想請問一下有人知道這是什麼意思嗎?我滴首頁連結一直有出問題今天去phpMyAdmin 看出現以下訊息\r
The mbstring PHP extension was not found and you seem to be using multibyte charset. Without mbstring extension phpMyAdmin is unable to split strings correctly and it may result in unexpected results.
[問題] phpMyAdmin 求助
