[教學] Bank Mod 不能存小數解決方法 v1.0.1
kp3011
文章: 384
註冊時間: 2004-05-15 21:16
來自: HKG
文章 由 kp3011 »
## MOD Title: Solution to deposit decimals in Bank Mod
## MOD Author: Jisp Cheung <cheungpuipan@netvigator.com>
## MOD Description: With this MOD a user is able to deposit / withdraw decimals into the bank, which cannot be done before.
## MOD Version: 1.0.1
## Installation Level: Easy
## Installation Time: 3 Minutes
## MOD required before installing: Bank Mod
## Files To Edit: bank.php
## Author Notes:
## MOD History:
## YYYY-MM-DD - Version x.x.x
## - version notes go here
## 26 Sept 2004 - Modified
## 24 Sept 2004 - The publication of the MOD
# OPEN bank.php
# FIND
$holding = round($holding);
# REPLACE WITH
$holding = round($holding,2); * NOTE1
# FIND
$deposit = round($_REQUEST['deposit']);
# REPLACE WITH
$deposit = round($_REQUEST['deposit'],2); *NOTE1
# FIND
$withdraw = round($_REQUEST['withdraw']);
# REPLACE WITH
$withdraw = round($_REQUEST['withdraw'],2); *NOTE1
# FIND
if ((!is_numeric($deposit)) || ($deposit < 1))
# REPLACE WITH
if ((!is_numeric($deposit)) || ($deposit < 0)) *NOTE2
# FIND
if ((!is_numeric($withdraw)) || ($withdraw < 1))
# REPLACE WITH
if ((!is_numeric($withdraw)) || ($withdraw < 0)) *NOTE2
#-----[ SAVE/CLOSE ALL FILES ]-------------------
# EoM
*NOTE1: Replace the 2 to 1 if your currency has 1 decimal place and 3 if 3 decimals places and so on.
(如果您的貨幣有1個小數位, 請將 2 換成 1, 3個小數位則換成3, 如此類推)
*NOTE2: Replace the 0 in the last two steps to 0.1 if your currency has one decimal place or 0.01 if two and so on.
It has been tested in my site and it was all right.
(最後兩步中, 如果您的貨幣有一個小數位請以 0.1 取代 0 , 兩個則以 0.01 取代, 如此類推)
當然, 請謹記於bank資料表中更改接受的數字格式
回到「非官方認證外掛」
