chiouss 寫:你把 Apache 和 MySQL 都 stop & start 一次,Apache 不要直接用 restart。然後,碰到這種情形記得要先看你的 access.log 和 error.log
STOP & STAR一次之後情況一樣
[Sun Mar 11 12:03:19 2007] [notice] Parent: Received shutdown signal -- Shutting down the server.
[Sun Mar 11 12:03:19 2007] [notice] Child 2496: Exit event signaled. Child process is ending.
[Sun Mar 11 12:03:20 2007] [notice] Child 2496: Released the start mutex
[Sun Mar 11 12:03:21 2007] [notice] Child 2496: Waiting for 250 worker threads to exit.
[Sun Mar 11 12:03:21 2007] [notice] Child 2496: All worker threads have exited.
[Sun Mar 11 12:03:21 2007] [notice] Child 2496: Child process is exiting
[Sun Mar 11 12:03:21 2007] [notice] Parent: Child process exited successfully.
[Sun Mar 11 12:03:40 2007] [notice] Apache/2.0.59 (Win32) PHP/4.4.5 configured -- resuming normal operations
[Sun Mar 11 12:03:40 2007] [notice] Server built: Jul 27 2006 15:55:03
[Sun Mar 11 12:03:40 2007] [notice] Parent: Created child process 4568
[Sun Mar 11 12:03:40 2007] [notice] Child 4568: Child process is running
[Sun Mar 11 12:03:40 2007] [notice] Child 4568: Acquired the start mutex.
[Sun Mar 11 12:03:40 2007] [notice] Child 4568: Starting 250 worker threads.
[Sun Mar 11 12:03:41 2007] [error] [client 66.249.65.131] script 'C:/AppServ/www/faq.php' not found or unable to stat
[Sun Mar 11 12:04:57 2007] [error] [client 66.249.65.131] script 'C:/AppServ/www/memcp.php' not found or unable to stat
[Sun Mar 11 12:05:03 2007] [error] [client 66.249.65.131] File does not exist: C:/AppServ/www/kaifungz.no-ip.org
[Sun Mar 11 12:05:24 2007] [error] [client 66.249.65.131] File does not exist: C:/AppServ/www/kaifungz.no-ip.org
[Sun Mar 11 12:06:16 2007] [error] [client 66.249.65.131] script 'C:/AppServ/www/register.php' not found or unable to stat
[Sun Mar 11 12:07:26 2007] [error] [client 66.249.65.131] File does not exist: C:/AppServ/www/kaifungz.no-ip.org
[Sun Mar 11 12:07:37 2007] [error] [client 66.249.65.131] script 'C:/AppServ/www/stats.php' not found or unable to stat
[Sun Mar 11 12:07:47 2007] [error] [client 66.249.65.131] File does not exist: C:/AppServ/www/kaifungz.no-ip.org
[Sun Mar 11 12:08:27 2007] [error] [client 66.249.65.131] script 'C:/AppServ/www/stats.php' not found or unable to stat
原來有很多錯誤=.=
66.249.65.131 - - [11/Mar/2007:12:05:24 +0800] "GET /kaifungz.no-ip.org?sid=LJsy6n HTTP/1.1" 404 309
66.249.65.131 - - [11/Mar/2007:12:06:16 +0800] "GET /register.php?sid=c4VuYN HTTP/1.1" 404 303
66.249.65.131 - - [11/Mar/2007:12:07:26 +0800] "GET /kaifungz.no-ip.org?sid=Js0XL5 HTTP/1.1" 404 309
66.249.65.131 - - [11/Mar/2007:12:07:37 +0800] "GET /stats.php?sid=LWOMHw HTTP/1.1" 404 300
66.249.65.131 - - [11/Mar/2007:12:07:47 +0800] "GET /kaifungz.no-ip.org?sid=rblNoP HTTP/1.1" 404 309
66.249.65.131 - - [11/Mar/2007:12:08:27 +0800] "GET /stats.php?type=creditsrank&sid=ELvOn2 HTTP/1.1" 404 300
66.249.65.131 - - [11/Mar/2007:12:09:06 +0800] "GET /faq.php?sid=fLO3dn HTTP/1.1" 404 298
66.249.65.131 - - [11/Mar/2007:12:09:24 +0800] "GET /register.php?sid=eqlcbE HTTP/1.1" 404 303
66.249.65.131 - - [11/Mar/2007:12:09:56 +0800] "GET /kaifungz.no-ip.org?sid=yV6fkK HTTP/1.1" 404 309
66.249.65.131 - - [11/Mar/2007:12:10:30 +0800] "GET /kaifungz.no-ip.org?sid=4YrSQQ HTTP/1.1" 404 309
66.249.65.131 - - [11/Mar/2007:12:10:32 +0800] "GET /index.php?sid=UUWbRP HTTP/1.1" 200 3439
66.249.65.131 - - [11/Mar/2007:12:11:58 +0800] "GET /memcp.php?action=buddylist&sid=zrpvF4 HTTP/1.1" 404 300
66.249.65.131 - - [11/Mar/2007:12:12:32 +0800] "GET /register.php?sid=bkI3eG HTTP/1.1" 404 303
66.249.65.131 - - [11/Mar/2007:12:13:10 +0800] "GET /kaifungz.no-ip.org?sid=KY3mRN HTTP/1.1" 404 309
66.249.65.131 - - [11/Mar/2007:12:13:13 +0800] "GET /kaifungz.no-ip.org?sid=O5U6Zw HTTP/1.1" 404 309
66.249.65.131 - - [11/Mar/2007:12:13:20 +0800] "GET /faq.php?page=using&sid=ub5mky HTTP/1.1" 404 298
66.249.65.131 - - [11/Mar/2007:12:13:25 +0800] "GET /memcp.php?sid=RKUjl0 HTTP/1.1" 404 300
66.249.65.131 - - [11/Mar/2007:12:14:37 +0800] "GET /faq.php?sid=EKEszz HTTP/1.1" 404 298
66.249.65.131 - - [11/Mar/2007:12:15:28 +0800] "GET /memcp.php?action=buddylist&sid=pyRFpo HTTP/1.1" 404 300
66.249.65.131 - - [11/Mar/2007:12:15:39 +0800] "GET /register.php?sid=pu0hCI HTTP/1.1" 404 303
66.249.65.131 - - [11/Mar/2007:12:16:21 +0800] "GET /kaifungz.no-ip.org?sid=f5zV9w HTTP/1.1" 404 309
66.249.65.131 - - [11/Mar/2007:12:16:23 +0800] "GET /stats.php?sid=PqFow7 HTTP/1.1" 404 300
66.249.65.131 - - [11/Mar/2007:12:16:24 +0800] "GET /kaifungz.no-ip.org?sid=lKFLyX HTTP/1.1" 404 309
66.249.65.131 - - [11/Mar/2007:12:16:31 +0800] "GET /faq.php?sid=48S3Jl HTTP/1.1" 404 298
66.249.65.131 - - [11/Mar/2007:12:18:38 +0800] "GET /kaifungz.no-ip.org?sid=MjKLaP HTTP/1.1" 404 309
66.249.65.131 - - [11/Mar/2007:12:18:59 +0800] "GET /stats.php?type=creditsrank&sid=QmEN0G HTTP/1.1" 404 300
66.249.65.131 - - [11/Mar/2007:12:19:02 +0800] "GET /faq.php?sid=0EdNmF HTTP/1.1" 404 298
66.249.65.131 - - [11/Mar/2007:12:19:14 +0800] "GET /memcp.php?sid=jboJWK HTTP/1.1" 404 300
問題應該在stat.php 那些我沒有的php=.= 這是什麼來的 要在那找回來
