我的版本是2.07
我於版面更改描述時
按下更新也有此問題:
SQL Error : 1064 You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near ' lock_enable = 0, lock_enable = 0 WHERE forum_id = 1' at li
[轉貼]phpBB 2.0.5 的潛在性 SQL 弱點
