忽略Appserv 关于PHPMYADMIN
AppServ Running Discuss
cnnanrenne
註冊時間: 2007-02-05 19:01
文章 由 cnnanrenne »
我什么都设置好了,但是为什么我开我的PHP只显示文本的东西
<?php
/* $Id: index.php 9831 2007-01-09 09:49:30Z nijel $ */
// vim: expandtab sw=4 ts=4 sts=4:
* forms frameset
* @uses libraries/common.lib.php global fnctions
* @uses libraries/relation.lib.php table relations
* @uses $GLOBALS['strNoFrames']
* @uses $GLOBALS['cfg']['QueryHistoryDB']
* @uses $GLOBALS['cfg']['Server']['user']
* @uses $GLOBALS['cfg']['DefaultTabServer'] as src for the mainframe
* @uses $GLOBALS['cfg']['DefaultTabDatabase'] as src for the mainframe
* @uses $GLOBALS['cfg']['NaviWidth'] for navi frame width
* @uses $GLOBALS['collation_connection'] from $_REQUEST (grab_globals.lib.php)
* or common.lib.php
* @uses $GLOBALS['available_languages'] from common.lib.php (select_lang.lib.php)
* @uses $GLOBALS['db']
* @uses $GLOBALS['charset']
* @uses $GLOBALS['lang']
* @uses $GLOBALS['text_dir']
* @uses $_ENV['HTTP_HOST']
* @uses PMA_getRelationsParam()
* @uses PMA_purgeHistory()
* @uses PMA_generate_common_url()
* @uses PMA_VERSION
* @uses session_write_close()
* @uses time()
* @uses PMA_getenv()
* @uses header() to send charset
* Gets core libraries and defines some variables
require_once './libraries/common.lib.php';
* Includes the ThemeManager if it hasn't been included yet
require_once './libraries/relation.lib.php';
// free the session file, for the other frames to be loaded
session_write_close();
// Gets the host name
// loic1 - 2001/25/11: use the new globals arrays defined with php 4.1+
if (empty($HTTP_HOST)) {
if (PMA_getenv('HTTP_HOST')) {
$HTTP_HOST = PMA_getenv('HTTP_HOST');
} else {
$HTTP_HOST = '';
// purge querywindow history
$cfgRelation = PMA_getRelationsParam();
if ($GLOBALS['cfg']['QueryHistoryDB'] && $cfgRelation['historywork']) {
PMA_purgeHistory( $GLOBALS['cfg']['Server']['user'] );
unset($cfgRelation);
* pass variables to child pages
$drops = array('lang', 'server', 'convcharset', 'collation_connection',
'db', 'table');
foreach ($drops as $each_drop) {
if (! array_key_exists($each_drop, $_GET)) {
unset($_GET[$each_drop]);
unset($drops, $each_drop);
if (! isset($GLOBALS['db']) || ! strlen($GLOBALS['db'])) {
$main_target = $GLOBALS['cfg']['DefaultTabServer'];
} elseif (! isset($GLOBALS['table']) || ! strlen($GLOBALS['table'])) {
$_GET['db'] = $GLOBALS['db'];
$main_target = $GLOBALS['cfg']['DefaultTabDatabase'];
} else {
$_GET['table'] = $GLOBALS['table'];
$main_target = $GLOBALS['cfg']['DefaultTabTable'];
$url_query = PMA_generate_common_url($_GET);
if (isset($GLOBALS['target']) && is_string($GLOBALS['target']) && !empty($GLOBALS['target']) && in_array($GLOBALS['target'], $goto_whitelist)) {
$main_target = $GLOBALS['target'];
$main_target .= $url_query;
$lang_iso_code = $GLOBALS['available_languages'][$GLOBALS['lang']][2];
// start output
header('Content-Type: text/html; charset=' . $GLOBALS['charset']);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Frameset//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-frameset.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"
xml:lang="<?php echo $lang_iso_code; ?>"
dir="<?php echo $GLOBALS['text_dir']; ?>">
<head>
<link rel="icon" href="./favicon.ico" type="image/x-icon" />
<link rel="shortcut icon" href="./favicon.ico" type="image/x-icon" />
<title>phpMyAdmin <?php echo PMA_VERSION; ?> -
<?php echo htmlspecialchars($HTTP_HOST); ?></title>
<meta http-equiv="Content-Type"
content="text/html; charset=<?php echo $GLOBALS['charset']; ?>" />
<script type="text/javascript" language="javascript">
// <![CDATA[
// definitions used in querywindow.js
var common_query = '<?php echo PMA_escapeJsString(PMA_generate_common_url('', '', '&'));?>';
var opendb_url = '<?php echo PMA_escapeJsString($GLOBALS['cfg']['DefaultTabDatabase']); ?>';
var safari_browser = <?php echo PMA_USR_BROWSER_AGENT == 'SAFARI' ? 'true' : 'false' ?>;
var querywindow_height = <?php echo PMA_escapeJsString($GLOBALS['cfg']['QueryWindowHeight']); ?>;
var querywindow_width = <?php echo PMA_escapeJsString($GLOBALS['cfg']['QueryWindowWidth']); ?>;
var collation_connection = '<?php echo PMA_escapeJsString($GLOBALS['collation_connection']); ?>';
var lang = '<?php echo PMA_escapeJsString($GLOBALS['lang']); ?>';
var server = '<?php echo PMA_escapeJsString($GLOBALS['server']); ?>';
var table = '<?php echo PMA_escapeJsString($GLOBALS['table']); ?>';
var db = '<?php echo PMA_escapeJsString($GLOBALS['db']); ?>';
var text_dir = '<?php echo PMA_escapeJsString($GLOBALS['text_dir']); ?>';
var pma_absolute_uri = '<?php echo PMA_escapeJsString($GLOBALS['cfg']['PmaAbsoluteUri']); ?>';
</script>
<script src="./js/querywindow.js" type="text/javascript" language="javascript">
</script>
</head>
<frameset cols="<?php
if ($GLOBALS['text_dir'] === 'rtl') {
echo '*,';
echo $GLOBALS['cfg']['NaviWidth'];
if ($GLOBALS['text_dir'] === 'ltr') {
echo ',*';
?>" rows="*" id="mainFrameset">
<?php if ($GLOBALS['text_dir'] === 'ltr') { ?>
<frame frameborder="0" id="frame_navigation"
src="left.php<?php echo $url_query; ?>"
name="frame_navigation" />
<?php } ?>
<frame frameborder="0" id="frame_content"
src="<?php echo $main_target; ?>"
name="frame_content" />
<?php if ($GLOBALS['text_dir'] === 'rtl') { ?>
<?php } ?>
<noframes>
<body>
<p><?php echo $GLOBALS['strNoFrames']; ?></p>
</body>
</noframes>
</frameset>
// <![CDATA[
var frame_content = window.frames[1];
var frame_navigation = window.frames[0];
<?php } else { ?>
var frame_content = window.frames[0];
var frame_navigation = window.frames[1];
<?php } ?>
</script>
</html>
我的界压文件内不包含什么HTTP.CONFIG 前边有人说查看这的相关设置
我是在华军提供的phpMyAdmin 2.9.2是最新版本 (http://www.newhua.com/soft/2622.htm)
没安装什么Appserv 我有IIS5.1和SQL4.0.15(别说不支持)
回到「AppServ」
