今天也買了一本phpbb2004回來練習
但是進入設定畫面時出現下列錯誤.請問是那裡出了問題嗎?
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 23
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 24
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 25
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 26
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 27
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 29
錯誤
MySQL 傳回:
Can't connect to MySQL server on 'localhost' (10061)
[推薦]phpbb論壇架設寶典2004
[問題]對不起不該亂發問
不好意思...不該亂發問.浪費網頁空間的.下次我會看清楚跟研究好後真的不懂再問
也謝謝您的回答.這個問題我以解決.
也謝謝您的回答.這個問題我以解決.
我在書店中也有看到竹貓出的書\r
雖然很有衝動的想買下
但是.......
我只是覺得直接上來竹貓學會比較快\r
所以就沒買嚕~
不過我有在書店中把所有內容都看了一次\r
讓自己對php更有概念一點
雖然很有衝動的想買下
但是.......
我只是覺得直接上來竹貓學會比較快\r
所以就沒買嚕~
讓自己對php更有概念一點
~§ 架站系統:WindowsXP §~
~§ 架站程式:Appserv2.4.4a §~
~§ 使用網路:giga ADSL §~
~§ 論壇版本: 2.0.18 §~
申明檔
3.還是想不通嗎? 那可以到地下十八樓找你的答案。
~§ 論壇版本: 2.0.18 §~
申明檔
