[外掛] Topic Color Hack (修改標題顏色)
彬彬BinBin ] #14
註冊時間: 2005-10-02 11:45
來自: 燦爛夏天Rws        目標: 轟殺小白ing      近況: 存錢敗Nb
文章 由 彬彬BinBin ] #14 »
此外掛功能:能讓系統管理員或版面管理員修改標題的顏色。
  1. 檔頭說明
  2. 正體中文化修正參考
  3. 安裝及修正經驗
  4. 外掛下載
.檔頭說明
## MOD Title: "Colored Topic Title" Mod
## MOD Author: Lyrthion < lyrthion@yahoo.co.uk >  Wesley Hollander http://www.lotr-tk.com
## MOD Description: This mod will allow moderators and admins to give topic titles in the viewforum.php custom colors. By clicking on the (c) under the topic.
## MOD Version: 1.0.0
## Installation Level: easy
## Installation Time: 10 Minutes
## Files To Edit: 	viewforum.php
## 			templates/xxx/viewforum_body.tpl
## Files included:	topiccolor.php
## 			templates/subSilver/topic_color.tpl
## This mod has been created for 2.6.0 and is compatible with the Category Hierarchy MOD. Other mods unkown.
## Author Notes:
## First version of this mod, description not yet fully tested, report any mistakes I made here, please.
## MOD History:
## Development version 0.1 -> just the basic support for showing custom topic colors
## Development version 0.2 -> added a Control Panel to change topic colors without manually modifying Mysql
## BETA version 1.0 -> made the Control Panel preview the topic color.
## BETA version 1.1 -> added a plug-in ripped from Carlo Claessen's Colour Palette
.正體中文化修正參考
#-----[ OPEN ]-----------------------------------------------
topiccolor.php
Color '.$update_topic_color.' Updated.
#-----[ REPLACE WITH ]----------------------------------------
指定顏色為 '.$update_topic_color.'.
Click here to go to your topic.
點擊此回到此文章
'L_COLOR_TITLE' => 'Modify Topic Color',
'L_COLOR_TITLE' => '更改標題顏色',
'L_COLOR_EXPLAIN' => 'Specify the Topic Color in HEX format. Example = FFFFFF (white). Do NOT use a #',
'L_COLOR_EXPLAIN' => '將下方顏色列表中的代碼,填入標題顏色的格子中,在按送出皆可。',
'L_COLOR' => 'Topic Color',
'L_COLOR' => '標題顏色',
templates\subSilver\topic_color.tpl
Colour Pallette by Carlo Claessen
顏色列表
#-----[ SAVE AND UPLOAD ALL ]------------------------------------------
# EoM
.安裝及修正經驗
1.
吉川拓也 寫:如果有安裝Split_topic_type那就要改這兩個檔案 !
‧viewforum.php -> functions_topics_list.php
‧viewforum_body.tpl -> topics_list_box.tpl
而要找的 -> {topicrow.GOTO_PAGE}
就要改成找 -> {topics_list_box.row.GOTO_PAGE}
所以你就要將原本要加入的 {topicrow.A_TOPIC_COLOR}
將其改變陣列值為 {topics_list_box.row.A_TOPIC_COLOR}
2. 建議做以下修改,作用是讓點擊此回到此文章與指定顏色分隔
topiccolor.php
點擊此回到此文章
<br />點擊此回到此文章
.外掛下載
http://home.pchome.com.tw/net/xder_net/ ... r_hack.zip
http://www.phpbbhacks.com/download/2140
最後由 彬彬BinBin ] #14 於 2005-10-03 20:17 編輯,總共編輯了 1 次。
吉川拓也
文章: 1215
註冊時間: 2003-02-09 18:24
來自: [ G.I.T ]
文章 由 吉川拓也 »
額外修改 :lol:
原文章 : http://gamania.idv.tw/Lineage/viewtopic.php?t=2245
#--- [ 開啟 ] ---
topiccolor.php
#--- [ 找到 ] ---
#--- [ 取代 ] ---
'L_COLOR_TITLE' => $lang[Modify_Topic_Color],
#--- [ 找到 ] ---
#--- [ 取代 ] ---
'L_COLOR_EXPLAIN' => $lang['c_faq'],
#--- [ 找到 ] ---
#--- [ 取代 ] ---
'L_COLOR' => $lang['topic_color'],
#--- [ 找到 ] ---
Color '.$update_topic_color.' Updated. <a href = viewtopic.'.$phpEx.'?t='.$id.'>Click here to go to your topic.</a>
#--- [ 取代 ] ---
主題顏色 '.'#'. $update_topic_color.' 更新完成. <br />請點選 <a href = viewtopic.'.$phpEx.'?t='.$id.'>這裡</a> 返回主題.
#--- [ 開啟 ] ---
#--- [ 找到 ] ---
#--- [ 取代 ] ---
{L_COLOUR}
#--- [ 開啟 ] ---
language\lang_chinese_traditional_taiwan\lang_main.php
#--- [ 找到 ] ---
// That's all Folks!
#--- [ 上面加入 ] ---
$lang['c_color'] ='指定此主題顏色';
$lang['Modify_Topic_Color'] ='更改主題顏色';
$lang['c_faq'] = '您可藉由下方顏色色碼表,填入標題顏色的格子中,在點選送出即可.';
$lang['topic_color'] ='標題顏色';
$lang['colour'] ='色碼表';
#--- [ 儲存關閉 ] ---
# eom
另外如果色碼表太大撐開版面可以用吉川自己修改的色碼表來替換 ;-)
#--- [ 開啟 ] ---
topic_color.tpl
#--- [ 找到 ] ---
<table width="100%" cellspacing="0" cellpadding="2" border="0" align="center" class="forumline">
<th colspan="23">Colour Pallette by Carlo Claessen</th>
----- 中略\r
</table>
#--- [ 取代 ] ---
<br />
<table width="620" cellspacing="1" cellpadding="0" border="0" align="center" class="forumline">
  <td colspan="11" class="catLeft" height="25">{L_COLOUR}</td>
		<td align="middle" width="89" bgColor="#eeeeee" height="25">
		<font color="#000000">EEEEEE</font></td>
		<td align="middle" width="89" bgColor="#ff00cc" height="25">
		<font color="#400000">FF00CC</font></td>
		<td align="middle" width="90" bgColor="#ff66ff" height="25">
		<font color="#400000">FF66FF</font></td>
		<td align="middle" width="90" bgColor="#ff00ff" height="25">
		<font color="#400000">FF00FF</font></td>
		<td align="middle" width="89" bgColor="#dddddd" height="25">
		<font color="#000000">DDDDDD</font></td>
		<td align="middle" width="89" bgColor="#ffcccc" height="25">
		<font color="#400000">FFCCCC</font></td>
		<td align="middle" width="90" bgColor="#ff66cc" height="25">
		<font color="#400000">FF66CC</font></td>
		<td align="middle" width="90" bgColor="#ff00cc" height="25">
		<td align="middle" width="89" bgColor="#cccccc" height="25">
		<font color="#000000">CCCCCC</font></td>
		<td align="middle" width="89" bgColor="#ffcc99" height="25">
		<font color="#400000">FFCC99</font></td>
		<td align="middle" width="90" bgColor="#ff6699" height="25">
		<font color="#400000">FF6699</font></td>
		<td align="middle" width="90" bgColor="#ff0099" height="25">
		<font color="#400000">FF0099</font></td>
		<td align="middle" width="89" bgColor="#bbbbbb" height="25">
		<font color="#000000">BBBBBB</font></td>
		<td align="middle" width="89" bgColor="#ffcc66" height="25">
		<font color="#400000">FFCC66</font></td>
		<td align="middle" width="90" bgColor="#ff6666" height="25">
		<font color="#400000">FF6666</font></td>
		<td align="middle" width="90" bgColor="#ff0066" height="25">
		<font color="#400000">FF0066</font></td>
		<td align="middle" width="89" bgColor="#aaaaaa" height="25">
		<font color="#000000">AAAAAA</font></td>
		<td align="middle" width="89" bgColor="#ffcc33" height="25">
		<font color="#400000">FFCC33</font></td>
		<td align="middle" width="90" bgColor="#ff6633" height="25">
		<font color="#400000">FF6633</font></td>
		<td align="middle" width="90" bgColor="#ff0033" height="25">
		<font color="#400000">FF0033</font></td>
		<td align="middle" width="89" bgColor="#999999" height="25">
		<font color="#80ffff">999999</font></td>
		<td align="middle" width="89" bgColor="#ffcc00" height="25">
		<font color="#400000">FFCC00</font></td>
		<td align="middle" width="90" bgColor="#ff6600" height="25">
		<font color="#400000">FF6600</font></td>
		<td align="middle" width="90" bgColor="#ff0000" height="25">
		<font color="#400000">FF0000</font></td>
		<td align="middle" width="89" bgColor="#888888" height="25">
		<font color="#80ffff">888888</font></td>
		<td align="middle" width="89" bgColor="#ccccff" height="25">
		<font color="#000000">CCCCFF</font></td>
		<td align="middle" width="90" bgColor="#cc66ff" height="25">
		<font color="#000000">CC66FF</font></td>
		<td align="middle" width="90" bgColor="#cc00ff" height="25">
		<font color="#000000">CC00FF</font></td>
		<td align="middle" width="89" bgColor="#777777" height="25">
		<font color="#80ffff">777777</font></td>
		<td align="middle" width="90" bgColor="#cc66cc" height="25">
		<font color="#000000">CC66CC</font></td>
		<td align="middle" width="90" bgColor="#cc00cc" height="25">
		<font color="#000000">CC00CC</font></td>
		<td align="middle" width="89" bgColor="#666666" height="25">
		<font color="#80ffff">666666</font></td>
		<td align="middle" width="89" bgColor="#cccc99" height="25">
		<font color="#000000">CCCC99</font></td>
		<td align="middle" width="90" bgColor="#cc6699" height="25">CC6699</td>
		<td align="middle" width="90" bgColor="#cc0099" height="25">CC0099</td>
		<td align="middle" width="89" bgColor="#555555" height="25">
		<font color="#80ffff">555555</font></td>
		<td align="middle" width="89" bgColor="#cccc66" height="25">
		<font color="#000000">CCCC66</font></td>
		<td align="middle" width="90" bgColor="#cc6666" height="25">CC6666</td>
		<td align="middle" width="90" bgColor="#cc0066" height="25">CC0066</td>
		<td align="middle" width="89" bgColor="#444444" height="25">
		<font color="#80ffff">444444</font></td>
		<td align="middle" width="89" bgColor="#cccc33" height="25">
		<font color="#000000">CCCC33</font></td>
		<td align="middle" width="90" bgColor="#cc6633" height="25">CC6633</td>
		<td align="middle" width="90" bgColor="#cc0033" height="25">CC0033</td>
		<td align="middle" width="89" bgColor="#333333" height="25">
		<font color="#80ffff">333333</font></td>
		<td align="middle" width="89" bgColor="#cccc00" height="25">
		<font color="#000000">CCCC00</font></td>
		<td align="middle" width="90" bgColor="#cc6600" height="25">CC6600</td>
		<td align="middle" width="90" bgColor="#cc0000" height="25">CC0000</td>
		<td align="middle" width="89" bgColor="#222222" height="25">
		<font color="#80ffff">222222</font></td>
		<td align="middle" width="89" bgColor="#99ccff" height="25">
		<font color="#000000">99CCFF</font></td>
		<td align="middle" width="90" bgColor="#9966ff" height="25">9966FF</td>
		<td align="middle" width="90" bgColor="#9900ff" height="25">9900FF</td>
		<td align="middle" width="89" bgColor="#111111" height="25">
		<font color="#80ffff">111111</font></td>
		<td align="middle" width="89" bgColor="#99cccc" height="25">
		<font color="#000000">99CCCC</font></td>
		<td align="middle" width="90" bgColor="#9966cc" height="25">9966CC</td>
		<td align="middle" width="90" bgColor="#9900cc" height="25">9900CC</td>
		<td align="middle" width="89" bgColor="#000000" height="25">000000</td>
		<td align="middle" width="89" bgColor="#99cc99" height="25">
		<font color="#000000">99CC99</font></td>
		<td align="middle" width="90" bgColor="#996699" height="25">996699</td>
		<td align="middle" width="90" bgColor="#990099" height="25">990099</td>
		<td align="middle" width="89" bgColor="#ff0000" height="25">FF0000</td>
		<td align="middle" width="89" bgColor="#99cc66" height="25">
		<font color="#000000">99CC66</font></td>
		<td align="middle" width="90" bgColor="#996666" height="25">996666</td>
		<td align="middle" width="90" bgColor="#990066" height="25">990066</td>
		<td align="middle" width="89" bgColor="#ee0000" height="25">EE0000</td>
		<td align="middle" width="89" bgColor="#99cc33" height="25">
		<font color="#000000">99CC33</font></td>
		<td align="middle" width="90" bgColor="#996633" height="25">996633</td>
		<td align="middle" width="90" bgColor="#990033" height="25">990033</td>
		<td align="middle" width="89" bgColor="#dd0000" height="25">DD0000</td>
		<td align="middle" width="89" bgColor="#99cc00" height="25">
		<font color="#000000">99CC00</font></td>
		<td align="middle" width="90" bgColor="#996600" height="25">996600</td>
		<td align="middle" width="90" bgColor="#990000" height="25">990000</td>
		<td align="middle" width="89" bgColor="#cc0000" height="25">CC0000</td>
		<td align="middle" width="89" bgColor="#66ccff" height="25">
		<font color="#000000">66CCFF</font></td>
		<td align="middle" width="90" bgColor="#6666ff" height="25">6666FF</td>
		<td align="middle" width="90" bgColor="#6600ff" height="25">6600FF</td>
		<td align="middle" width="89" bgColor="#bb0000" height="25">BB0000</td>
		<td align="middle" width="89" bgColor="#66cccc" height="25">
		<font color="#000000">66CCCC</font></td>
		<td align="middle" width="90" bgColor="#6666cc" height="25">6666CC</td>
		<td align="middle" width="90" bgColor="#6600cc" height="25">6600CC</td>
		<td align="middle" width="89" bgColor="#aa0000" height="25">AA0000</td>
		<td align="middle" width="89" bgColor="#66cc99" height="25">
		<font color="#000000">66CC99</font></td>
		<td align="middle" width="90" bgColor="#666699" height="25">666699</td>
		<td align="middle" width="90" bgColor="#660099" height="25">660099</td>
		<td align="middle" width="89" bgColor="#990000" height="25">990000</td>
		<td align="middle" width="89" bgColor="#66cc66" height="25">
		<font color="#000000">66CC66</font></td>
		<td align="middle" width="90" bgColor="#666666" height="25">666666</td>
		<td align="middle" width="90" bgColor="#660066" height="25">660066</td>
		<td align="middle" width="89" bgColor="#880000" height="25">880000</td>
		<td align="middle" width="89" bgColor="#66cc33" height="25">
		<font color="#000000">66CC33</font></td>
		<td align="middle" width="90" bgColor="#666633" height="25">666633</td>
		<td align="middle" width="90" bgColor="#660033" height="25">660033</td>
		<td align="middle" width="89" bgColor="#770000" height="25">770000</td>
		<td align="middle" width="89" bgColor="#66cc00" height="25">
		<font color="#000000">66CC00</font></td>
		<td align="middle" width="90" bgColor="#666600" height="25">666600</td>
		<td align="middle" width="90" bgColor="#660000" height="25">660000</td>
		<td align="middle" width="89" bgColor="#660000" height="25">660000</td>
		<td align="middle" width="89" bgColor="#33ccff" height="25">
		<font color="#000000">33CCFF</font></td>
		<td align="middle" width="90" bgColor="#3366ff" height="25">3366FF</td>
		<td align="middle" width="90" bgColor="#3300ff" height="25">3300FF</td>
		<td align="middle" width="89" bgColor="#550000" height="25">550000</td>
		<td align="middle" width="89" bgColor="#33cccc" height="25">
		<font color="#000000">33CCCC</font></td>
		<td align="middle" width="90" bgColor="#3366cc" height="25">3366CC</td>
		<td align="middle" width="90" bgColor="#3300cc" height="25">3300CC</td>
		<td align="middle" width="89" bgColor="#440000" height="25">440000</td>
		<td align="middle" width="89" bgColor="#33cc99" height="25">
		<font color="#000000">33CC99</font></td>
		<td align="middle" width="90" bgColor="#336699" height="25">336699</td>
		<td align="middle" width="90" bgColor="#330099" height="25">330099</td>
		<td align="middle" width="89" bgColor="#330000" height="25">330000</td>
		<td align="middle" width="89" bgColor="#33cc66" height="25">
		<font color="#000000">33CC66</font></td>
		<td align="middle" width="90" bgColor="#336666" height="25">336666</td>
		<td align="middle" width="90" bgColor="#330066" height="25">330066</td>
		<td align="middle" width="89" bgColor="#220000" height="25">220000</td>
		<td align="middle" width="89" bgColor="#33cc33" height="25">
		<font color="#000000">33CC33</font></td>
		<td align="middle" width="90" bgColor="#336633" height="25">336633</td>
		<td align="middle" width="90" bgColor="#330033" height="25">330033</td>
		<td align="middle" width="89" bgColor="#110000" height="25">110000</td>
		<td align="middle" width="89" bgColor="#33cc00" height="25">
		<font color="#000000">33CC00</font></td>
		<td align="middle" width="90" bgColor="#336600" height="25">336600</td>
		<td align="middle" width="90" bgColor="#330000" height="25">330000</td>
		<td align="middle" width="89" bgColor="#ffffff" height="25">
		<font color="#000000">FFFFFF</font></td>
		<td align="middle" width="89" bgColor="#00ccff" height="25">
		<font color="#000000">00CCFF</font></td>
		<td align="middle" width="90" bgColor="#0066ff" height="25">0066FF</td>
		<td align="middle" width="90" bgColor="#0000ff" height="25">0000FF</td>
		<td align="middle" width="89" bgColor="#ffffcc" height="25">
		<font color="#000000">FFFFCC</font></td>
		<td align="middle" width="89" bgColor="#00cccc" height="25">
		<font color="#000000">00CCCC</font></td>
		<td align="middle" width="90" bgColor="#0066cc" height="25">0066CC</td>
		<td align="middle" width="90" bgColor="#0000cc" height="25">0000CC</td>
		<td align="middle" width="89" bgColor="#ffff99" height="25">
		<font color="#000000">FFFF99</font></td>
		<td align="middle" width="89" bgColor="#00cc99" height="25">
		<font color="#000000">00CC99</font></td>
		<td align="middle" width="90" bgColor="#006699" height="25">006699</td>
		<td align="middle" width="90" bgColor="#000099" height="25">000099</td>
		<td align="middle" width="89" bgColor="#ffff66" height="25">
		<font color="#000000">FFFF66</font></td>
		<td align="middle" width="89" bgColor="#00cc66" height="25">
		<font color="#000000">00CC66</font></td>
		<td align="middle" width="90" bgColor="#006666" height="25">006666</td>
		<td align="middle" width="90" bgColor="#000066" height="25">000066</td>
		<td align="middle" width="89" bgColor="#ffff33" height="25">
		<font color="#000000">FFFF33</font></td>
		<td align="middle" width="89" bgColor="#00cc33" height="25">
		<font color="#000000">00CC33</font></td>
		<td align="middle" width="90" bgColor="#006633" height="25">006633</td>
		<td align="middle" width="90" bgColor="#000033" height="25">000033</td>
		<td align="middle" width="89" bgColor="#ffff00" height="19">
		<font color="#000000">FFFF00</font></td>
		<td align="middle" width="89" bgColor="#00cc00" height="19">
		<font color="#000000">00CC00</font></td>
		<td align="middle" width="90" bgColor="#006600" height="19">006600</td>
		<td align="middle" width="90" bgColor="#000000" height="19">000000</td>
		<td align="middle" width="89" bgColor="#ccffff" height="25">
		<font color="#000000">CCFFFF</font></td>
		<td align="middle" width="89" bgColor="#ff99ff" height="25">
		<font color="#000000">FF99FF</font></td>
		<td align="middle" width="90" bgColor="#ff33ff" height="25">FF33FF</td>
		<td align="middle" width="90" bgColor="#00ff00" height="25">
		<font color="#000000">00FF00</font></td>
		<td align="middle" width="89" bgColor="#ccffcc" height="25">
		<font color="#000000">CCFFCC</font></td>
		<td align="middle" width="89" bgColor="#ff99cc" height="25">
		<font color="#000000">FF99CC</font></td>
		<td align="middle" width="90" bgColor="#ff33cc" height="25">FF33CC</td>
		<td align="middle" width="90" bgColor="#00ee00" height="25">
		<font color="#000000">00EE00</font></td>
		<td align="middle" width="89" bgColor="#ccff99" height="25">
		<font color="#000000">CCFF99</font></td>
		<td align="middle" width="89" bgColor="#ff9999" height="25">
		<font color="#000000">FF9999</font></td>
		<td align="middle" width="90" bgColor="#ff3399" height="25">FF3399</td>
		<td align="middle" width="90" bgColor="#00dd00" height="25">
		<font color="#000000">00DD00</font></td>
		<td align="middle" width="89" bgColor="#ccff66" height="25">
		<font color="#000000">CCFF66</font></td>
		<td align="middle" width="89" bgColor="#ff9966" height="25">
		<font color="#000000">FF9966</font></td>
		<td align="middle" width="90" bgColor="#ff3366" height="25">FF3366</td>
		<td align="middle" width="90" bgColor="#00cc00" height="25">
		<td align="middle" width="89" bgColor="#ccff33" height="25">
		<font color="#000000">CCFF33</font></td>
		<td align="middle" width="89" bgColor="#ff9933" height="25">
		<font color="#000000">FF9933</font></td>
		<td align="middle" width="90" bgColor="#ff3333" height="25">FF3333</td>
		<td align="middle" width="90" bgColor="#00bb00" height="25">
		<font color="#000000">00BB00</font></td>
		<td align="middle" width="89" bgColor="#ccff00" height="25">
		<font color="#000000">CCFF00</font></td>
		<td align="middle" width="89" bgColor="#ff9900" height="25">
		<font color="#000000">FF9900</font></td>
		<td align="middle" width="90" bgColor="#ff3300" height="25">FF3300</td>
		<td align="middle" width="90" bgColor="#00aa00" height="25">
		<font color="#000000">00AA00</font></td>
		<td align="middle" width="89" bgColor="#99ffff" height="25">
		<font color="#000000">99FFFF</font></td>
		<td align="middle" width="89" bgColor="#cc99ff" height="25">
		<font color="#000000">CC99FF</font></td>
		<td align="middle" width="90" bgColor="#cc33ff" height="25">CC33FF</td>
		<td align="middle" width="90" bgColor="#009900" height="25">
		<font color="#000000">990099</font></td>
		<td align="middle" width="89" bgColor="#99ffcc" height="25">
		<font color="#000000">99FFCC</font></td>
		<td align="middle" width="89" bgColor="#cc99cc" height="25">
		<font color="#000000">CC99CC</font></td>
		<td align="middle" width="90" bgColor="#cc33cc" height="25">CC33CC</td>
		<td align="middle" width="90" bgColor="#008800" height="25">008800</td>
		<td align="middle" width="89" bgColor="#99ff99" height="25">
		<font color="#000000">99FF99</font></td>
		<td align="middle" width="89" bgColor="#cc9999" height="25">
		<font color="#000000">CC9999</font></td>
		<td align="middle" width="90" bgColor="#cc3399" height="25">CC3399</td>
		<td align="middle" width="90" bgColor="#007700" height="25">007700</td>
		<td align="middle" width="89" bgColor="#99ff66" height="25">
		<font color="#000000">99FF66</font></td>
		<td align="middle" width="89" bgColor="#cc9966" height="25">
		<font color="#000000">CC9966</font></td>
		<td align="middle" width="90" bgColor="#cc3366" height="25">CC3366</td>
		<td align="middle" width="90" bgColor="#006600" height="25">006600</td>
		<td align="middle" width="89" bgColor="#99ff33" height="25">
		<font color="#000000">99FF33</font></td>
		<td align="middle" width="89" bgColor="#cc9933" height="25">
		<font color="#000000">CC9933</font></td>
		<td align="middle" width="90" bgColor="#cc3333" height="25">CC3333</td>
		<td align="middle" width="90" bgColor="#005500" height="25">005500</td>
		<td align="middle" width="89" bgColor="#99ff00" height="25">
		<font color="#000000">99FF00</font></td>
		<td align="middle" width="89" bgColor="#cc9900" height="25">
		<font color="#000000">CC9900</font></td>
		<td align="middle" width="90" bgColor="#cc3300" height="25">CC3300</td>
		<td align="middle" width="90" bgColor="#004400" height="25">004400</td>
		<td align="middle" width="89" bgColor="#66ffff" height="25">
		<font color="#000000">66FFFF</font></td>
		<td align="middle" width="89" bgColor="#9999ff" height="25">
		<font color="#000000">9999FF</font></td>
		<td align="middle" width="90" bgColor="#9933ff" height="25">9933FF</td>
		<td align="middle" width="90" bgColor="#003300" height="25">003300</td>
		<td align="middle" width="89" bgColor="#66ffcc" height="25">
		<font color="#000000">66FFCC</font></td>
		<td align="middle" width="89" bgColor="#9999cc" height="25">
		<font color="#80ffff">9999CC</font></td>
		<td align="middle" width="90" bgColor="#9933cc" height="25">9933CC</td>
		<td align="middle" width="90" bgColor="#002200" height="25">002200</td>
		<td align="middle" width="89" bgColor="#66ff99" height="25">
		<font color="#000000">66FF99</font></td>
		<td align="middle" width="90" bgColor="#993399" height="25">993399</td>
		<td align="middle" width="90" bgColor="#001100" height="25">001100</td>
		<td align="middle" width="89" bgColor="#66ff66" height="25">
		<font color="#000000">66FF66</font></td>
		<td align="middle" width="89" bgColor="#999966" height="25">
		<font color="#80ffff">999966</font></td>
		<td align="middle" width="90" bgColor="#993366" height="25">993366</td>
		<td align="middle" width="89" bgColor="#66ff33" height="19">
		<font color="#000000">66FF33</font></td>
		<td align="middle" width="89" bgColor="#999933" height="19">
		<font color="#80ffff">999933</font></td>
		<td align="middle" width="90" bgColor="#993333" height="19">993333</td>
		<td align="middle" width="90" bgColor="#0000ee" height="19">0000EE</td>
		<td align="middle" width="89" bgColor="#66ff00" height="19">
		<font color="#000000">66FF00</font></td>
		<td align="middle" width="89" bgColor="#999900" height="19">
		<font color="#80ffff">999900</font></td>
		<td align="middle" width="90" bgColor="#993300" height="19">993300</td>
		<td align="middle" width="90" bgColor="#0000dd" height="19">0000DD</td>
		<td align="middle" width="89" bgColor="#33ffff" height="19">
		<font color="#000000">33FFFF</font></td>
		<td align="middle" width="89" bgColor="#6699ff" height="19">
		<font color="#80ffff">6699FF</font></td>
		<td align="middle" width="90" bgColor="#6633ff" height="19">6633FF</td>
		<td align="middle" width="90" bgColor="#0000cc" height="19">0000CC</td>
		<td align="middle" width="89" bgColor="#33ffcc" height="19">
		<font color="#000000">33FFCC</font></td>
		<td align="middle" width="89" bgColor="#6699cc" height="19">
		<font color="#80ffff">6699CC</font></td>
		<td align="middle" width="90" bgColor="#6633cc" height="19">6633CC</td>
		<td align="middle" width="90" bgColor="#0000bb" height="19">0000BB</td>
		<td align="middle" width="89" bgColor="#33ff99" height="17">
		<font color="#000000">33FF99</font></td>
		<td align="middle" width="89" bgColor="#669999" height="17">
		<font color="#80ffff">669999</font></td>
		<td align="middle" width="90" bgColor="#663399" height="17">663399</td>
		<td align="middle" width="90" bgColor="#0000aa" height="17">0000AA</td>
		<td align="middle" width="89" bgColor="#33ff66" height="19">
		<font color="#000000">33FF66</font></td>
		<td align="middle" width="89" bgColor="#669966" height="19">
		<font color="#80ffff">669966</font></td>
		<td align="middle" width="90" bgColor="#663366" height="19">663366</td>
		<td align="middle" width="90" bgColor="#000099" height="19">000099</td>
		<td align="middle" width="89" bgColor="#33ff33" height="19">
		<font color="#000000">33FF33</font></td>
		<td align="middle" width="89" bgColor="#669933" height="19">
		<font color="#80ffff">669933</font></td>
		<td align="middle" width="90" bgColor="#663333" height="19">663333</td>
		<td align="middle" width="90" bgColor="#000088" height="19">000088</td>
		<td align="middle" width="89" bgColor="#33ff00" height="19">
		<font color="#000000">33FF00</font></td>
		<td align="middle" width="89" bgColor="#669900" height="19">
		<font color="#80ffff">669900</font></td>
		<td align="middle" width="90" bgColor="#663300" height="19">663300</td>
		<td align="middle" width="90" bgColor="#000077" height="19">000077</td>
		<td align="middle" width="89" bgColor="#00ffff" height="19">
		<font color="#000000">00FFFF</font></td>
		<td align="middle" width="89" bgColor="#3399ff" height="19">
		<font color="#000000">3399FF</font></td>
		<td align="middle" width="90" bgColor="#3333ff" height="19">3333FF</td>
		<td align="middle" width="90" bgColor="#000066" height="19">000066</td>
		<td align="middle" width="89" bgColor="#00ffcc" height="19">
		<font color="#000000">00FFCC</font></td>
		<td align="middle" width="89" bgColor="#3399cc" height="19">
		<font color="#000000">3399CC</font></td>
		<td align="middle" width="90" bgColor="#3333cc" height="19">3333CC</td>
		<td align="middle" width="90" bgColor="#000055" height="19">000055</td>
		<td align="middle" width="89" bgColor="#00ff99" height="19">
		<font color="#000000">00FF99</font></td>
		<td align="middle" width="89" bgColor="#339999" height="19">
		<font color="#000000">339999</font></td>
		<td align="middle" width="90" bgColor="#333399" height="19">333399</td>
		<td align="middle" width="90" bgColor="#000044" height="19">000044</td>
		<td align="middle" width="89" bgColor="#00ff66" height="19">
		<font color="#000000">00FF66</font></td>
		<td align="middle" width="89" bgColor="#339966" height="19">
		<font color="#000000">339966</font></td>
		<td align="middle" width="90" bgColor="#333366" height="19">333366</td>
		<td align="middle" width="90" bgColor="#000033" height="19">000033</td>
		<td align="middle" width="89" bgColor="#00ff33" height="19">
		<font color="#000000">00FF33</font></td>
		<td align="middle" width="89" bgColor="#339933" height="19">
		<font color="#000000">339933</font></td>
		<td align="middle" width="90" bgColor="#333333" height="19">333333</td>
		<td align="middle" width="90" bgColor="#000022" height="19">000022</td>
		<td align="middle" width="89" bgColor="#00ff00" height="19">
		<td align="middle" width="89" bgColor="#339900" height="19">
		<font color="#000000">339900</font></td>
		<td align="middle" width="90" bgColor="#333300" height="19">333300</td>
		<td align="middle" width="90" bgColor="#000011" height="19">000011</td>
		<td align="middle" width="89" bgColor="#0099ff" height="19">
		<font color="#000000">0099FF</font></td>
		<td align="middle" width="89" bgColor="#0033ff" height="19">
		<font color="#80ffff">0033FF</font></td>
		<td align="middle" width="90" bgColor="#0099cc" height="19">
		<font color="#000000">0099CC</font></td>
		<td align="middle" width="90" bgColor="#0033cc" height="19">
		<font color="#80ffff">0033CC</font></td>
		<td align="middle" width="89" bgColor="#009999" height="19">009999</td>
		<td align="middle" width="89" bgColor="#003399" height="19">003399</td>
		<td align="middle" width="90" bgColor="#009966" height="19">009966</td>
		<td align="middle" width="90" bgColor="#003366" height="19">003366</td>
		<td align="middle" width="89" bgColor="#009933" height="19">009933</td>
		<td align="middle" width="89" bgColor="#003333" height="19">003333</td>
		<td align="middle" width="90" bgColor="#009900" height="19">009900</td>
		<td align="middle" width="90" bgColor="#003300" height="19">003300</td>
</table>
#--- [ 儲存關閉 ] ---
# eom
善用 搜尋 可以解決您 90% 的問題
頭腦清晰,選擇正確。 (╯▔︹▔)╯~╘═╛
回到「非官方認證外掛」
