[新聞] phpBB3 RC 釋出 (Update RC7)
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 Mac »
http://www.phpbb.com/community/viewtopi ... 4&t=585093
這一次 phpBB Group 使用了 SektionEins 的外部安全稽核,因此以下標為「安全相關」的問題皆是經由這個公司所找出來的
RC5 => RC7 的重大改變
[修正] Further fixing user profile view (please do not forget to update/refresh your template and style) (Bug #14230)
[修正] Adjust google adsense bot information (Bug #14296)
[修正] Fix horizontal scrollbar problem in IE6 (Bug #14228) - fix provided by Danny-dev
[修正] Correctly set user style for guest user (able to be changed within user management)
[修正] Do not use register_shutdown_function within cron.php if handling the queue and the mail function being used (Bug #14321)
[修正] Fixing private message on-hold code if moving messages into folder based on rules (Bug #14309)
[修正] Allow the merge selection screen to work (Bug #14363)
[修正] Local magic URLs no longer get an additional trailing slash (Bug #14362)
[修正] Do not let the cron script stale for one hour if register_shutdown_function is not able to be called (Bug #14436)
[修正] Fixed token handling in jabber class for extremely spec-compliant XMPP server (Bug #14445)
[修正] Use correct dimension (width x height) in ACP (Bug #14452)
[修正] Fixing google cache display problems with Firefox (Bug #14472) - patch provided by Raimon
[改變] Moved note about dns_get_record function for using GTalk (Jabber) from Jabber log to Jabber ACP panel
[改變] Require additional permissions for copying permission when editing forums
[改變] Listing the board url within the email text instead of appending it to the subject (Bug #14378)
[改變] Allow years in future be selected for date custom profile field (Bug #14519)
[新功能] Added /includes/db/db_tools.php file, which includes tools for handling cross-db actions such as altering columns, etc.
[新功能] Added completely new hook system to allow better application/mod integration - see docs/hook_system.html
[新功能] Added an option to enforce that users spend a configurable amount of time on the terms page during registration
[安全相關] Fixing possible XSS through compromised WHOIS server (#i63, #i64)
[安全相關] Missing access control on whois in viewonline.php (#i51)
[安全相關] Encoding some variables within user::page array correctly (to cope with browser not doing it correctly) to prevent XSS through functions re-using them (#i61)
[安全相關] Fixed XSS through memberlist search feature (#i62)
[安全相關] Fixed XSS through colour swatch (#i65)
[安全相關] Fixed insecure attachment deletion (#i53)
[安全相關] Only allow whitelisted protocols in meta_redirect/redirect (#i66)
[安全相關] Check file names to be written in language management panel (#i52)
[安全相關] Deregister globals if ini_get has been disabled (#i112)
[安全相關] Added form tokens to most forms to enforce a lighter variant of CSRF protection (#i91 - #i96)
[安全相關] Use new password hash method for forum passwords (#i43)
[安全相關] Changed download file location to prevent flash crossdomain policies taking effect (#i8)
[安全相關] Do not allow autocompletion for password on admin re-authentication (#i41)
[安全相關] Made sure users are not completely locked out if they have a GLOBALS cookie (#i101)
[安全相關] Use the secure hash to generate BBCODE_UIDs (#i71)
[安全相關] Increase the length of BBCODE_UIDs (#i72)
[安全相關] New password hashing mechanism for storing passwords (#i42)
下載:http://www.phpbb.com/downloads/
~Mac
最後由 Mac 於 2007-12-02 07:46 編輯,總共編輯了 1 次。
Meowmeow
文章: 221
註冊時間: 2006-03-01 17:03
來自: 台北
文章 Meowmeow »
更新的也太快了,不到 48 小時。 =.=
Chita,一個野性獸圖聖殿。
ckmarkhsu
文章: 139
註冊時間: 2005-03-21 09:38
文章 ckmarkhsu »
#i43
有 salt 了,不錯不錯:)
台灣深藍vBulletin技術論壇
vBulletin 論壇系統,內建
「0 修改新增插件」「完整附件功能」「無限深度子論壇」「進階權限管理」「前台 AJAX 即時管理」
歡迎研究:)
cloudsnow30
文章: 246
註冊時間: 2005-03-27 03:38
文章 cloudsnow30 »
對於RC X 版...
真的是有點懶得裝了...
目前是在等待正式版
期間也去玩了一些CMS的系統
覺得還挺不錯的...
(現在在試JOOMLA和PHPBB2的整合)
才知自己的能力是多麼的膚淺~~~~Orz
近況:站長的心變成浮動ip.不定時罷工中.= =
目標:努力活下去,....^^"
● (目前是租用虛擬主機架站)
++稜鏡之森++Prism Forest++
私の気まぐれな世界
++++自家主機使用++++
●架設主機作業系統:Windows11
●快速架站程式:XAMPP for Windows
●您的上網方式:ADSL 1G/600M
●錯誤代碼及狀態:如說明
~倉木麻衣~
文章: 1405
註冊時間: 2004-03-21 21:00
文章 ~倉木麻衣~ »
個人倒覺得phpBB3 RC版的更新速度、頻率還算OK的
如果你有在用EmEditor的話, 到它的Beta Version Bug Reports版面去看一下
你會發現它的Beta改版速度才真是快到讓人手軟
有時連續四五天, 天天都放出新的Beta版
而且到目前為止已經是第16版的Beta了
相較之下, phpBB RC推出的速度反而沒那麼誇張了
謝絕所有私人訊息詢問外掛相關問題
竹貓禁止發表含破解相關的軟體, 違者砍文
不要跟我講別的地方都可以發, 為什麼竹貓就不行
免費不等於破解, 傻傻的搞不清楚
Graphic
文章: 6
註冊時間: 2006-06-16 18:21
文章 Graphic »
~倉木麻衣~ 寫:個人倒覺得phpBB3 RC版的更新速度、頻率還算OK的
Beta 更新頻繁那是正常的,已經表明是Beta 版,當然是要一直測試
RC 就是正式版前身,但是很少看到RC 可以出到 RC 7,大多數都是RC 2再來就是正式版了
~倉木麻衣~
文章: 1405
文章 ~倉木麻衣~ »
Graphic 寫:RC 就是正式版前身,但是很少看到RC 可以出到 RC 7,大多數都是RC 2再來就是正式版了
能到RC7確實是不多見
但就正式版前身而言, 多幾次RC也不是件壞事
何況RC2之後就是正式版也不是硬性規定, 有一堆的軟體Beta完就直接跳正式版了
與其要硬上正式版後再來頻繁的做更新, 那我寧可讓他多來幾次RC
至少在正式版時會更有保障
謝絕所有私人訊息詢問外掛相關問題
免費不等於破解, 傻傻的搞不清楚
Graphic 寫:
無論 RC 最終釋出到幾版, 畢竟, 官方的謹慎做法是值得肯定的.
因為只是 RC 版, 所以僅鼓勵大家針對新的 RC 版做測試, 與相關 BUG 討論.
We encourage only those running the release candidates wanting to test out the new version, it is still recommended to wait for the full release; after all this is a release candidate.
Please also note that we urge you to update - we only support the latest version. Bug reports submitted for previous releases will be closed as well as only the latest version being supported here.
Source: http://www.phpbb.com/community/viewtopi ... 4&t=585093
