[問題]請問phpMyAdmin 2.2.6的config該如何設?
phpMyAdmin Running Discuss
阿尼
註冊時間: 2002-07-09 17:48
來自: 南方公園
文章 阿尼 »
請問phpMyAdmin 2.2.6的config該如何設? ;-)
文章 小竹子 »
先搜尋一下吧!
阿尼
來自: 南方公園
[問題]phpMyAdmin 的錯誤訊息
文章 阿尼 »
>>phpMyAdmin 的錯誤訊息....這是哪裡沒設定好嗎?<<
歡迎使用 phpMyAdmin 2.2.6
Warning: Cannot add header information - headers already sent by (output started at C:\Apache\htdocs\phpmyadmin\libraries\auth\config.auth.lib.php:91) in C:\Apache\htdocs\phpmyadmin\header.inc.php on line 23
Warning: Cannot add header information - headers already sent by (output started at C:\Apache\htdocs\phpmyadmin\libraries\auth\config.auth.lib.php:91) in C:\Apache\htdocs\phpmyadmin\header.inc.php on line 24
Warning: Cannot add header information - headers already sent by (output started at C:\Apache\htdocs\phpmyadmin\libraries\auth\config.auth.lib.php:91) in C:\Apache\htdocs\phpmyadmin\header.inc.php on line 25
Warning: Cannot add header information - headers already sent by (output started at C:\Apache\htdocs\phpmyadmin\libraries\auth\config.auth.lib.php:91) in C:\Apache\htdocs\phpmyadmin\header.inc.php on line 26
Warning: Cannot add header information - headers already sent by (output started at C:\Apache\htdocs\phpmyadmin\libraries\auth\config.auth.lib.php:91) in C:\Apache\htdocs\phpmyadmin\header.inc.php on line 27
Warning: Cannot add header information - headers already sent by (output started at C:\Apache\htdocs\phpmyadmin\libraries\auth\config.auth.lib.php:91) in C:\Apache\htdocs\phpmyadmin\header.inc.php on line 29
錯誤
MySQL 傳回:
Access denied for user: 'root@localhost' (Using password: YES)
阿尼
來自: 南方公園
文章 阿尼 »
錯誤
MySQL 傳回:
阿尼
來自: 南方公園
文章 阿尼 »
YA.....搞定了^^
回到「phpMyAdmin」
