一般錯誤
Couldn't update private forum permissions
SQL Error : 1064 You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near ' 1)' at line 2
INSERT INTO phpbb_auth_access (forum_id, group_id, auth_mod) VALUES (8, , 1)
Line : 388
File : /home/oranging/public_html/cmu/admin/admin_ug_auth.php
SQL Error : 1064 You have an error in your SQL syntax near ' 1)' at line 2
INSERT INTO phpbb_auth_access (forum_id, group_id, auth_mod) VALUES (2, , 1)
Line : 389
File : c:\appserv\www\cdsforum\admin\admin_ug_auth.php
