[停止更新] 付費瀏覽強化版 1.0.5
DL
文章: 717
註冊時間: 2005-03-05 15:29
文章 DL »
本外掛停止更新,請至新外掛,謝謝
最後由 DL 於 2006-05-17 20:00 編輯,總共編輯了 19 次。
DL
文章: 717
文章 DL »
05年7月25日更新
小郭
文章: 33
註冊時間: 2002-06-28 22:44
來自: 地球
文章 小郭 »
我解壓縮的時候會出現\r
!   Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_fix\attach_mod: The file "Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_fix\attach_mod" header is corrupt
!   Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_fix\templates\subSilver: The file "Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_fix\templates\subSilver" header is corrupt
!   Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_fix\templates: The file "Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_fix\templates" header is corrupt
!   Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_fix: The file "Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_fix" header is corrupt
!   Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_org\attach_mod: The file "Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_org\attach_mod" header is corrupt
!   Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_org\templates\subSilver: The file "Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_org\templates\subSilver" header is corrupt
!   Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_org\templates: The file "Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_org\templates" header is corrupt
!   Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_org: The file "Pay_Money_MOD_Plus_1.0.1\extra\attach_mod_org" header is corrupt
!   Pay_Money_MOD_Plus_1.0.1\extra: The file "Pay_Money_MOD_Plus_1.0.1\extra" header is corrupt
!   Pay_Money_MOD_Plus_1.0.1: The file "Pay_Money_MOD_Plus_1.0.1" header is corrupt
出了什麼問題嗎?
郭建廷
問題狂
文章: 1947
註冊時間: 2004-06-28 17:13
文章 問題狂 »
給你兩個建議:
1.重新下載在解壓縮看看
2.下載最新版的WinRAR來解壓縮
DL
文章: 717
文章 DL »
已更新載點及程式,完全相容於2.0.18
DL
文章: 717
文章 DL »
現在連最新的2.0.19也支援囉...
DL
文章: 717
文章 DL »
06年1月10日,更新至1.0.3
回到「非官方認證外掛」
