phpBB 2.0.20 released!!
文章 chiouss »
chiouss 寫:現在只剩下這個問題了...好歹也判斷一下版本吧,不能只是不相等就這樣跟人家說阿 XD
改好了 :P
最後由 chiouss 於 2006-04-08 18:54 編輯,總共編輯了 1 次。
jwxinst
文章: 945
註冊時間: 2006-03-31 10:07
文章 jwxinst »
之前也有想過說"多國語系"
不過本身引言+簡體應該可以
多半是 Code變成亂碼 :roll:
那麼我們也等竹貓各位大大辛苦囉 ;-)
目前狀態圖檔
GoKo Music進度: 10%
新手必讀
問問題的技巧
MOD安裝教學及轉碼
DL
文章: 717
註冊時間: 2005-03-05 15:29
文章 DL »
就我個人而言,我的翻譯是這樣
[Fix] Prevent login attempts from incrementing for inactive users
[修正] 為不活躍的會員增加嘗試登入的次數限制
[Fix] Do not check maximum login attempts on re-authentication to the admin panel - tomknight
[修正] 現在進入後台的密碼輸入錯誤,將不會被計算在嘗試登入的次數限制中
[Fix] Regenerate session keys on password change
[修正] 當在變更密碼時,session keys將重新產生
[Fix] retrieving category rows in index.php (Bug #90)
[修正] 在index.php中恢復分區欄位
[Fix] improved index performance by determining the permissions before iterating through all forums (Bug #91)
[修正] (不肯定)
[Fix] Better handling of short usernames within the search (bug #105)
[修正] 現在能更好的處理會員名稱較短的搜尋,例如DL(這句是自己加的 :-P
[Fix] Send a no-cache header on admin pages as well as normal board pages (Bug #149)
[修正] 發送一個no-cache的檔頭在後台就像一個普通的版面頁
[Fix] Apply word censors to the message when quoting it (Bug #405)
[修正] 修正某些字不能引言
[Fix] Improved performance of query in admin_groups (Bug #753)
[修正] (不肯定)
[Fix] Workaround for an issue in either PHP or MSSQL resulting in a space being returned instead of an empty string (bug #830)
[修正] (不肯定)
[Fix] Correct use of default_style config value (Bug #861)
[修正] 正確地使用default_style的設定值
[Fix] Replace unneeded unset calls in admin_db_utilities.php - vanderaj
[修正] 取代admin_db_utilities.php不需要的unset call
[Fix] Improved error handling in modcp.php
[修正] 改進modcp.php中的錯誤處厘
[Fix] Improved handling of forums to which the user does not have any explicit permissions - vanderaj
[修正] (不肯定)
[Fix] Assorted fixes and cleanup of admin_ranks.php, now requires confirmation of deletions
[修正] 刪除等級,現在需要確認
[Fix] Assorted fixes and cleanup of admin_words.php, now requires confirmation of deletions
[修正] 刪除過濾用字,現在需要確認
[Fix] Addition and editing of smilies can no longer be performed via GET, now requires confirmation of deletions
[修正] 刪除過濾表情符號,現在需要確認
[Fix] Escape group names in admin_groups.php
[修正] (不肯定)
[Sec] Replace strip_tags with htmlspecialchars in private message subject
[安全修正] (不肯定)
[Sec] Some changes to HTML handling if enabled
[安全修正] 某些HTML的處理被修改如果啟用
[Sec] Escape any special characters in reverse dns - Anthrax101
[安全修正] (不肯定)
[Sec] Typecast poll id values - Anthrax101
[安全修正] (不肯定)
[Sec] Added configurable search flood control to reduce the effect of DoS style attacks
[安全修正] (不肯定)
[Sec] Changed the way we create "random" values for use as keys - chinchilla/Anthrax101
[安全修正] (不肯定)
[Sec] Enabled Visual Confirmation by default
[安全修正] 防機器人註冊機制將預設開啟
[Change] Changed handling of the case where a selected style doesn't exist in the database
[安全修正] (不肯定)
[Change] Changed handling of topic pruning to improve performance
[安全修正] (不肯定)
[Change] Changed default forum permissions to only allow registered users to post in new forums
[安全修正] 以後的建立的版面,將預設只允許註冊會員發表
文章 chiouss »
jwxinst 寫:之前也有想過說"多國語系"
不過本身引言+簡體應該可以
多半是 Code變成亂碼 :roll:
那麼我們也等竹貓各位大大辛苦囉 ;-)
這就是轉 UTF8 的好處 XD
就算不是什麼大站、沒有用多少種語言 (我也不過用中文和一些日文),只是為了搞定中文的問題也很值得。
jwxinst
文章: 945
文章 jwxinst »
2.0.15多國語系修正仍然可以使用@@
不過一直的更新, 相對應的2.0.19多國語系修正仍然沒有時間...
作者也是很辛苦啦@@
所以我也等待他有空看看將來的板本相對..... :-P
目前狀態圖檔
GoKo Music進度: 10%
新手必讀
問問題的技巧
MOD安裝教學及轉碼
文章 chiouss »
那個多國語系修正是還可以用沒錯,畢竟我也曾經用過。但是轉 utf8 以後我就沒去理那個東西過了,或許是因為我都不裝 mod 所以很方便吧?
jwxinst
文章: 945
文章 jwxinst »
現在的板本都不會影響到 2.0.15多國語系修正
現在的2.0.20. 是3.X的一個更新
如果看到check-in的話, 叼以看到類似的修正
將來的板本就會有最少數個外掛加入~ :oops:
目前狀態圖檔
GoKo Music進度: 10%
新手必讀
問問題的技巧
MOD安裝教學及轉碼
澀男人
文章: 32
註冊時間: 2004-01-18 20:44
原來給2.0.15版的多國語系修正在2.0.20真的還可以用嗎?
文章 澀男人 »
chiouss 寫:那個多國語系修正是還可以用沒錯.....
jwxinst 寫:現在的板本都不會影響到 2.0.15多國語系修正.....
:?: 樓上二位前輩都說原來給2.0.15版的多國語系修正還可以用。
不過不知何故?在我的論壇卻無法使用了。
可否請前輩高手們幫忙查看原因?非常感激!
我是從2.0.19(big5版本)按照官方的code changes逐一修正升級為2.0.20版。在2.0.19以前,的確2.0.15的多國語系修正都還OK,不過升級為2.0.20後,卻出現「新發表簡體中文文章」或「引言回覆簡體中文文章」時,簡體中文都會變成亂碼,也就是根本不能再使用簡體中文了,除非從後台將HTML功能關閉,簡體中文才會正常,這令我非常苦惱。我也考慮將論壇轉為utf8版,不過自己還有許多不懂,沒把握可以轉換成功,不敢輕舉妄動。 :cry:
:idea: 我的使用環境如下:
●架設主機作業系統:FreeBSD 4.10。
●上網方式:Seednet ADSL。
●租用空間安裝的程式:Apache1.3.33 + php4.4.1 + MySql2.7.0 。
●phpBB2 版本:phpBB 2.0.19。
●domain:www.doecosway.com
●phpBB2 連結網址: http://www.doecosway.com/share
:idea: 我的include/functions_post.php檔案內容如下:
http://www.urchance.com/other_images/functions_post.txt
承蒙指導,不勝感激!
eCosway為您的人生增添光彩
歡迎參觀我的網站:http://www.doecosway.com/tw063252
jwxinst
文章: 945
文章 jwxinst »
首先, 這次的更新, 增加了 HMTL的修正...
個人而言, HTML並不應該打開, 因為允許了, 會插入很多病毒碼...
BBCODE卻阻止了這一點
對於亂碼, 通常應該不會發生這種事情
看來是在2.0.20更動了CODE之間.... :oops:
目前狀態圖檔
GoKo Music進度: 10%
新手必讀
問問題的技巧
MOD安裝教學及轉碼
Re: 原來給2.0.15版的多國語系修正在2.0.20真的還可以用嗎?
澀男人 寫: 我是從2.0.19(big5版本)按照官方的code changes逐一修正升級為2.0.20版。在2.0.19以前,的確2.0.15的多國語系修正都還OK,不過升級為2.0.20後,卻出現「新發表簡體中文文章」或「引言回覆簡體中文文章」時,簡體中文都會變成亂碼,也就是根本不能再使用簡體中文了,除非從後台將HTML功能關閉,簡體中文才會正常,這令我非常苦惱。我也考慮將論壇轉為utf8版,不過自己還有許多不懂,沒把握可以轉換成功,不敢輕舉妄動。 :cry:
承蒙指導,不勝感激!
試試以下的修改方法:
以關鍵字 'htmlspecialchars' 搜尋此檔
若有做過 '多國語言修正' 則是會出現 'dohtmlspecialchars'
若仍舊保持 'htmlspecialchars' 則請修改為 'dohtmlspecialchars'
ps.
仔細找找, 您可能必須修改 5 次.
動機不明
喝咖啡的綠皮猴
喝咖啡的綠皮猴
文章: 1179
註冊時間: 2002-03-06 20:37
來自: GOP (重啟)
文章 動機不明 »
這次真的很容易出錯... :oops: (三次)
有些地方還是找不到問題,乾脆直接覆蓋才OK的 :oops: (大概是個人問題,不要理我這篇的解決經驗...)
jwxinst
文章: 945
文章 jwxinst »
剛剛再看code changed files.txt
應該再按多國語言中要求的類似句子 作出修改....
不只是 function_post
posting.php等也有多國語言的修正
不過致老師,
像fucntion_post中的
return htmlspecialchars('<' . $tag[1] . $attributes . '>');
類似的是否也需要加入 do?
所以我應該按照2.0.15中提到要修改的地方, 加上 do, 對不?
(其他的別裝帥 :mrgreen:
ps: 原來動機大也上來....
我仍然在等待官方提出修正....
這次2.0.20出來好像有點.....
修正卻是一種麻煩 :oops:
big-5的用戶可得搜尋多一次 :-|
最後由 jwxinst 於 2006-04-10 00:15 編輯,總共編輯了 1 次。
目前狀態圖檔
GoKo Music進度: 10%
新手必讀
問問題的技巧
MOD安裝教學及轉碼
文章 chiouss »
jwxinst 寫:像fucntion_post中的
類似的是否也需要加入 do?
都加上去應該不會有事才對...
無責任發言 :P
kkt
文章: 625
註冊時間: 2005-06-15 01:37
來自: H.K.
文章 kkt »
jwxinst, 唉, 我這麼多外掛修改中, 可最成功是這個多語修正..
分享我的經驗, 我按作者說: 反正有 htmlspecialchars 的之前都加上 do 就是了..
有加多, 沒減少, 我全部都加遍了. 到今天沒出現過亂碼. sure!!
在此學到很多架站知識, 永遠多謝:
jwxinst
文章: 945
文章 jwxinst »
:oops: 我是膽小@@
嘿...不想害別人-_-"
@@那麼就全部 都加上do好了 :-|
目前狀態圖檔
GoKo Music進度: 10%
新手必讀
問問題的技巧
MOD安裝教學及轉碼
