[原創][外掛]簡易型機器人終結者
shihchieh
文章: 509
註冊時間: 2002-10-07 13:02
[原創][外掛]簡易型機器人終結者
文章 由 shihchieh »
## Title : Robot Don`t Touch Me Again
## Author : yuan < sniperlan@msn.com >
## Installation Level : Very Easy
## Installation Time : 1 minutes
## Don`t change any words, program, copyright or filename of this mod before get my permissions
## If you change or post this mod that you can`t get my support
## Please backup your phpbb before install this mod
OPEN includes/usercp_register.php
FIND
	$username = ( !empty($HTTP_POST_VARS['username']) ) ? phpbb_clean_username($HTTP_POST_VARS['username']) : '';
REPLACE
	$clean = ( isset($HTTP_GET_VARS['clean']) ) ? $HTTP_GET_VARS['clean']:$HTTP_POST_VARS['clean'];
	if( empty($clean) )
FIND
$lang['Fields_empty']
AFTER ADD
 . ( ( !empty($clean) ) ? '<br />' . $lang['cleantoregister']:'' );
FIND
AFTER ADD
FIND
		'SMILIES_STATUS' => $smilies_status,
AFTER ADD
		'CLEANTOREGISTER' => ( $mode == 'register' ) ? $lang['cleantoregister']:'',
SAVE AND CLOSE
OPEN templates/subSilver/profile_add_body.tpl
FIND
		<td class="row1" colspan="2"><span class="gensmall">{L_ITEMS_REQUIRED}</span></td>
REPLACE
		<td class="row2"><input type="text" class="post" style="width:200px" name="clean" size="25" maxlength="25" value="{CLEANTOREGISTER}" onclick="this.value='';" /></td>
SAVE AND CLOSE
OPEN language/lang_chinese_traditional_taiwan/lang_main.php
FIND
// That's all Folks!
BEFORE ADD
$lang['cleantoregister'] = '請點此將欄位留白後註冊才會成功';
SAVE AND CLOSE
要註冊的會員只需滑鼠點該欄位使其留白後即可,未留白則會把設定會會員名稱清除造成註冊失敗,此方法是一定要"手動"點選而無法使用傳遞混過
Do you fear death ?
回到「非官方認證外掛」
