[外掛] P.C.P 時間格式選項
天霜
文章: 882
註冊時間: 2003-04-15 19:40
來自: 星之鄉學園
[外掛] P.C.P 時間格式選項
文章 由 天霜 »
#-----[ OPEN 打開 ]------------------------------------------------
includes/usercp_register.php
#-----[ FIND 尋找 ]------------------------------------------------
	$template->assign_vars(array(
		'USERNAME' => $username,
#-----[ BEFORE ADD 之前, 加上 ]------------------------------------
// build the date format list
	$timeset = array(
		'D m d, Y g:i a',
		'D d-m-Y, G:i',
		'M Y, D d, g:i a',
		'D d M Y, G:i',
		'd M Y h:i a',
		'd M Y, G:i',
		'D M d, Y g:i a',
		'D M d, Y G:i',
	$s_time = '<select name="dateformat" onChange="select_dateformat(this.options[this.selectedIndex].value);">';
	$time = time();
	$found = false;
	for ($i=0; $i < count($timeset); $i++)
		$selected = ($user_dateformat == $timeset[$i]) ? ' selected="selected"' : '';
		if ($selected != '') $found = true;
		$s_time .= '<option value="' . $timeset[$i] . '"' . $selected . '>' . create_date($timeset[$i], $time, $user_timezone) . '</option>';
	$selected = ( !$found ) ? ' selected="selected"' : '';
	$s_time .= '<option value=""' . $selected . '>' . $lang['Other'] . '</option></select>';
'LOCATION' => $location,
#-----[ AFTER, ADD 之後, 加上 ]------------------------------------
		'S_DATE_FORMAT' => $s_time,
// That's all Folks!
$lang['Other'] = "其他...";
templates/subSilver/profile_add_body.tpl
<form action="{S_PROFILE_ACTION}" {S_FORM_ENCTYPE} method="post">
#-----[ REPLACE WITH 替換 ]----------------------------------------
<script language="JavaScript" type="text/javascript">
function select_dateformat(format)
	if (format != '')
		this.document.forms['post'].user_dateformat.value = format;
</script>
<form action="{S_PROFILE_ACTION}" {S_FORM_ENCTYPE} name="post" method="post" >
	  <td class="row1"><span class="gen">{L_DATE_FORMAT}:</span><br />
		<span class="gensmall">{L_DATE_FORMAT_EXPLAIN}</span></td>
	  <td class="row2">
		<input type="text" name="dateformat" value="{DATE_FORMAT}" maxlength="14" class="post" />
	  </td>
	  <td class="row2">{S_DATE_FORMAT}
			<input type="text" name="user_dateformat" value="{DATE_FORMAT}" maxlength="14" class="post" />
	  </td>
#-----[ SAVE/CLOSE ALL FILES 儲存/關閉所有檔案 ]-------------------
# EoM 外掛修正結束
除非是個人疏失所造成的問題
這世界還有拼命守護的價值嗎...
回到「非官方認證外掛」
