[問題]圖片驗證CAPTCHA『解決』
Re: [問題]圖片驗證CAPTCHA
必須從字型檔下手, 它的原理就是到 captcha\fonts 目錄下去讀出以下四個字型檔S-h L 寫:如何在PLUS裡將CAPTCHA的功能關閉阿
雖然那是安全機制
但是只要打錯一次密碼就會出現
他的圖片難度太高了(0&O、B&8)
以致於難以登入
造成會員的不滿
PLUS乃是目前最新的1.53版
請教一下,謝謝
1. assimila.ttf
2. elephant.ttf
3. swash_normal.ttf
4. trekker_regular.ttf
除非你可以找到一個字型檔內的 0 跟 O 是可以輕易辨識的, 就可以 rename 來覆蓋那四個檔了, 要不然就是到後台內的 CAPTCHA 設定 中關畢
啟動字體陰影 及 啟用隨機字體 這兩項, 讓圖型產生不要太複雜!!
PHPBB 2.0.21 可以關閉此功能,但是 PLUS 似乎改的有點複雜,尚未查出可以修改的地方,試過直接改資料庫的值,但是無效 -.-||
PLUS 1.53 關閉註冊確認碼(CAPTCHA)的方法
進入後台,點選 [PLUS] [基本組態]
[啟用 Robot 檢查] 選取 否
[啟用 Robot 檢查] 選取 否
要猜拆掉它的話, 來請照以下步驟作S-h L 寫:那這樣我很想拆了他
會員都被他搞到無法進入
可以交我要找那個版本的文件把他拆了= =
因為圖片驗證連圖片也顯示不出來
只有少數特定的看的到而已
就是那少數幾個我看不到
難怪無法登入
## MOD Title: Update CrackerTracker v4.x to CrackerTracker v5.x
## MOD Author: cback < webmaster@cback.de > (Christian Knerr) http://www.cback.de
## MOD Description: This MOD helps you to completely remove CrackerTracker v4.x from
## your forum to install the new Generation 5.x CrackerTracker.
## after you have done this Modification you have to do everything
## from the normal install.txt in the main Folder of this MOD!
## Installation Level: Easy
## Installation Time: 14 Minutes
## License: http://opensource.org/licenses/gpl-license.php GNU General Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
#-----[ DIY INSTRUCTIONS ]------------------------------------------
Please delete these files from your board. You will loose the Logfiles and the
Settings because CrackerTracker v5.x completely changed!
- admin/admin_ct_blocker.php
- admin/admin_ct_config.php
- admin/admin_ct_footer.php
- admin/admin_ct_logs.php
- admin/admin_ct_seccheck.php
- admin/admin_ct_systest.php
- ctracker/
- language/lang_english/lang_ctracker.php
- language/lang_german/lang_ctracker.php
- templates/subSilver/admin/ct_blocker.tpl
- templates/subSilver/admin/ct_config.tpl
- templates/subSilver/admin/ct_footer.tpl
- templates/subSilver/admin/ct_logs_1.tpl
- templates/subSilver/admin/ct_logs_2.tpl
- templates/subSilver/admin/ct_logs_3.tpl
- templates/subSilver/admin/ct_logs_4.tpl
- templates/subSilver/admin/ct_seccheck.tpl
- templates/subSilver/admin/ct_systest.tpl
common.php
#-----[ FIND AND DELETE ]------------------------------------------
// CBACK.de CrackerTracker
// Worm&Exploit Protection Engine
include($phpbb_root_path . "ctracker/ct_security." . $phpEx);
// Proxy&IP Blocker and Function File
include($phpbb_root_path . 'ctracker/ct_ipblocker.'.$phpEx);
include($phpbb_root_path . 'ctracker/ct_functions.'.$phpEx);
includes/functions.php
include($phpbb_root_path . 'language/lang_' . $board_config['default_lang'] . '/lang_ctracker.' . $phpEx);
includes/page_tail.php
include($phpbb_root_path . 'ctracker/ct_footer.'.$phpEx);
includes/constants.php
// CBACK CrackerTracker Professional
define('CTRACK', $table_prefix.'ctrack');
define('CTFILTER', $table_prefix.'ct_filter');
define('CTVISKEY', $table_prefix.'ct_viskey');
templates/subSilver/overall_footer.tpl
<!-- BEGIN cback_cracker_tracker -->
<div align="center"><span class="copyright"><br />
{cback_cracker_tracker.CTRACKER_FOOTER}
<br />
</span></div>
<!-- END cback_cracker_tracker -->
search.php
// CBACK CrackerTracker Search Flood Protection
if(($userdata['ct_searchtime'] > time()) and (!empty($HTTP_GET_VARS['search_id']) || isset($HTTP_POST_VARS['search_id']) || isset($HTTP_GET_VARS['search_keywords']) || isset($HTTP_POST_VARS['show_results'])))
$waittime = 0;
$waittime = $userdata['ct_searchtime'] - time();
$waitmsg = '';
$waitmsg = sprintf($lang['ct_forum_sfl'], $ctracker_config['searchtime'], $waittime);
if($userdata['user_id'] == ANONYMOUS)
message_die(GENERAL_MESSAGE, $waitmsg);
$sql = "UPDATE " . USERS_TABLE . " SET ct_searchcount = ct_searchcount + 1 WHERE user_id = " . $userdata['user_id'];
message_die(CRITICAL_ERROR, "Could not perform Database operation", "", __LINE__, __FILE__, $sql);
if($userdata['ct_searchcount'] >= $ctracker_config['maxsearch'] && $userdata['ct_searchtime'] > time())
if($userdata['ct_searchcount'] == $ctracker_config['maxsearch'])
$stime = time() + $ctracker_config['searchtime'];
$sql = "UPDATE " . USERS_TABLE . " SET ct_searchtime = " . $stime . " WHERE user_id = " . $userdata['user_id'];
if( !$db->sql_query($sql))
if(isset($HTTP_POST_VARS['mode']) || isset($HTTP_GET_VARS['mode']) || !empty($HTTP_GET_VARS['search_id']) || isset($HTTP_POST_VARS['search_id']) || isset($HTTP_GET_VARS['search_keywords']) || isset($HTTP_POST_VARS['show_results']))
if($userdata['ct_searchtime'] <= time())
if($userdata['user_id'] != ANONYMOUS)
$sql = "UPDATE " . USERS_TABLE . " SET ct_searchcount = 1 WHERE user_id = " . $userdata['user_id'];
$sucheck = strtolower($highlight_active);
$sucheck = str_replace($ct_rules, '*', $sucheck);
if($sucheck != $highlight_active)
$highlight_active = '';
includes/usercp_register.php
// CBACK CrackerTracker Register Flood Protection
if($ctracker_config['regblock'] == 1 && $HTTP_GET_VARS['mode'] == 'register')
if($ctracker_config['lastreg'] >= time())
$lregtimestamp = $ctracker_config['lastreg'];
$waittime = 0;
$waittime = $lregtimestamp - time();
$waitmsg = '';
$waitmsg = sprintf($lang['ct_forum_rfl'], $waittime);
if(!empty($HTTP_SERVER_VARS['REMOTE_ADDR']) && $ctracker_config['lastreg_ip'] == $HTTP_SERVER_VARS['REMOTE_ADDR'])
// If the same IP wants to register we block this for 400 Seconds
if($ctracker_config['lastreg'] + 400 >= time())
message_die(GENERAL_MESSAGE, $lang['ct_forum_ifl']);
$stime = time() + $ctracker_config['regtime'];
$sql = "UPDATE " . CTRACK . " SET value = " . $stime . " WHERE name = 'lastreg'";
$db->sql_query($sql);
if(!empty($HTTP_SERVER_VARS['REMOTE_ADDR']))
$sql = "UPDATE " . CTRACK . " SET value = '" . $HTTP_SERVER_VARS['REMOTE_ADDR'] . "' WHERE name = 'lastreg_ip'";
// END CBACK CrackerTracker Register Flood Protection
includes/functions_post.php
global $ctracker_config;
#-----[ FIND AND DELETE]------------------------------------------
// CBACK CrackerTracker Spammer Protection Engine
$ctinfomeldung = '';
if(($mode == 'newtopic' || $mode == 'reply') and ($ctracker_config['floodprot'] == 1))
if($userdata['user_level'] == 0 && $userdata['user_id'] != ANONYMOUS)
if($userdata['ct_posttime'] >= time())
if($userdata['ct_postcount'] > $ctracker_config['postintime'])
if($ctracker_config['autoban'] == 1)
ct_filllog();
$sql = "INSERT INTO " . BANLIST_TABLE . "( `ban_id` , `ban_userid` , `ban_ip` , `ban_email` ) VALUES ('', '" . $userdata['user_id'] . "', '', NULL);";
session_end($userdata['session_id'], $userdata['user_id']);
ct_filllog();
$sql = "UPDATE " . USERS_TABLE . " SET user_active = 0 WHERE user_id = '" . $userdata['user_id'] . "'";
message_die(GENERAL_MESSAGE, $lang['ct_forum_blo']);
else if($userdata['ct_postcount'] == $ctracker_config['postintime'])
$ctinfomeldung = sprintf($lang['ct_forum_wa'] . '<br /><br />', $ctracker_config['posttimespan']);
$sql = "UPDATE " . USERS_TABLE . " SET ct_postcount = ct_postcount + 1 WHERE user_id = '" . $userdata['user_id'] . "'";
$stime = time() + $ctracker_config['posttimespan'];
$sql = "UPDATE " . USERS_TABLE . " SET ct_posttime = " . $stime . " WHERE user_id = '" . $userdata['user_id'] . "'";
$sql = "UPDATE " . USERS_TABLE . " SET ct_postcount = 2 WHERE user_id = '" . $userdata['user_id'] . "'";
#-----[ IN-LINE FIND AND DELETE ]------------------------------------------
$ctinfomeldung .
includes/usercp_email.php
if ( $userdata['ct_mailcount'] >= time() && $ctracker_config['mailfeature'] == 1 )
message_die(GENERAL_MESSAGE, $lang['ct_forum_emb']);
$mtimetemp = time() + 240;
SET ct_mailcount = " . $mtimetemp . "
includes/usercp_sendpasswd.php
$sql = "SELECT user_id, username, user_email, user_active, user_lang
, ct_pwreset, ct_unsucclogin
if ( $ctracker_config['pwreset'] == 1 )
if ( $row['ct_pwreset'] == 1 && $row['ct_unsucclogin'] >= time())
message_die(GENERAL_MESSAGE, $lang['ct_forum_pws']);
$loginsyst = time() + 14400;
SET ct_pwreset = '1', ct_unsucclogin = '" . $loginsyst . "'
WHERE user_id = " . $row['user_id'];
if ( !$db->sql_query($sql) )
message_die(GENERAL_ERROR, 'Could not update new password information', '', __LINE__, __FILE__, $sql);
includes/usercp_activate.php
SET ct_pwreset = '0', ct_unsucclogin = '0'
message_die(GENERAL_ERROR, 'Could not update users table', '', __LINE__, __FILE__, $sql);
login.php
// CBACK CrackerTracker Visual Login Confirmation
// visual confirmation code Generator taken from phpBB (c) phpBB Group
if ( isset($HTTP_GET_VARS['mode']) || isset($HTTP_POST_VARS['mode']) )
$mode = ( isset($HTTP_GET_VARS['mode']) ) ? $HTTP_GET_VARS['mode'] : $HTTP_POST_VARS['mode'];
$mode = htmlspecialchars($mode);
if ( $mode == 'confirm' )
exit;
include($phpbb_root_path . 'ctracker/ct_confirm.'.$phpEx);
exit;
// Now we check if the User is trying to Log in if he already has used one attempt or not
// if not we disable the Visual Confirmation Code and with this we allow a normal login without any Confirmation
// if the User tried to log in once we just continue with the normal Script and then we show the Visible Code every time the user
// tries to log in before checking Password or anything.
// Well OK its more DB gaming but many users want comfort AND security so let's do it ;-)
if(!empty($HTTP_POST_VARS['username']) && $ctracker_config['loginfeature'] == 1)
$secure_username = '';
$secure_username = isset($HTTP_POST_VARS['username']) ? phpbb_clean_username($HTTP_POST_VARS['username']) : '';
$sql = "SELECT ct_logintry FROM " . USERS_TABLE . " WHERE username = '" . str_replace("\\'", "''", $secure_username) . "'";
message_die(GENERAL_ERROR, 'Error in obtaining userdata', '', __LINE__, __FILE__, $sql);
if( $row = $db->sql_fetchrow($result) )
if($row['ct_logintry'] == 0)
$ctracker_config['loginfeature'] = 0;
if ( $ctracker_config['loginfeature'] == 1 && !$userdata['session_logged_in'] && !empty($HTTP_POST_VARS['confirm_id']) && !empty($HTTP_POST_VARS['confirm_code']))
$confirm_id = htmlspecialchars($HTTP_POST_VARS['confirm_id']); if (!preg_match('/^[A-Za-z0-9]+$/', $confirm_id))
$confirm_id = '';
$sql = 'SELECT code
FROM ' . CTVISKEY . "
WHERE confirm_id = '$confirm_id'
AND session_id = '" . $userdata['session_id'] . "'";
message_die(GENERAL_ERROR, 'Could not obtain confirmation code', __LINE__, __FILE__, $sql);
if ($row['code'] != $HTTP_POST_VARS['confirm_code'])
message_die(GENERAL_MESSAGE, $lang['ct_forum_sl1']);
$sql = 'DELETE FROM ' . CTVISKEY . "
if (!$db->sql_query($sql))
message_die(GENERAL_ERROR, 'Could not delete confirmation code', __LINE__, __FILE__, $sql);
$db->sql_freeresult($result);
$vcheck_need = FALSE;
$vcheck_login = TRUE;
if($ctracker_config['loginfeature'] == 1 )
$vcheck_need = TRUE;
$vcheck_login = FALSE;
if (($vcheck_need = FALSE || $userdata['session_logged_in']) or (isset($HTTP_GET_VARS['logout']) || !empty($HTTP_POST_VARS['confirm_id']) && !empty($HTTP_POST_VARS['confirm_code'])))
# The original line is longer!
if(( $vcheck_login == TRUE ) and
# Please replace the COMPLETE line!
if( isset($HTTP_POST_VARS['login']) || isset($HTTP_GET_VARS['login']) || isset($HTTP_POST_VARS['logout']) || isset($HTTP_GET_VARS['logout']) )
$sql = 'UPDATE ' . USERS_TABLE . ' SET ct_logintry = 0 WHERE user_id = ' . $row['user_id'];
if ($row['user_id'] != ANONYMOUS)
SET ct_logintry = 1
// CBACK CrackerTracker Login Confirmation
// Confirmation Generator Taken from phpBB (C) phpBB Group
$confirm_image = '';
if( $ctracker_config['loginfeature'] == 1 && !$userdata['session_logged_in'])
$sql = 'SELECT session_id
FROM ' . SESSIONS_TABLE;
message_die(GENERAL_ERROR, 'Could not select session data', '', __LINE__, __FILE__, $sql);
$confirm_sql = '';
do
$confirm_sql .= (($confirm_sql != '') ? ', ' : '') . "'" . $row['session_id'] . "'";
while ($row = $db->sql_fetchrow($result));
WHERE session_id NOT IN ($confirm_sql)";
message_die(GENERAL_ERROR, 'Could not delete stale confirm data', '', __LINE__, __FILE__, $sql);
$confirm_chars = array('A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z', '1', '2', '3', '4', '5', '6', '7', '8', '9');
list($usec, $sec) = explode(' ', microtime());
mt_srand($sec * $usec);
$max_chars = count($confirm_chars) - 1;
$code = '';
for ($i = 0; $i < 6; $i++)
$code .= $confirm_chars[mt_rand(0, $max_chars)];
$confirm_id = md5(uniqid($user_ip));
$sql = 'INSERT INTO ' . CTVISKEY . " (confirm_id, session_id, code)
VALUES ('$confirm_id', '". $userdata['session_id'] . "', '$code')";
message_die(GENERAL_ERROR, 'Could not insert new confirm code information', '', __LINE__, __FILE__, $sql);
unset($code);
$confirm_image = (@extension_loaded('zlib')) ? '<img src="' . append_sid("login.$phpEx?mode=confirm&id=$confirm_id") . '" alt="" title="" />' : '<img src="' . append_sid("login.$phpEx?mode=confirm&id=$confirm_id&c=1") . '" alt="" title="" /><img src="' . append_sid("login.$phpEx?mode=confirm&id=$confirm_id&c=2") . '" alt="" title="" /><img src="' . append_sid("login.$phpEx?mode=confirm&id=$confirm_id&c=3") . '" alt="" title="" /><img src="' . append_sid("login.$phpEx?mode=confirm&id=$confirm_id&c=4") . '" alt="" title="" /><img src="' . append_sid("login.$phpEx?mode=confirm&id=$confirm_id&c=5") . '" alt="" title="" /><img src="' . append_sid("login.$phpEx?mode=confirm&id=$confirm_id&c=6") . '" alt="" title="" />';
$hidden_form_fields .= '<input type="hidden" name="confirm_id" value="' . $confirm_id . '" />';
$template->assign_block_vars('switch_confirm', array());
'CONFIRM_IMG' => $confirm_image,
'L_CONFIRM_CODE' => $lang['ct_forum_slo'],
'S_HIDDEN_FIELDS' => $s_hidden_fields . $hidden_form_fields )
'S_HIDDEN_FIELDS' => $s_hidden_fields)
templates/subSilver/login_body.tpl
<!-- BEGIN switch_confirm -->
<td class="row1" colspan="2" align="center">
<br /><br /><span class="gen">{L_CONFIRM_CODE}</span>
<span class="gensmall"> </span><br /><br />{CONFIRM_IMG}<br /><br /></td>
<td colspan="2" align="center" class="row2">
<input type="text" class="post" name="confirm_code" size="25" maxlength="6" value="" />
<br /><br />
</td>
<!-- END switch_confirm -->
# Please remember to replace the prefix phpbb_ if you are using an other one!
# If you don't want to execute this SQL Commands manually just upload the
# db_uninstall.php to your Forum root and execute it!
DROP TABLE `phpbb_ctrack`;
DROP TABLE `phpbb_ct_filter`;
DROP TABLE `phpbb_ct_viskey`;
ALTER TABLE `phpbb_users` DROP `ct_logintry`;
ALTER TABLE `phpbb_users` DROP `ct_unsucclogin`;
ALTER TABLE `phpbb_users` DROP `ct_pwreset`;
ALTER TABLE `phpbb_users` DROP `ct_mailcount`;
ALTER TABLE `phpbb_users` DROP `ct_postcount`;
ALTER TABLE `phpbb_users` DROP `ct_posttime`;
ALTER TABLE `phpbb_users` DROP `ct_searchcount`;
ALTER TABLE `phpbb_users` DROP `ct_searchtime`;
# EoM
