You Know?
再也不當爛好人...
好人是小白轉型成大白的墊腳石...
好人是小白轉型成大白的墊腳石...
常見到的應用有
醒世格言
歷史上的今天\r
小技巧\r
等等
醒世格言
歷史上的今天\r
小技巧\r
等等
七點要求:
1. 發問前先搜尋,確定沒有重複後再發表
2. 主題要明確
3. 依照發問格式
4. 禁連續推文
5. 請盡量減少使用地方性語言
七點要求:
2. 主題要明確
3. 依照發問格式
4. 禁連續推文
5. 請盡量減少使用地方性語言
