●快速架站程式:Appserv 2.5.7
我在我的電腦上跑WordPress、Xoops
因為懶惰,把Control Server by Manual底下的Apache Start以及MySql Start兩個執行序拉到啟動列裡面,讓它開機自動開伺服器
這一切似乎沒有什麼問題,但是前幾天我連自己的網頁赫然發現:
This page cannot be displayed due to an internal error.
If you are the administrator of this site, please visit the Xoops Troubleshooting Page for assistance.
Helpful infomation you should provide while asking for assistance:
Error [Xoops]: Unable to connect to database in file C:\AppServ\www\xoops\class\database\databasefactory.php line 34代碼: 選擇全部
Error establishing a database connection
This either means that the username and password information in your wp-config.php file is incorrect or we can't contact the database server at localhost. This could mean your host's database server is down.
Are you sure you have the correct username and password?
Are you sure that you have typed the correct hostname?
Are you sure that the database server is running?
If you're unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress Support Forums.
請問這是什麼問題?有沒有辦法解決?
我的Appserv資訊
