ACP Announcement Centre 公告中心 的外掛問題(畫面被切割無法對齊)
Re: ACP Announcement Centre 公告中心 的外掛問題(畫面被切割無法對齊)
j0958322080 寫:我打好公告後按送出會出現以下的錯誤
SQL ERROR [ mysql4 ]
Incorrect string value: '\xE8\x8B\xA6\xE7\xAC\x91...' for column 'announcement_text' at row 1 [1366]
SQL
UPDATE phpbb_announcement_centre SET announcement_enable_guests = 1, announcement_show = 0, announcement_show_birthdays = 0, announcement_birthday_avatar = 0, announcement_title = 'Site Announcements', announcement_text = '[color=red:rwki90je][b:rwki90je]Site Announcements[/b:rwki90je][/color:rwki90je] can be seen here!! <!-- s:mrgreen: --><img src=\"{SMILIES_PATH}/icon_mrgreen.gif\" alt=\":mrgreen:\" title=\"苦笑\" /><!-- s:mrgreen: -->', announcement_text_bbcode_uid = 'rwki90je', announcement_text_bbcode_bitfield = 'Qg==', announcement_text_bbcode_options = 7, announcement_draft = '[color=red:1khgj1v3][b:1khgj1v3]Draft Announcements[/b:1khgj1v3][/color:1khgj1v3] can be seen here!! <!-- s:mrgreen: --><img src=\"{SMILIES_PATH}/icon_mrgreen.gif\" alt=\":mrgreen:\" title=\"苦笑\" /><!-- s:mrgreen: -->', announcement_draft_bbcode_uid = '1khgj1v3', announcement_draft_bbcode_bitfield = 'Qg==', announcement_draft_bbcode_options = 7, announcement_title_guests = 'Guest Announcements', announcement_text_guests = '[color=green:1abr2n13][b:1abr2n13]Guest Announcements[/b:1abr2n13][/color:1abr2n13] can be seen here!! <!-- s:wink: --><img src=\"{SMILIES_PATH}/icon_e_wink.gif\" alt=\":wink:\" title=\"眨眼\" /><!-- s:wink: -->', announcement_text_guests_bbcode_uid = '1abr2n13', announcement_text_guests_bbcode_bitfield = 'Qg==', announcement_text_guests_bbcode_options = 7, announcement_show_group = '2'
BACKTRACE
FILE: includes/db/mysql.php
LINE: 158
CALL: dbal->sql_error()
FILE: includes/acp/acp_announcements_centre.php
LINE: 99
CALL: dbal_mysql->sql_query()
FILE: includes/functions_module.php
LINE: 471
CALL: acp_announcements_centre->main()
FILE: adm/index.php
LINE: 74
CALL: p_master->load_active()
資料庫有經過竹貓的修正才更新的
但載入時會有以下錯誤
SQL 語法:
INSERT INTO phpbb_config( config_name, config_value )
VALUES (
'announcement_show_index', '0'
MySQL 傳回:
#1062 - Duplicate entry 'announcement_show_index' for key 1
依發問格式, 重新發表主題.
jkcat
文章: 49
註冊時間: 2003-07-05 13:45
文章 由 jkcat »
●主機作業系統:Windows xp
●快速架站程式:AppServ 2.4.0
●您安裝的程式:AppServ 2.4.0 套裝程式
●您的 phpBB 版本:phpBB 3.0.3
●安裝外掛:ACP Announcement Centre (公告中心)1.0.3.a
問題:畫面被切割無法對齊
畫面如下,已爬文無相似問題,煩請解答,謝謝
jkcat 寫:●主機作業系統:Windows xp
問題:畫面被切割無法對齊
1. 貼出論壇網址
2. 試試清除快取
jkcat
文章: 49
文章 由 jkcat »
1. 貼出論壇網址
網址
http://220.132.188.229/phpbb3/index.php
2. 試試清除快取
我試過,但神奇的是
我將原本檔案overall_header覆蓋後,清除快取
論壇首頁都沒動靜,好像不需要這檔案修改似的
請幫我解答 ,謝謝
jkcat 寫:
1. 貼出論壇網址
網址
2. 試試清除快取
我試過,但神奇的是
請幫我解答 ,謝謝
1. 連不上您貼的網址?
2. 聽不太懂您說什麼? :oops:
jkcat
文章: 49
文章 由 jkcat »
1. 貼出論壇網址
抱歉!!這是我對外ip我忘記關掉防火牆了
請再幫我看看,謝謝
jkcat 寫:1. 貼出論壇網址
請再幫我看看,謝謝
我猜想:
是因為 "跑馬燈" 影響了版面的寬度.
試試用 "一般的" 文字, 做為公告的內容.
jkcat
文章: 49
文章 由 jkcat »
jkcat 寫:1. 貼出論壇網址
請再幫我看看,謝謝
我猜想:
是因為 "跑馬燈" 影響了版面的寬度.
我拿掉跑馬燈只有純文字,清除快取,還是沒變回來
jkcat 寫:
jkcat 寫:1. 貼出論壇網址
請再幫我看看,謝謝
我猜想:
是因為 "跑馬燈" 影響了版面的寬度.
有點詭異?
我以 IE 瀏覽, 除了首頁, 其他版面都是正常的;
而以 Fx 瀏覽, 則一切正常.
試試 "重新整理"--ACP > 風格 > 樣板 > prosilver > 重新整理
jkcat
文章: 49
文章 由 jkcat »
我拿掉跑馬燈只有純文字,清除快取,還是沒變回來[/quote]
有點詭異?
而以 Fx 瀏覽, 則一切正常.
試試 "重新整理"--ACP > 風格 > 樣板 > prosilver > 重新整理[/quote][/quote]
動作完成 仍沒改善
但我除登出登入畫面會正常外,其他版面都不正常
包括剛剛裝的簡易TOP5,還是我瀏覽器問題阿,謝謝
jkcat 寫:動作完成 仍沒改善
1. 我指的是像 "問答集" "註冊" 等頁面也是正常的.
2. 我還是以為:
也許您有做了哪些其他修改, 而導致這個現象發生.
  • 若仍不死心, 則先試試回復原始狀態.
    1. 以原始的 styles/prosilver/*.* 覆蓋論壇
    2. 清除論壇快取
    3. 重新整理風格 prosilver (樣板, 主題, 圖檔組)
  • 若可回復原始狀態, 則再重新修改外掛.
