[發問] Phpbb2.0.22(UTF-8)轉換PhpBB3過程中發生問題
phpBB 3 Conversion Support
官方 phpbb.com 自訂資料庫已收錄之轉換器
ttshtai
註冊時間: 2008-04-24 10:21
文章 ttshtai »
前兩天我朋友發過一篇文章發問
但是error log裡面的連結卻被心靈捕手大發現有木馬
真的很不好意思
我們只是照貼出來 並不知道連結是有問題的 希望心靈捕手大原諒
以下是我們目前遇到的狀況 並已經更新心靈捕手大所需資訊 還請各位幫忙
目前我們是要將電腦內的資料庫備份(phpbb2)上載到新的空間並升級成phpbb3
於是按照板上教學先安裝phpbb2, 然後用板上提供外掛程式將資料庫上載至新空間
接著另外安裝phpbb3並進行升級動作
在伺服器空間下我把phpbb2及phpbb3分成兩個資料夾
名稱個別為 phpbb2 及phpbb3
安裝過後按下進行轉換便出現以下錯誤訊息
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@XXX.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.8 (Unix) mod_ssl/2.2.8 OpenSSL/0.9.8g DAV/2 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 Server at XXX.com Port 80
以下是error log所提供訊息 由於心靈捕手大的提醒 我已把referer的連結都去掉
[Mon Apr 28 15:46:13 2008] [error] [client 123.22.108.241] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0, referer:
[Mon Apr 28 15:46:16 2008] [error] [client 123.22.108.241] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0, referer:
[Mon Apr 28 15:46:16 2008] [error] [client 203.162.3.155] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0, referer:
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/ixedts.lin' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/ixedts.lin: undefined symbol: executor_globals_id in Unknown on line 0
[Mon Apr 28 15:46:17 2008] [error] [client 203.160.1.44] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0
[Mon Apr 28 15:46:22 2008] [error] [client 203.160.1.44] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0, referer:
[Mon Apr 28 15:46:23 2008] [error] [client 118.68.164.205] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0, referer:
[Mon Apr 28 15:46:23 2008] [error] [client 222.254.69.240] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0, referer:
[Mon Apr 28 15:46:25 2008] [error] [client 203.160.1.44] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0, referer:
[Mon Apr 28 15:46:31 2008] [error] [client 203.160.1.44] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0, referer:
[Mon Apr 28 15:46:31 2008] [error] [client 222.254.69.240] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0, referer:
虛擬主機基本資料
Apache version: 2.2.8 (Unix)
MySQL version: 5.0.45-community-log
Operating system: Linux
快速架站程式:N/A
您的 phpBB 版本:phpBB 2.0.22
php版本: 5.2.5
phpbb2網址: http://formosamba.com/phpbb2/
文章: 8538
Re: [發問] Phpbb2.0.22(UTF-8)轉換PhpBB3過程中發生問題
ttshtai 寫:目前我們是要將電腦內的資料庫備份(phpbb2)上載到新的空間並升級成phpbb3
接著另外安裝phpbb3並進行升級動作
安裝過後按下進行轉換便出現以下錯誤訊息
貼出新的空間 '安裝phpbb2' 後的網址.
ttshtai
文章 ttshtai »
心靈捕手大
安裝phpbb2後的網址為 http://formosamba.com/phpbb2/
請參考 謝謝
文章: 8538
ttshtai 寫:心靈捕手大
請參考 謝謝
請再貼出您新的 phpBB 3 網址.
ryan11
文章: 59
註冊時間: 2006-01-24 01:34
文章 ryan11 »
回ls , 他的phpb3 在此
http://formosamba.com/phpbb3/
romeox
文章: 8
註冊時間: 2008-03-17 18:22
文章 romeox »
ttshtai 寫: [Mon Apr 28 15:46:13 2008] [error] [client 123.22.108.241] PHP Warning: Zend Optimizer for PHP 5.2.x cannot be found (expected at '/usr/local/Zend/lib/Optimizer/php-5.2.x/ZendOptimizer.so') - try reinstalling the Zend Optimizer in Unknown on line 0, referer:
ttshtai你好,我是路過的 ;) ,一點問題請問,
error log中有寫到Zend Optimizer這個厡件找不到,
請問你有在server上試著搜尋這個套件在不在嗎?
回到「[3.0.x] 轉換」
