[問題]網站被外來者更改
文章 由 chiouss »
china2000 寫:Do you mind to tell me more about the installation steps (run which php file to upgrade?) as I've no experience to install phpBB2 before.
正常安裝的時候畫面上有個選項可以選完整安裝或是升級,在這個地方選擇升級就好了。
