[轉貼]Yahoo Messanger Online/Off
gueatest
文章: 42
註冊時間: 2002-11-17 07:25
文章 gueatest »
在phpbb官網上看到的...
分享出來給大家用囉^^~
yahoo_online_offline_204_pc
## MOD Title: Yahoo Messanger Online/Offline
## MOD Author: donpedro00 < palagyi@hotmail.com > (Peter Palagyi) http://www.SlovakiaClub.com
## MOD Description: This MOD will allow you to have an 'Online/Offline' Icon For Yahoo Messanger.
##                  When cliked on icon, Yahoo messanger that is installed on PC window will popup.
## MOD Version: 2.0.4 - PC
## Installation Level: Easy
## Installation Time: ~10 Minutes
## Files To Edit:
##                   viewtopic.php
##                   templates/subSilver/viewtopic_body.tpl
##                   privmsg.php
##                   templates/subSilver/privmsgs_read_body.tpl
##                   includes/usercp_viewprofile.php
##                   templates/subSilver/profile_view_body.tpl
##                   templates/subSilver/subSilver.cfg
## Included Files:
##                   templates/subSilver/images/lang_english/icon_yim_status.gif
## Author Notes:
## Copyright ?Peter Palagyi, < palagyi@hotmail.com >
## Make sure that in your Yahoo Public Profile you uncheck "Check the box to hide my
## online status () from other users" checkbox. Otherwise the status will always show you as offline.
## More about that flag can be found here http://messenger.yahoo.com/messenger/onlinestatus.html
## MOD History:
##   2003-06-21 - Version 1.0.0
##      - Initial Release For phpBB 2.0.5 (also works with phpBB 2.0.2)
##   2003-06-21 - Version 1.0.1
##      - privmsg.php modified to include this MOD in PM
##   2003-07-28 - Version 2.0.0
##      - new "SubSilver" compatible icon added
##      - two version are maintained. web and pc messanger version
##   2003-08-09 - Version 2.0.1
##      - fixed issue with private message and profile (wrong icon)
##	  - tested on release phpBB 2.0.6 too
##   2003-08-10 - Version 2.0.2
##	  - fixed "to to" in copy command
##   2003-08-13 - Version 2.0.4
##      - fixed problem with missing FIND after profile_view_body.tpl
##      - tested with EasyMOD alpha3 (0.0.10a)
#-----[ OPEN ]-------------------------------------
viewtopic.php
#-----[ FIND ]-------------------------------------
		$yim_img = ( $postrow[$i]['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $postrow[$i]['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
#-----[ REPLACE WITH ]-------------------------------------
		// MOD - YAHOO ONLINE/OFFLINE - donpedro00
		//$yim_img = ( $postrow[$i]['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $postrow[$i]['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
     		$yim_img = ( $postrow[$i]['user_yim'] ) ? '<a href="ymsgr:sendim?' . $postrow[$i]['user_yim'] . '"><img src="' . $images['icon_yim_status'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
		$yim_status_img = ( $postrow[$i]['user_yim'] ) ? '<a href="ymsgr:sendim?' . $postrow[$i]['user_yim'] . '"><img src="http://opi.yahoo.com/online?u=' . $postrow[$i]['user_yim'] . '&m=g&t="' . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
		'YIM_IMG' => $yim_img,
#-----[ AFTER, ADD ]-------------------------------------
		'YIM_STATUS_IMG' => $yim_status_img,
				<td valign="middle" nowrap="nowrap">{postrow.PROFILE_IMG} {postrow.PM_IMG} {postrow.EMAIL_IMG} {postrow.WWW_IMG} {postrow.AIM_IMG} {postrow.YIM_IMG} {postrow.MSN_IMG}<script language="JavaScript" type="text/javascript"><!--
				<!-- MOD - YAHOO ONLINE/OFFLINE - donpedro00 -->
				{postrow.PM_IMG}
				{postrow.EMAIL_IMG}
				{postrow.WWW_IMG}
				{postrow.MSN_IMG}
				{postrow.AIM_IMG}
						if ( navigator.userAgent.toLowerCase().indexOf('mozilla') != -1 && navigator.userAgent.indexOf('5.') == -1 )
							document.write(' {postrow.YIM_IMG}');
							document.write('</td><td> </td><td valign="top" nowrap="nowrap"><div style="position:relative"><div style="position:absolute">{postrow.YIM_IMG}</div><div style="position:absolute;left:32px;top:4px">{postrow.YIM_STATUS_IMG}</div></div>');
					</script>
					{postrow.YIM_IMG}
privmsg.php
	$yim_img = ( $privmsg['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $privmsg['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
	//$yim_img = ( $privmsg['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $privmsg['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
      $yim_img = ( $privmsg['user_yim'] ) ? '<a href="ymsgr:sendim?' . $privmsg['user_yim'] . '"><img src="' . $images['icon_yim_status'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
      $yim_status_img = ( $privmsg['user_yim'] ) ? '<a href="ymsgr:sendim?' . $privmsg['user_yim'] . '"><img src="http://opi.yahoo.com/online?u=' . $privmsg['user_yim'] . '&m=g&t="' . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
\n#
			  {WWW_IMG} {AIM_IMG} {YIM_IMG} {MSN_IMG}</td><td> </td><td valign="top" nowrap="nowrap"><script language="JavaScript" type="text/javascript"><!--
			  {WWW_IMG} {AIM_IMG} {MSN_IMG}
							document.write(' {YIM_IMG}');
							document.write('</td><td> </td><td valign="top" nowrap="nowrap"><div style="position:relative"><div style="position:absolute">{YIM_IMG}</div><div style="position:absolute;left:32px;top:4px">{YIM_STATUS_IMG}</div></div>');
					</script>
					{YIM_IMG}
$yim_img = ( $profiledata['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $profiledata['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
//$yim_img = ( $profiledata['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $profiledata['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
$yim_img = ( $profiledata['user_yim'] ) ? '<a href="ymsgr:sendim?' . $profiledata['user_yim'] . '"><img src="' . $images['icon_yim_status'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
$yim_status_img = ( $profiledata['user_yim'] ) ? '<a href="ymsgr:sendim?' . $profiledata['user_yim'] . '"><img src="http://opi.yahoo.com/online?u=' . $profiledata['user_yim'] . '&m=g&t="' . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
		  <td valign="middle" nowrap="nowrap" align="right"><span class="gen">{L_YAHOO}:</span></td>
		  <td class="row1" valign="middle"><span class="gen">{YIM_IMG}</span></td>
\n		</tr>
		  <td class="row1"><script language="JavaScript" type="text/javascript"><!--
			document.write('<table cellspacing="0" cellpadding="0" border="0"><tr><td nowrap="nowrap"><div style="position:relative;height:18px"><div style="position:absolute">{YIM_IMG}</div><div style="position:absolute;left:32px;top:4px">{YIM_STATUS_IMG}</div></div></td></tr></table>');
		//--></script><noscript>{YIM_IMG}</noscript></td>
$images['icon_yim'] = "$current_template_images/{LANG}/icon_yim.gif";
$images['icon_yim_status'] = "$current_template_images/{LANG}/icon_yim_status.gif";
copy icon_yim_status.gif to templates/subSilver/images/lang_english/
# EoM
yahoo_online_offline_204_web
##                  When cliked on icon, Yahoo web page will open with Lite version of web
##                  based messanger. This is how ot was originaly designed.
## MOD Version: 2.0.4 - WEB
## Files To Edit:
##                   viewtopic.php
##                   privmsg.php
## Included Files:
## Author Notes:
## MOD History:
viewtopic.php
     		$yim_img = ( $postrow[$i]['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $postrow[$i]['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim_status'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
		$yim_status_img = ( $postrow[$i]['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $postrow[$i]['user_yim'] . '&.src=pg"><img src="http://opi.yahoo.com/online?u=' . $postrow[$i]['user_yim'] . '&m=g&t="' . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
				{postrow.PM_IMG}
				{postrow.EMAIL_IMG}
				{postrow.WWW_IMG}
				{postrow.MSN_IMG}
				{postrow.AIM_IMG}
					</script>
					{postrow.YIM_IMG}
privmsg.php
      $yim_img = ( $privmsg['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $privmsg['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim_status'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
      $yim_status_img = ( $privmsg['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $privmsg['user_yim'] . '&.src=pg"><img src="http://opi.yahoo.com/online?u=' . $privmsg['user_yim'] . '&m=g&t="' . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
					</script>
					{YIM_IMG}
$yim_img = ( $profiledata['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $profiledata['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim_status'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
$yim_status_img = ( $profiledata['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $profiledata['user_yim'] . '&.src=pg"><img src="http://opi.yahoo.com/online?u=' . $profiledata['user_yim'] . '&m=g&t="' . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
# EoM
請自行按"另存圖片"下載圖示..
感謝竹貓的大大們...真的辛苦了,也讓我在這學到不少,感謝大大們....^^"
拜託一下,不要再用私人訊息來跟我要東西了~"~
回到「非官方認證外掛」
