[外掛] Minimum And Maximum Post Message Length (發文最短、最長字數限制)
文章: 911
文章 阿維 » 2007-04-22 14:29
檔頭:
## EasyMod 0.0.7 compliant
## MOD Title: Minimum And Maximum Post Message Length
## MOD Author: Leuchte < mail@leuchte.net > http://www.leuchte.net
## MOD Description: This Mod allows you to require a minimum and maximum amount of characters in a post.
## MOD Version: 1.0.1
## Installation Level: Easy
## Installation Time: < 5 Minutes
## Files To Edit: 6
lang_main.php, lang_admin.php, admin_board.php, functions_post.php, board_config_body.tpl
## Included Files: 0
## For Security Purposes, Please Check: http://www.leuchte.net/mods/ for the
## latest version of this MOD.
## ToDo: - Determine forums in ACP, which excluded by length-restriction
## MOD History:
##   2004-03-06 - Version 1.0.1
##      - Postlength also included with 'edit-Post'
##      - 'Whitespaces' are not counted
說明:
這個外掛可以從後台設定發文最短、最長字數限制
檔案下載:
下載點
回到「非官方認證外掛」
