各位大大安安 在這ㄍ站看ㄌ很多篇ㄉ心得及成果,ㄝ引起我對PHPBBㄉ興趣\r
買ㄌ書 照書上ㄉ只是來操作 發現一些可能讓大家好笑ㄉ問題 希望 各位前被能替我解危\r
我ㄉ問題如下:
1. 就書上ㄉ方式 灌APPSERV,在"系統管理員ㄉE-MAIL帳號"是要怎ㄇ設定設定
我ㄉ意思是,假如 我ㄉE-MAUL是AA@PCHOME.COM.TW ,是不是 就是輸入 這ㄍ 還是有其他
2.灌好ㄌAPPSERV,要啟動APPSERV,有時 無法START, 有時 可以,是不是 我再灌ㄉ時候,沒注意到什ㄇㄋ
3.等到APPSERV 可以STARTㄌ,執行phpMyAdmin Database Manager Version 2.2.6 卻出現 以下ㄉ訊息\r
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 23
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 24
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 25
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 26
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 27
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\appserv\www\phpmyadmin\header.inc.php on line 29
錯誤
MySQL 傳回:
Can't connect to MySQL server on 'localhost' (10061)
●架設主機作業系統:Windows:Xp Pro
●快速架站程式:Appserv
●免費空間連結:
●上網方式:學術網(目前是)
●phpBB2 版本:phpBB 2.0.2
●錯誤狀態:如上
順便告知電腦ㄉ配備
●CPU: P4 1.5GA
●ASUS P4B
●SD 256MB 記憶體
[問題]我是阿呆 請各位大大幫幫忙
